Go to Post Listen, my team lost in the finals to that alliance, and I've never suffered a more entertaining arse-kicking. Case closed. - Petey [more]
Unread 16-12-2013, 17:11
F Elliott F Elliott is offline
FTC #8114
Team Role: Teacher
Rookie Year: 2013
F Elliott is an unknown quantity at this point
Fusing Samantha and the Controllers
Rookie coach alert!
We are using a Powerwerx RIGrunner 4005H power distribution panel on our FTC robot. I posted on FTC rules forum and it was approved. Yay.
It has one input Anderson Powerpole connection and five output connections. Each are individually fused. This is our configuration:
Input: From battery after master switch
Output 1: Motor Controller with two motors
Output 2: Motor Controller (same as above)
Output 3: Servo Controller with six HS-485HB servos
Output 4: Servo Controller with two HS-785HB servos
Output 5: Samantha Module
What size fuses do you think I should use for each connection?
THANKS!
