Thread Tools |
Rating:
Display Modes |
2014 Rules Changes
Some quick ones I noticed are more legal batteries and new vertical projection rules.
A match is now two and a half minutes. Last edited by cgmv123 : 04-01-2014 at 11:17. |
Re: 2014 Rules Changes
Autonomous is only ten seconds.
Championships has 3 selection rounds, 1-8, 8-1, 1-8, 4th team doesn't have to play in any round.
Maybe a new rule??
Only 10 second? Wow.
Instead of FIRST decreasing autonomous mode time, they should be increasing that time. Its more of challenge for teams to accomplish. FIRST should keep Autonomous at 15 second, though in my opinion it should be 30 seconds. That way a team is forced to do something good with their robot or else they will be missing out on a lot of points. |
There is no end game this year, although I don't know when the last time this happened was.
(End game being defined as the last twenty seconds where a robot hangs, positions itself, fires a mini robot, scores extra points using special objects like super moon rocks or colored frisbees, placing track balls on overpass, etc) |
Can we use other alliances balls? What about entering another bot's perimeter for an assist, if it is on our alliance?
#10
For the other one, there is no rule specifically against it. However, you only get 20" outside your own perimeter to work with, per R3-B. |
#11
I believe that this is new:
I saw that too. Make your bumpers robust. If they go out of the bumper zone, you get DISABLED!
#13
in regards to the horizontal extensions. you can go out up to 20in in any direction correct? But does that limit you to one <20in extension at a time in the 6in cylinder? Or can you have more than one as long as they aren't 20in?
#14
Vertically, any extending parts going higher than 5 feet can only be extended in the Goalie Zone and must fit within a 6" vertical cylinder. Horizontally, you can extend 20 inches normal to the edge of any frame perimeter member. Height doesn't matter as long as it's under 5 feet. I have just read the rules but I do not remember anything limiting how many extensions are out at one time. |
#15
The six-inch cylinder rule only applies to vertical extensions.
