Go to Post FIRST is doing a great job, it's me who needs to do the hard work now. - Bomberofdoom [more]
Thread Tools Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
Unread 18-12-2013, 22:27
Joe Johnson Joe Johnson is online now
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Rookie Year: 1996
[Ri3D] Help BOOM DONE. Pop Rivets
Chief Delphi Community.
Pop Rivets. I love 'em. I hate 'em.
I use them some years. Others I shun them.
What's the consensus?
I bought a pneumatic pop rivet gun (Harbor Freight).
I am going with the larger rivets (#11 hole size).
Bengi Ambrogi (w/ team #131) swears by using epoxy in addition to pop rivets.
Artur Ostrowski (w/ team #469) swears by the "structural rivets" (e.g. McMaster 98778A511) rather than mambi pambi standard rivets (e.g. 97519A045).
I have had good success using "Very High Bond" double stick tape in conjunction pop rivets (e.g 76665A82) -- I use it not just as an added strength but as a fixture (stick 'em together, then drill, then rivet -- holds everything in place like a charm).
What do YOU have to say about Pop Rivets?
Tell all.
Dr. Joe
Joseph M. Johnson, Ph.D., P.E.
Mentor
Team #88, TJ2
Unread 18-12-2013, 22:45
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
Re: [Ri3D] Help BOOM DONE. Pop Rivets
Joe - we have been using them more and more. much quicker than nuts and bolts or tape or other means. Pretty easy to use, and easy to remove if you change your mind.
We use them in light load places, to attach polycarb to aluminum structure, etc.
You might want a few sizes (for material thicknesses) to be sure you get a tight connection.
I heard a rumor the guys from 1501 use a few rivets ...
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 18-12-2013, 22:55
Coach Norm Coach Norm is online now
Team 2468 Coach/Adviser
AKA: Norman Morgan
FRC #2468 (Team Appreciate)
Team Role: Teacher
Coach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond repute
We used rivets on sheet metal for the first time last year since it was our first sheet metal frame.
We also used rivets to attach our tread to our HDPE flywheel in our shooter this past year. We did got with stainless steel on this application though.
We used Clecos http://www.mcmaster.com/#cleco-style-clamps/=pvbbwvto help hold the sheetnmetal in place while we were riveting. We also use these for attaching our bumpers onto the chassis during the tournaments.
We have several pairs of Clecos pliers http://www.mcmaster.com/#cleco-style-clamps/=pvbcww
FRC 2468 Team Lead 2008 - Present
Win The Day!
Unread 18-12-2013, 23:41
Paul Copioli's Avatar Unsung FIRST Hero Woodie Flowers Award
Paul Copioli Paul Copioli is offline
President, VEX Robotics, Inc.
FRC #3310 (Black Hawk Robotics)
Rookie Year: 2000
Paul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond repute
Joe,
Pop rivets since 2005 and never gone back. No glue, no double sided tape (although great idea for holding before drilling).
We use the regular aluminum mandrel 5/32 rivets almost everywhere. We also have steel mandrel 3/16 and 1/4" for super high load or in areas where I can only get a few rivets.
The key to rivets is to get the right hole size and don't overdrill. Next is rivets do not like tension, only shear. If you can't keep them primarily in shear or compression then use 1/4 or bolts.
Out robots have been 90% 5/32 rivets for many years now.
In full disclosure I am the President of VEX Robotics, a division of Innovation First International.
Unread 18-12-2013, 23:51
MichaelBick MichaelBick is offline
FRC #1836 (MilkenKnights)
Rookie Year: 2010
MichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant future
You should be able to use aluminum body, aluminum mandrel rivets. We used 3/16" rivets like this for everything last year. We also purchased the high strength rivets, but never had to use them.
Team 1836 - The Milken Knights
2013 LA Regional Champions with 1717 and 973
2012 LA Regional Finalists with 294 and 973
To follow Team 1836 on Facebook, go to http://www.facebook.com/MilkenKnights
To go to our website, go to http://milkenknights.com/index.html
Unread 19-12-2013, 07:15
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Rookie Year: 2000
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
FRC Team 1501 T.H.R.U.S..T. have been using rivets since we started in 2005.
To date we have used over 10,000, 1/8" rivets
All but two robots have been fully Monocoqued robots.
We have 4 Cleco pliers, 400+ Clecoes (temp rivet), numerous rivet guns and 1 pneumatic rivet gun.
Generally we use .040 sheet aluminum. At stress point (bearing blocks) we rivet in 1/8" aluminum finger plates. We use different lengths of rivets depending on how many layers of aluminum we are going through.
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
Unread 19-12-2013, 16:13
BrendanRadabaug's Avatar
BrendanRadabaug BrendanRadabaug is offline
FRC #1902 (Exploding Bacon)
BrendanRadabaug is a splendid one to beholdBrendanRadabaug is a splendid one to beholdBrendanRadabaug is a splendid one to beholdBrendanRadabaug is a splendid one to beholdBrendanRadabaug is a splendid one to beholdBrendanRadabaug is a splendid one to behold
As posted above about the rivets don't like tension, just shear. But we will use them everywhere and then go back after some testing and see which ones need bolts later. Just a couple bolts for structure and then rivets... rivets everywhere.
ID:	15588  Click image for larger version
Bacon
Unread 20-12-2013, 14:27
AKA: Warthog
Rookie Year: 2000
You guys are amateurs
http://www.chiefdelphi.com/media/photos/37470
2899 rivets
Unread 20-12-2013, 15:12
DonRotolo's Avatar
Back to humble
FRC #0832
In my job at an automotive company, rivets plus adhesive are used for structural collision repairs. A glued and steel-riveted joint is stronger than a bolted joint.
We use them mostly for lower-stress joints like polycarb to aluminum.
Unread 20-12-2013, 16:15
Bryce Paputa's Avatar
Bryce Paputa Bryce Paputa is offline
FF TSL: Frog Farce
FRC #0503 (Frog Force)
Bryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond repute
What adhesive is used? Just a normal two part epoxy? We use steel 1/8th rivets to hold our sheet metal chassis together.
Unread 22-12-2013, 22:01
Kevin Sevcik's Avatar
Kevin Sevcik Kevin Sevcik is online now
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
We use a lot of the aluminum 3/16" structural rivets to build superstructure from 1/16" square tube and bent plate. Aluminum because drilling out steel rivets is a royal pain, and we never need that strength anyways. Structural because they seem to have better pull-up and hole filling, and I can never get everyone to properly fit and drill every joint. In addition to the above advice, we've found that fit-up is important. If your fitup is bad and you have a gap after riveting, then the rivet and its hole is the only thing taking up the load. I'd imagine your tape + rivet thing mitigates this slightly with the tape taking some of the shear load.
