Go to Post Team 1114 does not design or build ROBOTS. They build AWESOME. - DonRotolo [more]
Unread 02-01-2014, 10:51
NorviewsVeteran's Avatar
NorviewsVeteran NorviewsVeteran is offline
Precision Driver Extraordinaire
AKA: Richard Raitt
FRC #1793 (Pilots)
NorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond repute
My robot, Hormes
After being involved in the FRC since 2006, I finally got the wherewithal to make a bot of my very own. Having cut my teeth on robots that weighed more than I did, I didn't want something that you watch dance around on the coffee table, I wanted something that has to go outside to play.
I built my Christmas present this year, and its name is Hormes.
I went into some detail here: http://letsmakerobots.com/node/39667, but here's the rundown:
-over 50 lbs
-all steel frame
-10" tubed tires
-CIMple boxes with 1 CIM per side
-Talon motor controllers
-Arduino with USB host shield
-driven with an XBox controller
It's far from where I'd call it done. Since that picture was taken I've gotten a good strap to hold the battery in place, added temporary headlights (LED flashlights ziptied to the front corners) and added a strap to replace the zipties holding the control box down. The plan is to have all the electronics inside the red toolbox and have it on shock-damping mounts, mostly to keep the breakers from popping after quick drops, get a bigger battery, and have remotely switched headlights.
______
I was in Scouts but I wanted out by the third meeting. I was in TSA, but I quit after a couple of weeks. I don't go camping with the SCA anymore. I was in taekwondo but I had to leave because I got sick.
I joined FIRST and stuck with it. It was nice enough to return the favor.
