Go to Post Either way, FIRST works. You just have to keep the big picture in mind. - Lux [more]
Unread 03-01-2014, 18:15
ttldomination's Avatar
ttldomination ttldomination is offline
Sunny
Rookie Year: 2007
ttldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond repute
Centering and Driving Flat Belts
For a long time, I've seen teams use flat belts to considerable success (341 in 2012 and 2363 last year), and in an effort to pick as much as I can before kickoff, I was wondering how teams go about driving flat belts?
I know that you need a simple crown to keep the belts centered (so you can run them sasn pulleys). Any tips on how to create these crowns/what works super well? Is there a specific type of tape that the flat belts work really well with?
- Sunny G.
1648: 2013-2014
5283: 2015
Unread 03-01-2014, 20:14
jimwick's Avatar
jimwick jimwick is offline
jim wick
FRC #0885 (the Green Team)
jimwick is a glorious beacon of lightjimwick is a glorious beacon of lightjimwick is a glorious beacon of lightjimwick is a glorious beacon of lightjimwick is a glorious beacon of light
Re: Centering and Driving Flat Belts
Last year we were one of the few teams at the Granite State Regional that could pick up frisbees reliably from the floor. We used a flat belt system.
We found the necessary rollers at the local True Value hardware store! They were in the section of the store that had furniture rollers and glides. They had a convex profile. They were mounted in sort of a foot, but we just drilled that out and used the rollers. They worked just fine with a 1" urethane flat belt.
Unread 03-01-2014, 20:33
MetalJacket's Avatar
MetalJacket MetalJacket is offline
Has read the 2014 manual
AKA: Jesse Gibson
FRC #2068 (The Metal Jackets)
Team Role: CAD
Rookie Year: 2011
MetalJacket has a spectacular aura aboutMetalJacket has a spectacular aura aboutMetalJacket has a spectacular aura about
Could you post a picture of the part, preferably on the robot but doesn't have to be.
Team Role = !artTeam
2011 - Logomotion
- Virginia Regional : Tournament Semi-Finalist, Gracious Professionalism Award
2012 - Rebound Rumble
- Chesapeake Regional : Tournament Finalist, Gracious Professionalism Award
2013 - Ultimate Ascent
- Virginia Regional : Gracious Professionalism Award
Unread 03-01-2014, 20:58
the.miler's Avatar
the.miler the.miler is offline
taking a break
AKA: Miles Chan
FRC #0846 (Funky Monkeys)
Rookie Year: 2011
the.miler is a glorious beacon of lightthe.miler is a glorious beacon of lightthe.miler is a glorious beacon of lightthe.miler is a glorious beacon of lightthe.miler is a glorious beacon of light
Flat belts worked really well for us on our collector: https://www.youtube.com/watch?v=yCBjZ0s0kAo
We used McMaster flat urethane belt with this part number: 6075K14
To make sure the belts tracked well, we wrapped crowns of tape over the 1/2" shaft (which raised the diameter of the "pulley" to the minimum diam. specified for the belt product). We usually wrapped a few layers with the upper layers thinner in width to create a gradually crowned shape. In our experience, the belts have run great as long as the crowns on each shaft are properly aligned to each other.
I will edit with the exact name of the tape product we used if I can find it. It was in the electrical tape section, but it is not smooth on the outside as most electrical tape is. Instead, it was black and fairly sticky on both sides, which made it pretty good for our purposes. We acquired it from OSH, a local hardware store chain, but I cannot find the product on their website.
Hope this helps.
Member 846 The Funky Monkeys 2010-2014
Team 846 Highlights 2014
lynbrookrobotics.com
becauserobots.org
Unread 03-01-2014, 21:04
- Sunny G.
I think the tape used was 3M mastic tape. That stuff is like magic. Feel free to PM Dustin or Jared to confirm though.
Unread 03-01-2014, 21:11
Jared Russell's Avatar
Jared Russell Jared Russell is offline
Taking a year (mostly) off
FRC #0254 (The Cheesy Poofs), FRC #0341 (Miss Daisy)
Jared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond repute
We used plain old electrical tape.
Unread 03-01-2014, 21:35
Anthony4004's Avatar
Anthony4004 Anthony4004 is offline
Anthony4004
FRC #4004 (MARS Rovers)
Anthony4004 is an unknown quantity at this point
Would it be possible for someone to posts a few pictures to show how it attaches with the rollers. My team has wanted to try this before, and this would be a nice help.
Unread 03-01-2014, 22:24
Decent picture here: http://www.flickr.com/photos/team341...57628843002609
You can see there really isn't much to it. Wrap the tape while spinning the roller, and wrap more densely in the middle. It doesn't take much to keep the belt centered.
Unread 03-01-2014, 22:39
Anthony4004
Thanks!
Unread 03-01-2014, 22:57
ToddF's Avatar
ToddF ToddF is online now
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
Rookie Year: 2011
ToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond repute
In the various incarnations of our arms and handlers we drove the flat belts in a couple different ways.
1) using rollers made from 1" OD aluminum tube. Where the belts were located, we wrapped the rollers with 1/4" wide strips of 1/16" thick bump-on adhesive backed urethane from McMaster.
2) using 1" wide crowned rollers that were 3D printed. STEP files for these parts can be found on the CAD models found in this thread. We made rollers for both 1/2" hex shaft and 3/8" round keyed shaft.
Todd F.
mentor, FIRST team 2363, Triple Helix
Photo gallery
video channel
Triple Helix mobile
