Go to Post I don't care if you use hot dogs for wheels. If you're scoring points, and you fit the strategy, it's fine. - evanperryg [more]
Go Back   Chief Delphi > Competition > Championship Event
Unread 04-01-2014, 12:42
alectronic alectronic is online now
no team (Volunteer)
Rookie Year: 2007
alectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant future
5.6.1 Four ROBOT Alliances
Looks like a new process at Championship this year... interesting...
5.6.1 Four ROBOT Alliances:
Before each Division Elimination Tournament, ALLIANCES will be selected per the process as described in Section 5.5.3: ALLIANCE Selection Process, however the process will continue with a 3rd round of selection as follows.
Unread 04-01-2014, 13:14
khanh111 khanh111 is offline
Outreach/Scouting/Software Manager
AKA: Hamzah Khan
FRC #1540 (The Flaming Chickens)
Team Role: Student
khanh111 has a spectacular aura aboutkhanh111 has a spectacular aura about
Re: 5.6.1 Four ROBOT Alliances
This is the IRI's way of selection. It's become increasingly common among other offseason events too.
Essentially, after each alliance has 3 robots, then they each choose a fourth one. The alliance can then play any three of those teams.
See the rules for a more detailed explanation, but this way allows for more diverse game play within each alliance.
Unread 04-01-2014, 14:56
no team (Volunteer)
Rookie Year: 2007
Right, I understand the rule. I was just pointing it out for discussion purposes. Thanks for the reminder though.
Unread 04-01-2014, 15:13
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
I still wish FIRST would adopt the Battlecry model and have 16 Alliances.
Unread 15-01-2014, 09:06
pandamonium's Avatar
pandamonium pandamonium is offline
FRC #1836 (Milken Knights)
pandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond repute
4 robots per an alliance!!?!?!?!
I have not seen anyone talk about how the elimination tournament structure will work at champs. Read the rules specifically the tournament rules and yes we will have 4 robots on alliances. How do you think this will work? I think 1st seed choosing twice in a row is a huge advantage.
Unread 15-01-2014, 09:22
Rynocorn's Avatar
Rynocorn Rynocorn is offline
Strategist and Designer
AKA: Ryan Jacobs
FRC #1466 (Webb Robotics)
Team Role: Mechanical
Rookie Year: 2010
Rynocorn is on a distinguished road
Re: 4 robots per an alliance!!?!?!?!
Correct me if I am wrong, but I believe his has been discussed in this thread already: http://www.chiefdelphi.com/forums/sh...ferrerid=74798
But it certainly is incredibly interesting. Also, I would check the rules as the pick order is still a snake draft so the first seed only makes their 2nd and 3rd pick back to back
My favorite parts: Surgical tubing, Grab catches, churro tubing, and waffle tread.
Unread 15-01-2014, 09:36
eddie12390's Avatar
eddie12390 eddie12390 is offline
AKA: Eddie
FRC #3260 (SHARP)
Rookie Year: 2011
eddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of light
I'm not sure if the picking order will be the same, but having one extra team per Alliance is the same way the Vex does it. It's always been very nice to have the ability to pick and choose teams as it gives you at least a match and reset time to fix potential issues that appear with a member of the team.
Unread 15-01-2014, 09:41
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
FrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond repute
Pick order is fully described in the rules.
Unread 15-01-2014, 10:42
Do you foresee picking two very different teams such as a strong defender as a 4th robot and rotating them in strategically as needed? I guess I wanted to discuss how it will be used or not used and the effect it will have.
It would feel kinda funny I think winning the world championship and not playing in a single elimination match.
Unread 15-01-2014, 11:12
Nathan Streeter's Avatar
Nathan Streeter Nathan Streeter is offline
FIRST Fan(atic)
FRC #1519 (Mechanical MAYHEM)
Nathan Streeter has a reputation beyond reputeNathan Streeter has a reputation beyond reputeNathan Streeter has a reputation beyond reputeNathan Streeter has a reputation beyond reputeNathan Streeter has a reputation beyond reputeNathan Streeter has a reputation beyond reputeNathan Streeter has a reputation beyond reputeNathan Streeter has a reputation beyond reputeNathan Streeter has a reputation beyond reputeNathan Streeter has a reputation beyond reputeNathan Streeter has a reputation beyond repute
I was very glad to see this rule change... it's a great way to improve the backup robot system and add another element of strategy at those higher levels of play!
What really bothers me about the prior backup system (which is still in place everywhere except CMP) is that the first backup robots tend NOT to be the best robots still available... The backup robots are the highest seeded, unpicked teams. Usually the alliance selection does a significantly better job of ranking robots than the qualification matches do (hence why some of the teams in the bottom quarter of the qual seeding will often getting picked)... which means that if a team "lucked out" in the schedule they will be ranked fairly high and may not be that good. This will be the backup robot.
So, I'm very glad to see this implemented at CMP... I would also like to see it implemented at DCMPs and potentially at Regionals though. At DCMPs it would be very helpful... you'd still have a good field to be drawing from, the teams picking have more experience, and the strategy would be more likely to enter in. I can't see it working as well for District events though, where you only have 40 teams and they've already played 12 matches... the backup robot pool would be fairly limited, and the quals should do a reasonable job of sorting the teams with the high match:team ratio.
As for how it'll play into strategy... I expect that to depend some on the game. In 2013, where teams generally filled specific roles because so few robots could do everything, I think you'd have seen the 4th robot being switched in for different match strategies by many alliances. I expect more robots to be effective at nearly all of the game tasks this year though... so don't expect most alliances to be swapping robots in and out. This year many alliances (especially one with 3 especially great robots) will never switch in their fourth robot. That said, there'd still be room to pick a fourth robot that would add an extra dimension to your alliance (i.e. specialized defense, good catching, etc.) that might be "too risky" to pick early on.
"If you want to build a ship, don't drum up men to gather wood, divide the work, or give orders. Instead, teach them to yearn for the vast and endless sea." - Antoine de Saint-Exupery
"The fight is won or lost far away from witnesses - behind the lines, in the gym, and out there on the road, long before I dance under those lights." - Muhammad Ali
"Simplicity is the ultimate sophistication." - Leonardo da Vinci
Student: 2006-2010 (#1519)
Mentor: 2011-Present (#1519)
Unread 15-01-2014, 11:15
eli2410's Avatar
eli2410 eli2410 is offline
Alumni/UCF Student
FRC #2410 (Metal Mustangs)
Rookie Year: 2011
eli2410 is a glorious beacon of lighteli2410 is a glorious beacon of lighteli2410 is a glorious beacon of lighteli2410 is a glorious beacon of lighteli2410 is a glorious beacon of lighteli2410 is a glorious beacon of light
We were chosen as the 4th robot of the number 1 alliance at the 2013 Cowtown Throwdown, joining teams 1986, 1825, and 3284 (thanks again for picking us!). We didn't play in the quarterfinals, and played in the second semifinal. Our alliance chose us because of our defensive ability, so we went in for the finals to block 1806's amazing full court shooter. We ended up blocking somewhere around 123 points, or 43 of their frisbees.
So, to answer your question, yes I see that it is possible (depending on how effective defense can be) for the 4th robot to be a defensive robot. You put your three high scorers in when you know you can outscore them pretty easily. You put in two of the three high scorers and the defensive bot when you aren't so sure.
Co-captain:
2013: Cowtown Throwdown-Winners
2014: Greater KC Regional-Judges Award & Oklahoma Regional-Judges Award and Dean's List Finalist (Lauren Pudvan)
Team Member:
2013: Razorback Regional-Team Spirit & Woody Flowers (Mr. Ritter) & Greater Kansas City Regional- Gracious Professionalism
2012: FIRST Championship in St. Louis, Oklahoma Regional- Team Spirit Award, & Greater Kansas City Regional
2011: Midwest Regional & Greater Kansas City Regional- Innovation in Control
Little Brother (Spectator):
2008: FIRST Championship in Atlanta & Greater Kansas City Regional
Unread 15-01-2014, 11:53
karomata's Avatar
karomata karomata is offline
Rebellious Egyptian
AKA: Mo Elhelw
karomata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud of
I don't find there to be an issue with 1st seed picking twice. This new system is identical to that of IRI, and often at IRI it is not over powered when the 1st seed pick both their 2nd and 3rd pick consecutively. Often times that is the most strategic pick and less based off of rank or qualification score, which will reward teams who "do their homework" by effectively scouting, and further lessen the value of teams that only focus on their own robot performance without keeping an eye on other teams. This adds another level of strategic play off the field, encouraging more inter team networking and communication, which in reality, is what this game is all about.
Mo Elhelw
FRC 1511 Rolling Thunder 10th Season Team Captain
Check out this awesome scouting project I've been working over the past year called FMS Scouting:
http://www.chiefdelphi.com/media/papers/3002
If you're tired of needing 6 people to scout or just don't have the resources, FMS Scouting is for you!
"The FIRST rule of FIRST Robotics is always talk about FIRST Robotics"
"Life's not linear"
2014 Finger Lakes Regional Chairman's Award Winner
2014 New York Tech Valley Regional Engineering Inspiration Winner
2013 Boston Regional Winners with 125 and 126
2012 Connecticut Regional Engineering Inspiration Winner
2011 DC Regional Chairman's Winners[/size]
Unread 15-01-2014, 11:57
JohnSchneider's Avatar
JohnSchneider JohnSchneider is online now
FRC #3310 (Black Hawk Robotics)
Rookie Year: 2010
JohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond repute
Isn't it 1->8 8->1 1->8? so its not identical to IRI
Unread 15-01-2014, 12:00
karomata's Avatar
Rebellious Egyptian
AKA: Mo Elhelw
I concur. You are correct. Sorry for the confusion.
Mo Elhelw
"Life's not linear"
