Thread Tools |
Rating:
Display Modes |
4265's Off Season Octanum
Team 4265 The Secret City Wildbots is proud to present our off-season drive train that we are calling Dragonfly. It is a custom machined octanum drive using Vex Pro 6" mecanums, and 4"x2" Colsons, with 4 vex pro ball shifters.
Specs include: 21ft/s High gear. 10ft/s Low gear. 4 Cims + 4 Mini Cims = 6.66 Cims worth of power. In low gear it puts out 94 foot pounds of torque. fully loaded it weighs in at about 80lbs. According to FIRST Regulation, we are happy, and proud to release our design include CAD and Software under the GPL for any and all to use. https://www.dropbox.com/s/63jokadpwthhmzc/Dragonfly.zip Release Video: https://www.youtube.com/watch?v=O_vv...Q&noredirect=1 Pictures: https://drive.google.com/file/d/0B9o...it?usp=sharing https://drive.google.com/file/d/0B9o...it?usp=sharing https://drive.google.com/file/d/0B9o...it?usp=sharing -Tag Last edited by tag_groff : 02-01-2014 at 11:48. |
Re: 4265's Off Season Octanum
As cool as it is, 80 pounds? That only leaves you with 40 pounds for all of your manipulators. I don't see the point in any drive train being that heavy (at least you'll have a low center of gravity). I would love to see this used in a competition but you're going to have a tough time with that weight limit.
I trust they know what they're doing ![]() |
This is really, really well done, good job. All of these octocanums popping up is really making me rethink my dislike of mecanum wheels.
Just for reference, if this drive were only running (4) CIM Motors, each through their own Vexpro Single Speed, it'd be ~16lbs lighter, and that's not counting all of the other components that could be removed when the motor count drops from (8) to (4). (Speed controllers, wiring, etc) |
That's a pretty serious drive base! I guess the offseason is the perfect time to max out a drive train for a team that has that itch.
You've listed just two speeds. Is the gearing from the 6" to 4" wheels setup to keep the two types of wheels at the same speed? If not, then you really have a four speed drive. In my mind, one of the benefits of octocanum is that you don't need shifters. It's already providing the benefits of a two speed if you gear the Colson wheels slower than the mecanums. |
We also hinged on the traction wheels like you did, for strength, but put the traction wheels at the extreme front and rear for better stance when pushing. With the 8 motors and gear reduction, we had no problem turning on carpeting, even with conveyor traction belting on wheels. Very nice Cad work and machining. Is the cylinder mount a cast part or machined? Last edited by Dad1279 : 02-01-2014 at 14:41. |
You might want to export it as a .step instead of providing the raw file. STEP files tend to import better into Creo/ProE and Inventor, as they aren't a proprietary format.
Very cool modelling though. I like the combination of sheet metal (?) and tube parts. Last edited by cadandcookies : 02-01-2014 at 15:41. |
#12
This is pretty cool. One thing you need to look at on saturday is if the game calls for a extra high speed/high performance drivetrain. I can only name a few games where it would be worth such a high performance drive (2008 comes to mind). If not I would try to get it to around 40-50 lbs with electronics so you have weight for your scoring system. Also does anyone have any experience with that many motors on the drive since I would think you would pop your main breaker pretty quick.
Another random question, was that a DJI Phantom in the robot video? |
#13
what regulations are you talking about in terms of your CAD and software? I'm Curious.
#15
Very cool.
Have you considered using a single air cylinder on each side with a linkage to move the drive mechanisms up and down? If properly designed you could potentially use a single smaller, lighter, cylinder on each side. |
