Thread Tools |
Rating:
Display Modes |
How to wire unrealistically well?
Hey all,
We're pretty fed up with how horrible our wiring has been in the past two years- simply not neat, not streamlined, not anything. We would really like some tips and pointers about how to wire extremely neatly and streamline our wiring, I'm looking for something along the lines of: https://www.dropbox.com/s/rqnwpjmhjk...%20chassis.jpg http://www.greybots.com/uploads/1/4/...84221_orig.jpg |
Re: How to wire unrealistically well?
Believe it or not, there aren't really many tips to do that. The main thing is time. Wiring takes lots of it, so make sure you have enough. Second, it helps to plan ahead where components and wires will go. Finally, use tons of zipties and fasteners.
One of the easiest ways to get neat and clean wiring with limited effort and experience would be to use wire ducts. A few well placed wire ducts on your electronics board can easily manage wiring with little extra work.
449 used this last year, and we would recommend it to all teams who don't necessarily have the resources to create 968/1538 style wiring. |
Secret: A metric ton of zip ties, zip tie mounts, and time.
Wire only stays so neat when it has a place to be, and zip ties are perfect for that. Bundle wire going to the same place (for example, PWMs from the DS to the motor controllers or power wires from the PDB to motor controllers) in a neat fashion, meaning line each wire with the same color facing each direction, and zip tie the wires together every few inches. Keep everything standard. Use the same zip tie colors, crimp connectors, and wire. It looks better. Actually, thinking about it, thats really it. Just set out to wire well and you will wire well. If it looks pretty, you are good. I actually don't have any pictures on hand of the wiring on our robot, but this was us a few nights before bag date last year. |
keep your eyes peel team 340 is going to be shooting a video about a cool 3d printed part that has helped a ton
We may make a video on our wiring process, gotta convince all the wire monkies to do it first though.
Our team color codes our wires so its easier to trace/ replace if need be.
- An aluminium bellypan is pretty much required for our style of wiring, but a polycarb base with holes drilled out for zipties can also be used. You'll probably end up with some accidental holes and it won't be very pretty, but it's a good start towards cleaner wiring that's easy to maintain. We used white polycarb for this in 2011. Clear might look cool. YMMV.
- Use lots of zipties. Properly trim them, place at regular intervals along wire runs, etc. - Use heat-shrink tubing over crimps and splices. - When laying out runs, give yourself a few extra inches of wire when you cut. Connectorize one end, lay it out, then cut the other end to length & connectorize. - Use zip cord (nonglossy looks better). - Give yourself enough wire for strain relief. - Color coding is, in our opinion, not required. Our philosophy is that the wiring should be clean enough to easily trace without any extra markings. Here are a couple of examples of our wiring 2012 2013 |
^Connor is just bragging with those pics
Totally love the wiring job. |
#10
I'm just wondering, but wouldn't that cRIO placement be illegal? Doesn't the cRIO ground itself? Is that a metal matrix under the electrical components.
If you're trying to clean up, why don't you just copy the team's wiring in the model, and tweak it so it fits your needs? An engineer steals one's idea and makes it better! |
#11
Something that hasn't been mentioned so far is time. You need to give your electrical time with the robot to get their job done properly. Unfortunately for us time is never on our side so a majority of our robots have been wired in a few meetings or on practice days.
Hey stuff happens! ![]() |
#14
Another thing we do is use nylon fasteners. We do this for a few reasons:
#15
Don't forget that copper is heavy. The weight of #12 or #14 wire is not insignificant.
All that neat, right angle turn wiring looks nice, but the hypotenuse of a triangle is shorter than the two sides. We had a panel with a number of victors one year and wired it all neat and tidy, with a loop so that the panel could be swung down to work on. We needed to lose some weight, though, and ended up cutting about half a pound out of it all without much trouble by re-routing many of the wires. Layout is important. If the flow from the battery to the main breaker to the PDB to the motor controllers is short, things will be much easier. |
