Go to Post I found the best way to slice through pit crowds is to carry a clipboard and look like you know where you are going. People just seem to slide out of your way. :) - Ian Curtis [more]
Unread 19-12-2013, 21:53
T^2 T^2 is offline
Rookie Year: 2011
T^2 has a reputation beyond reputeT^2 has a reputation beyond reputeT^2 has a reputation beyond reputeT^2 has a reputation beyond reputeT^2 has a reputation beyond reputeT^2 has a reputation beyond reputeT^2 has a reputation beyond reputeT^2 has a reputation beyond reputeT^2 has a reputation beyond reputeT^2 has a reputation beyond reputeT^2 has a reputation beyond repute
3D Printing A Wheel
1678 is doing a test run of a full-size 3D-printed wheel; you can see it at http://www.twitch.tv/frc1678. We're using the MakerBot Replicator 2 we got through Donors Choose.
We tried this last night, but the filament snapped, and somehow part of it had gotten wrapped around the drive gear. In addition, more filament was clogged up in the nozzle head. Took me about 2 hours to fix. I hope this one goes better.
Unread 19-12-2013, 22:04
coalhot's Avatar
coalhot coalhot is offline
Assistant to the regional manager
AKA: Phil
FRC #4454 (Artisan Rockets)
Rookie Year: 2007
coalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant future
Send a message via AIM to coalhot
Re: 3D Printing A Wheel
PLA wheel? Interesting. Also, how large is the wheel? Looks like a 4"
Current home, 4454 (Glowa's ghetto Philly FRC team). Check us out!
My posts represent my personal views only, and do not represent the views of my team, its school, sponsors, or FIRST.
Unread 19-12-2013, 22:07
avanboekel's Avatar
avanboekel avanboekel is offline
AKA: Adam Van Boekel
FRC #5934 (Gear it Forward, Crowbotics)
Rookie Year: 2010
avanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant future
What % infill are you using?
2338 Gear It Forward | Student 2010-2013 | Mentor 2014-Present | oswegofirst.org
2013 Wisconsin Regional Winner (1732, 111, 2338)
2013 Midwest Regional Dean's List Finalist
2015 Midwest Regional Chairman's Award Winner
2015 Archimedes Subdivision Winner (1023, 2338, 3996, 1089)
2016 Midwest Regional Chairman's Award Winner
4096 CTRL-Z | Mentor 2014 | team4096.org
5934 Crowbotics | Mentor 2016-Present | crowbotics.org
Unread 19-12-2013, 22:10
IVAN IVAN is offline
FRC #2429
IVAN is on a distinguished road
2429 just got a replicator 2 as well make sure to have your filament cable loose and unconstrained. also have you changed any of the heating settings?
Unread 19-12-2013, 22:15
dtengineering's Avatar
dtengineering dtengineering is offline
Teaching Teachers to Teach Tech
AKA: Jason Brett
no team (British Columbia FRC teams)
dtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond repute
I saw the head move for about five seconds and then an ad popped up... turned it off at that point.
Jason
Unread 19-12-2013, 22:20
T^2 T^2 is offline
Rookie Year: 2011
Yes, yes it is, and yes.
100%.
That may have been the problem. We'd printed stuff before, but I switched colors for this piece. I tried a few heat settings, but the default 230C seems to stick best.
Jason
Sorry, blame twitch. Try using Adblock?
Unread 19-12-2013, 22:28
DampRobot's Avatar
DampRobot DampRobot is offline
Physics Major
AKA: Roger Romani
FRC #0100 (The Wildhats) and FRC#971 (Spartan Robotics)
Rookie Year: 2010
DampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond repute
I'm interested that you decided to 3d print wheels at all. Is this just a test, to see what kind of quality you get? If you're seriously considering using 3d printed wheels next year, could you talk a bit about the thought that went into the decision?
The mind is not a vessel to be filled, but a fire to be lighted.
-Plutarch
Unread 19-12-2013, 22:37
T^2 T^2 is offline
Rookie Year: 2011
Yes, it's a test. We think it's quite possible (based off the advice of one of our mentors, who has built many 3D printers) that an extruded PLA wheel will be strong enough to endure the rigors of FRC. Our hope is to be able to cut down on manpower and machining time. We use 2-inch wide wheels with 971's tread attachment style, which take our sponsors several weeks to machine out of aluminum. In the build season, this is unacceptable, so we're trying to print them instead (using a modified design, obviously). A 1/4 scale model held my weight without cracking. If you want, I can post renders of both designs.
Unread 19-12-2013, 22:39
FRC #2429
what resolution did you use fine,low,standard ? also have you tried putting down the big blue piece of tape that comes with it?
Unread 19-12-2013, 22:53
T^2 T^2 is offline
Rookie Year: 2011
High resolution, using tape.
Unread 19-12-2013, 22:58
Calvin Hartley's Avatar
Calvin Hartley Calvin Hartley is offline
FRC #4967 (That ONE Team)
Rookie Year: 2012
Calvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud of
When will this model (likely) be done? Will you be making more to test an actual drive train, or just the one wheel? Either way, I am interested in seeing results.
FRC 4967 That ONE Team 2013-Present, Founder, CAD/Everything Mentor
FRC 2771 Code Red Robotics 2012 and 2013 Drive Team, 2014 Drive Coach, Executive Leadership
FLL Team member 2005-2010, LEGO In Paradise,
FLL Mentor 2009-Present Paradise Teams (nine teams)
FLL Coach 2014-Present - The Lightning Bugs
Gracious Professionalism isn't a set of rules to follow, it's an attitude.
MichaelBick MichaelBick is offline
FRC #1836 (MilkenKnights)
Rookie Year: 2010
MichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant future
What is your problem with Vex traction wheels, other than the attatchment method?
Team 1836 - The Milken Knights
2013 LA Regional Champions with 1717 and 973
2012 LA Regional Finalists with 294 and 973
To follow Team 1836 on Facebook, go to http://www.facebook.com/MilkenKnights
To go to our website, go to http://milkenknights.com/index.html
Unread 19-12-2013, 23:11
FRC #2429
are you printing the wheel solid ?
Unread 19-12-2013, 23:14
T^2 T^2 is offline
Rookie Year: 2011
Tomorrow evening, and we'll test this one before deciding if we want to make more.
The attachment method.
Yes.
  #15   Spotlight this post!
Unread 19-12-2013, 23:33
FRC #2429
o.o why not polyurethane casting and using hollowed version out of wheel to use as a negative because printing four or six of those wheels (at least) is going to be expensive
my math has it at 5 cents per gram if your using makerbot pla and 1.5 cents using an amazon competitor
