Go to Post I am a 2-3 year competition veteran, and a new member at chief delphi, and everyone here seems to be as nice as they are at the competition. Very gracious, you might say. - Ian S. [more]
Go Back   Chief Delphi > Technical > CAD
Unread 02-01-2014, 23:36
wasayanwer97's Avatar
wasayanwer97 wasayanwer97 is offline
Take from the best, invent the rest
AKA: Wasay Anwer
FRC #0668 (The Apes of Wrath)
Team Role: Coach
Rookie Year: 2011
wasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant future
Automatic Shifter Plates
Hi CD.
This is at least the start of a project I'm working on.
It's an automated design system for a 2-Speed, 2-CIM shifter.
I wanted to put it out here for people to play around with/test if they felt like it.
Currently, the system works as follows:
  • User inputs gears into the JVN calculator. (It's called Linked_Parameters)
  • Once desired speeds are achieved, the user can then save and close the calculator.
  • The CAD will then read gear sizes from the calculator and create a plate.
  • Once a plate is made, a reference assembly with two of the plates and generated mockups of the gears is updated to match.
There are some limitations though:
  • It only does holes for the Bearings/Gears, CIMS, and 4 corner holes for assembly. Holes for face mounting or attaching a cylinder will have to be added by the user.
  • It will try to pocket, but it will not do fillets (rounding the edges). That will need to be done manually.
  • Right now, it makes all the bearing holes .875". I haven't made separate parameters for each bearing yet. One or two holes/extrusions would get you the size you need if it's different.
  • It uses Inventor 2014
  • It's currently made to specifically do a 2-Speed, 3-Stage Gearbox. I'll upload versions for different type of gearboxes later. Though smart manipulation of the JVN calculator would probably allow you to do other things.
This was just a fun experiment for me before build season. The intention was to accelerate the creation of a gearbox plate so I would have something basic to build off of.
I probably forgot some stuff, so I apologize in advance.
Comments and questions are greatly appreciated.
Download link is below:
https://www.dropbox.com/s/ry6580nspv...ay_Autobox.zip
Also attached is a picture of one of the plates it made. No manual work was done except entering gear sizes and then a quick fillet.
"Coming together is a beginning; keeping together is progress; working together is success."- Henry Ford
FRC Team 668: The Apes of Wrath
Pioneer High School, San Jose CA
http://www.theapesofwrath.org
Talking to other FIRSTers is great. Add me on Facebook!
My Page
