Go to Post ...there is just something that I like about the smell of fresh engine oil... - Matt Attallah [more]
Unread 22-12-2013, 17:00
Maximillian's Avatar
Maximillian Maximillian is offline
AKA: Max Westwater
FRC #5254 (HYPE)
Rookie Year: 2014
Maximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant future
Help deploying code to the robot
I am trying to deploy our code to the robot. When I try to click run as startup it comes up with an error message that says it is unable to resolve from current dialog.
Unread 22-12-2013, 17:17
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Help deploying code to the robot
Select "Build" before using "Run as Startup"
On the same menu.
Unread 22-12-2013, 19:39
AKA: Max Westwater
FRC #5254 (HYPE)
Rookie Year: 2014
I did do that. I still get the same error
Unread 22-12-2013, 20:50
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
I assume there weren't any build errors?
I saw this type of behavior once where a LabVIEW project had been copied from a different computer that had a different directory structure, and had been partially modified. It was building in one location and trying to download in another. Could something like that have happened?
Unread 22-12-2013, 22:45
Just Itinerant
It can also happen when the user account doesn't have write privileges for all the LabVIEW data directories that it should. Most commonly encountered on school issued laptops. Possibly, running LabVIEW "as administrator" might help that case.
As a test case you can try creating a default project from scratch, no edits or changes, and try building and run as startup with that.
Unread 23-12-2013, 09:38
AKA: Max Westwater
FRC #5254 (HYPE)
Rookie Year: 2014
In fact I did actually copy this from another computer. Thanks. I will try and fix this now that I know this is probably the problem.
