Go to Post Little kids playing soccer....or a typical Lunacy match. Ah, memories. :cool: - Travis Hoffman [more]
Unread 04-01-2014, 12:23
TheDrillKeeper TheDrillKeeper is offline
AKA: Josh Rodriguez
FRC #2903 (NeoBots)
Rookie Year: 2010
TheDrillKeeper is an unknown quantity at this point
Assist System explained
Hey Chief Delphi forums! I was a little confused by all the different plays and how exactly the assists are counted, so I decided to try and figure out for myself a set of rules for the assist system.
As said in the video detailing the assist plays, the system will count assists/possessions in the way that gives the play the most points. A robot is given an assist point when it is able to be assigned its own unique zone with no other robots. In order to do this, the system will find a robot/robots that has its own unique zone and nullify the other possessions by that robot in order to give other robots their own unique zone.
In addition, balls from the autonomous period cannot gain assist points, even during teleop. This is because assists are scored during a cycle, and the balls from autonomous are not part of a cycle due to not starting on the pedestal. Try to score them during autonomous so you aren't occupied with a dead ball during teleop. (thanks MasterEric)
Originally Posted by Siri View Post
This seems to match exactly with the manual's "ASSISTS are earned when a unique ALLIANCE ROBOT POSSESSES the ALLIANCE’S BALL in a unique ZONE (i.e. red, white, or blue ZONE) during a CYCLE." My conclusion from this quote is that the Rule of Thumb is: count the number of unique robot-zone pairs. That's the number of assists.
Last edited by TheDrillKeeper : 04-01-2014 at 14:24. Reason: added extra information about assists with autonomous balls
Unread 04-01-2014, 13:46
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
no team (Refs & RIs)
Team Role: Coach
Rookie Year: 2007
Siri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond repute
Send a message via ICQ to Siri
Re: Assist System explained
Unread 04-01-2014, 13:51
AKA: Josh Rodriguez
FRC #2903 (NeoBots)
Rookie Year: 2010
Thank you! This really helps clarify the rule system. The main thing I was confused about was how a robot could get an assist point when other robots also had a possession in that zone.
Unread 04-01-2014, 14:14
MasterEric's Avatar
MasterEric MasterEric is offline
Bacon. 'nuff said.
AKA: Eric Myllyoja (E2)
FRC #2137 (Oxford Robocats)
Rookie Year: 2013
MasterEric is an unknown quantity at this point
One thing you should make note of in your post:
As mentioned in the post Autonomous Assist, since the balls that the bots were given during auto were never on the pedestal, they never completed a full cycle. Thus:
a) You cannot score assist points with autonomous balls.
b) You should try to score those non-assistible autonomous balls during autonomous so you can spend as much time during teleop as possible getting assists.
Unread 04-01-2014, 14:25
AKA: Josh Rodriguez
FRC #2903 (NeoBots)
Rookie Year: 2010
Done! Thank you very much.
Unread 04-01-2014, 15:58
jnelly's Avatar
jnelly jnelly is offline
FRC #2472 (Centurions)
Team Role: Parent
Rookie Year: 2010
jnelly can only hope to improve
I'm just commenting to come back
Sleep, Lift, Muscle Milk, Repeat...
"The only bad workout is the one that didn't happen!"
-Jesse "the body" Ventura
Yeah... I lift
Unread 04-01-2014, 18:25
Bob Steele's Avatar
Bob Steele Bob Steele is offline
Professional Steamacrit Hunter
AKA: Bob Steele
FRC #1983 (Skunk Works Robotics)
Team Role: Coach
Bob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond repute
The game should have been called Aerial "Possession"
They are using the term assist in a new way and not like it is used in sports
It is best to think of possession rather than assist.
For a team to get one assist one team has to have possession of the ball in one of the zones...
For two assists, 2 teams need to have had possession in two separate zones
For three assists 3 teams need to have had possessions in three separate zones.
It is pretty simple if you look at it this way...
One team can only get credit for a single possession and you have to have separate teams possess the ball in separate zones..
The assisting that will be done will be by robots that help other alliance robots to possess the ball in a zone that does not have an alliance robot possessing the ball already.
I think it will be played like this:
ball starts in end zone... hopefully a robot possesses it there...
it moves forward either by being carried or not... the ball is passed to another robot in either of the other two zones... and now two robots have had possession in two zones... now the only thing left to do is to recognize which robot has not possessed the ball and what zone needs that possession for the bonus... then the ball is scored...bam and you get 31 or 40 points..
I believe the alliance will rely on the monitor to see when the referees have indicated possession and then go back and fill in to get the bonuses...if necessary...the indication of possession should be real time but you must not rely on your OWN idea of what possession is but rather when the referee has seen it and recorded it.
If all three teams possess in all three zones you will get the big bonus... if a single separate team possesses in each of the zones you get the big bonus...
I think the monitor will have to be watched closely to determine when to go in for a score.
It is really nice that the GDC thought to put this monitor in a place where the alliance can really use it...
Raisbeck Aviation High School TEAM 1983 - Seattle, Washington
Las Vegas 07 WINNER w/ 1425/254...Seattle 08 WINNER w/ 2046/949.. Oregon 09 WINNER w/1318/2635..SEA 10 RCA ..Spokane 12 WINNER w/2122/4082 and RCA...Central Wa 13 WINNER w/1425/753..Seattle 13 WINNER w/948/492 & RCA ..Spokane 13 WINNER w/2471/4125.. Spokane 14 - DCA --Auburn 14 - WINNER w/1318/4960..District CMP 14 WINNER w/1318/2907, District CMA.. CMP 14 Newton Finalist w 971/341/3147 ... Auburn Mountainview 15 WINNER w/1318/3049 - Mt Vernon 15 WINNER w/1318/4654 - Philomath 15 WINNER w/955/847 -District CMP 15 WINNER w/955/2930 & District CMA -CMP Newton -Industrial Design Award
Unread 04-01-2014, 22:26
Jakenan Jakenan is offline
AKA: Jacob Rojas
FRC #0457 (Grease Monkeys)
Jakenan is an unknown quantity at this point
Ive come to the same conclusion, and agree that assist would be better explained as possession. I believe the confusion with my team was with the video explanation (I wasnt watching, rather looking at the rules i had just decrypted). I hope this can be fully explained in the Q and A.
#FRC457
Unread 05-01-2014, 10:39
cbudrecki's Avatar
cbudrecki cbudrecki is offline
AKA: Carl Budrecki (buh-dre'-key)
FRC #0222 (Tigertrons)
cbudrecki is a name known to allcbudrecki is a name known to allcbudrecki is a name known to allcbudrecki is a name known to allcbudrecki is a name known to allcbudrecki is a name known to all
my big assist question:
Robot 1 in Red passes to Robot 2 in white. Robot 2, still in white, then passes back to Robot 1, now in blue. Robot 1 has no possession while in white. Would this count for the 3 assist rule?
Unread 05-01-2014, 10:43
cbudrecki's Avatar
as far as the confusion with the term 'assist', I just think that instead of saying 1,2,3 assists, it should be labeled as 0,1,2 assists, as one bot going for the goal does not involve any 'assistance.' Handing off to a 2nd bot is then 1 'assist,' and a 3rd bot is then a 2nd 'assist.' ... yeah, confusing term to use...
Unread 05-01-2014, 10:48
pilum40 pilum40 is offline
Steve Miller-Coach-Team 3355
AKA: Steve Miller
FRC #3355 (Bigg Redd)
Team Role: Coach
Rookie Year: 2010
pilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud of
Ok...a question from my students yesterday still "sticks in my craw"....
"If we're playing for max points in combination and assists, how are individual teams ranked for finals at the regional?" My question is how many refs will be needed to work three different teams, three areas, marking assists, calculating points in the hot zones as they come up hot, etc.? I'm just an AP teacher but I see a lot of Swiss Cheese holes and massaging of the rules. But...that's just one prole's opinion.
Unread 05-01-2014, 10:51
Qbot2640's Avatar
Qbot2640 Qbot2640 is offline
AKA: Terry McHugh
FRC #2640 (Hotbotz)
Rookie Year: 2012
Qbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond repute
Please correct me if I am wrong as this is the core of my confusion:
This would not constitute the 3 assist, because robot 1 initiated the first assist and is thus no longer eligible for additional assist participation (no longer "unique robot/zone pair")
2012 Palmetto Regional Winners (Thanks 2059, 2815, and 287).
2012 Newton 14th Seed
2013 Chesapeake Regional Imagery Award Winners
2014 North Carolina Regional Imagery Award Winners
2014 Greater DC Regional Team Spirit Award Winners
2015 North Carolina Regional Finalists (Thanks 3971 and 587)
Unread 10-01-2014, 07:51
lcoreyl's Avatar
lcoreyl lcoreyl is offline
WittyTitleGen can't link to library
AKA: Milner
lcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud of
Robot 1 would still be "eligible" (1 could then pass to 3 in blue and you have 3 assists). You are still thinking like sports assist where the actual pass matters.
you can score the 3 assists without any alliance members intentionally "passing" at all:
the human player retrieves the ball from the pedestal. they are excitedly running around to the guardrail and trip and the ball rolls into the blue zone. robot 1 drives over and picks up the ball in the blue zone. a defender crashes into robot 1 and the ball comes loose and rolls to the white zone where robot 2 possesses the ball. The defender crashes into robot 2 and the ball comes loose again and rolls to the red zone where robot 3 possesses the ball by herding into the low goal. 31 points. no passes.
Read Bob Steele's post again; POSSESSION IS THE KEY WORD! the definition of assist never says anything about passing.
I have to admit that when watching the kickoff video and then reading the rules I was still confused. After talking it through with a few people the idea of thinking only of possession and not passing made things more clear.
Unread 05-01-2014, 11:05
cbudrecki's Avatar
Well, to answer myself... after watching the Assist Analysis video over, and over again... this would NOT be a 3 assist, only 2. "Assists will never be granted for possessions that share either a row, or a column." Since the 2 Robot 1 possessions share a column, this would not count as an assist.
  #15   Spotlight this post!
Unread 05-01-2014, 11:16
TheOtherGuy's Avatar
TheOtherGuy TheOtherGuy is offline
Unregistered User
AKA: Kevin Forbes
FRC #4183 (Bit Buckets)
TheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond repute
The simplest way to explain the assist rule is to literally use their definition:
ASSIST: an event worth bonus points that occurs when a unique ALLIANCE ROBOT POSSESSES the ALLIANCE’S BALL in a unique ZONE (i.e. red, white, or blue ZONE) during a CYCLE.
In order to have one assist, you need one robot to posses the ball in one unique zone. To have two assists, you need two unique robots possessing the ball in two unique zones. For three assists, three unique robots possessing the ball in three unique zones.
