Thread Tools |
Rating:
Display Modes |
Victor Blinking Light Question
We've got a question about the indicator light on the victor. We've only seen this on an older 883 (rev F), and we can't find an explanation in the manual for the newer ones. If you power on the controller while pushing down the calibration button, the indicator light flashes green for about 5 seconds. Sometimes (I'd guess less than half the time) it's red instead. What is it telling us?
Also, when did they stop making the 883s? Last edited by magnets : 31-12-2013 at 18:59. Reason: added another question |
Re: Victor Blinking Light Question
I am aware of the calibration light, but I'm not calibrating the victor. There's no PWM signal going in, and it still flashes green, and you can't calibrate without a pwm signal.
I would start by removing anything that is connected to the output, disconnect the PWM, double check input wiring for 12 volts and apply power.
If it looks normal then try a cal without PWM and then with PWM. The results of the above tests will be very helpful to finding out what is wrong. |
The 888 is the same architecture as the 883. The 888 has new firmware which provides a more linear response curve, otherwise they are essentially the same units.
Because the response curves are different, I would suggest not mixing 883s and 888s on the same multi-motor mechanism. |
Did you mean 884? The 883 is 24v.
Not Always
Here's all the victors Pre2003(?) red text 883's -12V(what I have) Post2003(?) blue text 883's - 24V 2004(?)-200?- red text 884's (incorrectly disallowed at some competitions) 200?-2011 - blue text 884's 2012 green text 884's 2013 green text 888's Last edited by apples000 : 01-01-2014 at 13:35. Reason: Added victor history |
So, is the firmware the only difference between the Pre2003(?) red text 883 and the 2013 green text 888?? I would think some non-trivial hardware changes would have been made in the intervening 10 years.
From the 2000 robot manual: Quote:
#10
From a 2003 883 Manual...
Resetting Calibration to FIRST Pre-calibration: 1. Power OFF the speed controller. 2. Press and hold the Cal button. 3. While continuing to hold the Cal button, Power ON the speed controller. 4. A flashing GREEN indicator denotes calibration is reset. Release the Cal button. I will make an assumption from this part that flashing red indicates a failure to return to factory calibration. This became a non-issue when it was realized that all joysticks are not created equal. Calibration to the joysticks used was highly recommended after that. I believe the 884 became available in the 2003 season(after kickoff). By 2004, 883s were not allowed on the robot per the Inspection Checklist. The change from red to blue labels on both the 883 and the Spike gave a lot of confusion during that transition. There was a period of a couple of weeks where red 883s were not allowed even though some had been provided in the KOP that year. There is significant hardware changes in the 888, the FETs, for one, are different. |
#11
Thanks! That explains why we kept having to recalibrate all the time, we must have been resetting the calibration to watch the blinking lights. I've also noticed that the red flashing lights happen if you try to power on the victor with a PWM signal going in while holding the button down. It seems like it won't reset this way.
