Go to Post Is FIRST making it too easy?... yes they are making it easier than years past. But I would also say that does that matter? If students are still inspired to pursue more advanced designs and eventually a career in the technology sector we still have met our ultimate goal. - MikeDubreuil [more]
Unread 17-12-2013, 16:45
sthreet's Avatar
sthreet sthreet is offline
AKA: scott threet
FRC #4692
Rookie Year: 2012
sthreet is an unknown quantity at this point
Difficulty running and imaging.
I'm having a little difficulty imaging the cRIO to java, I might have done it but I'm not sure. I couldn't find a tutorial, so I just tried things that might work, and got one that ended up taking half an hour of waiting before I had to shut the computer down.
I'm also not sure how to run the code once I have imaged the cRIO, I can't find Set as Main Project anywhere, and trying to run it gives an error in a different file that is something along the lines of "fork=true". The error says that compile failed.
