Go to Post Real projects have good and bad aspects, problems that must be dealt with, and lots of things that dont make any sense from your side of the fence. - KenWittlief [more]
Go Back   Chief Delphi > Old Forum Archives > 2001
Unread 23-06-2002, 23:45
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
archiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond repute
Pipe Diameter
Posted by CArobot at 1/27/2001 8:19 PM EST
Other on team #619, CArobot, from Charlottesville Albemarle.
Does any one know if they are refering to 1/2" - 1 1/2" inside diameter or outside diameter for the schedule 40 PVC pipe mentioned on update #2? All of the dimensions given for the playing field were inside but we don't want to assume.
Thanks
CA Robot
This message was archived from an earlier forum system. Some information may have been left out. Start new discussion in the current forums, and refer back to these threads when necessary.
[IMG] code is Off
Machining/Engineering Question re: Pitch Diameter 157#1Driver Technical Discussion 4 08-01-2003 10:57
How can i mount a pneumatic piston to a pvc pipe!?!?! archiver 2001 4 24-06-2002 01:11
the size of the pipe on the goals archiver 2001 2 24-06-2002 00:07
Goal pipe spacing too narrow to push balls through??? archiver 2001 6 23-06-2002 22:53
Units for Pipe Measurements l1jmx Rules/Strategy 4 10-01-2002 20:33
