Go to Post I love the smell of burnt motors in the morning! - Mike Betts [more]
Unread 17-12-2013, 12:34
EricWilliams EricWilliams is offline
FRC #2039 (Rockford Robotics)
EricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of light
Lightbulb 3.6GHz 802.11y for Competitions
Based on a thread in the Scouting forum that has now grown legs and walked off-topic, I thought having a quick discussion about the possibility of changing the robot <-> FMS communications technology for the purpose of enhancing both the performance, security, and spectator/team "quality of experience" (I understand we'd only be removing only a minimal inconvenience, but you don't try to minimize the benefits of your proposal while making it).
I'm sure this conversation happened over and over again after the Einstein incident, but I couldn't find much about my specific idea. Sorry if this is old news re-hashed, hopefully the thread will quickly disappear into obscurity if that's the case.
What about the possibility for FIRST official competitions (just focusing on FRC now, as we already have an entirely separate scenario in FTC/FLL) to try to acquire (relatively - from what little information I can find) cheap licenses from the FCC for 802.11y 3.6GHz operation. References: http://www.bwianews.com/2007/06/fcc_attempts_th.html, http://en.wikipedia.org/wiki/IEEE_802.11y-2008
Teams could still practice/demonstrate/run off-season events using standard ISM band WiFi - at the competitions the wireless bridge would simply be swapped out for a FIRST owned 3.6GHz module.
As the MAC and higher layers remain the same, there shouldn't be any performance difference between practice/demo/off-season and competition. And this is not a proposal to come full circle and go back to custom radios in obscure spectrum bands - this is (mostly) standard COTS hardware.
It's a bit of an up-front investment, but I think there's potential to improve things.
Unread 17-12-2013, 12:50
yash101 yash101 is offline
Curiosity | I have too much of it!
AKA: null
Rookie Year: 2012
yash101 is an unknown quantity at this point
Re: 3.6GHz 802.11y for Competitions
That is a great idea! Also, I think that the thread "Internet at Competitions" has also gotten a drivetrain and drove off the road to off-topic! 3.36 GHz is one of the lesser-used frequencies, so the communication would be much less prone to interference! Also, I haven't been been able track down a trustable source, explaining whether FRC uses 2.4GHz or 5GHz!
By the way, this is a tad off-topic, but why does 5GHz not penetrate walls so easily, where 2.4GHz will cover my entire (large) home?
Unread 17-12-2013, 13:12
magnets's Avatar
magnets magnets is offline
Rookie Year: 2012
magnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond repute
People brought this up in the Einstein 2012 thread, and they realized three things.
1. 3.6GHz is a licensed channel, so first would have to pay.
2. The problems (excluding those of Einstein 2012) aren't caused by interfering signals.
3. If implemented properly, normal 802.11n should work fine, even with lots of other networks happening at the same time. Instead of making it more complicated to fix the problem, FIRST should resolve the current issue.
Overall, the 3.6GHz solution requires too much work (money, new radios...) in order for something that may not be the right solution, may make the situation worse, or could be resolved another way.
That being said, using a different frequency would be great. The old IFI radios were 900MHz, and had a pretty decent bandwidth, more than what we need for control data. The camera data could still be sent over wifi, and they even make axis cams with built in wifi.
Unread 17-12-2013, 13:48
techhelpbb's Avatar
techhelpbb techhelpbb is offline
FRC #0011 (MORT - Team 11)
Rookie Year: 1997
techhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond repute
Even if FIRST reduces each field to a single channel and makes the field/robot system more stable the effect of reusing a channel will be degraded performance with one or more network.
Once the other network is out of FIRST's control the risk of channel monopolization is high.
As we have both stated putting the show stopping robot communication on a different channel is possible. That other channel should be easier to diagnose without robots of various different needs placing demands on it. The field systems are common and required for all fielded robots. TCP/IP and video is not required but nice to have.
On the topic of 3.6GHz it only perpetuates binding the necessary field communications to the extra optional traffic.
It would be far cheaper to use RS232/TTL serial to RF adapters for the field traffic.
Licensing issues may apply to both options.
Course we could try IRDA for the fields and make the fields more RF immune.
Unread 17-12-2013, 14:23
The fact that it's licensed is stated in the proposal. Many telecommunication technologies require an FCC license for use - the reason these bands/services are licensed is to protect the users from interfering signals. As that's the point of this proposal, I feel it's an acceptable cost.
From the FCC site (http://wireless.fcc.gov/services/ind...&id=3650_3700), it appears the filing fee would be $60 + $150/Call Sign - at worst, this is less than $2000 (somewhere between $50 and $100 per team) These events cost money - the A/V budget alone for some events would most likely be mind boggling. I think that's a reasonable price to pay to ensure that the command & control network remains isolated and secure.
I don't agree, or at least don't find enough evidence to support that statement in your comment to summarily dismiss the idea.
As for going back to some type of custom hardware/radio: that completely undermines the biggest benefit of going away from the 900MHz radios - that teams can use standard COTS equipment for development/demo/practice/off-season events. I'm suggesting simply swapping out the bridge before you bring the robot out onto the field.
Unread 17-12-2013, 14:36
techhelpbb's Avatar
Rookie Year: 1997
Originally Posted by EricWilliams View Post
As for going back to some type of custom hardware/radio: that completely undermines the biggest benefit of going aay from the 900MHz radios - that teams can use standard COTS equipment for development/demo/practice/off-season events. I'm suggesting simply swapping out the bridge before you bring the robot out onto the field.
When I helped propose a 2015 control system I got around this by making a module that accepted radio modules of various frequencies. FIRST could send teams ISM band modules (often unlicensed) with valid frequencies for the team's nation of origin. If you really wanted that module could do TCP/IP for home use of an AP or base band serial. After all that module had an Ethernet for field side. It could work with existing fields and FMS. The module was called the Turtle. Slow and steady wins the race and it is hardened.
If the teams wanted WiFi FIRST could let them provide hardware or restrict the hardware to choices they prefer.
Turtle did not advocate a specific frequency it would have allowed FIRST to move around.
This proposal was not accepted.
I think Asus is providing a WiFi USB radio for RoboRIO.
Upside - less involved than the D-Link AP and hopefully cheaper.
Downsides - still wraps baseband serial in TCP/IP giving up control and risks RoboRIO busy state holding up radio.
Unread 17-12-2013, 13:23
DonRotolo's Avatar
Back to humble
FRC #0832
More than a tad. Nonetheless: Different frequencies have different propagation characteristics. At 3.5 MHz you can communicate around the world with one watt of power, while at 400 MHz you can't go more than a hundred miles with 1500 watts*.
The higher in frequency you go, the more the radio waves behave like light. 2.4 GHz passes right through wood, plaster, etc with only a little attenuation. 5 GHz is affected much more. 10 GHz is even worse in that respect.
*There are some very specific exceptions, such as tropospheric ducting, but I'm discussing 'normal' propagation here.
Unread 17-12-2013, 19:37
seg9585's Avatar
seg9585 seg9585 is offline
AKA: Eric
FRC #4276 (Surf City Vikings)
seg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond repute
Like light? Radio waves are light.
Anyway, many of you are forgetting that FIRST is a worldwide activity, and just because the United States has permitted licensed usage of the 3.6Ghz band doesn't mean the rest of the world has. Would you really want our Brazilian, Israeli, Mexican, etc teams getting into trouble with their local regulators over FIRST hardware?
http://en.wikipedia.org/wiki/List_of_WLAN_channels
My FIRST legacy:
Team 204 Student 2001, 2002 (Voorhees, NJ)
Team 1493 College Mentor 2006 - 2008 (Troy, NY)
Team 2150 Intern/Professional Mentor 2007, 2009 (Palos Verdes)
Team 4123 Lead Engineering Mentor 2012 (Bellflower, CA)
Team 4276 Engineering Mentor 2012-2016 (Huntington Beach, CA)
