Go to Post Brace yourselves, reality check incoming. - EmileH [more]
Thread Tools Rating: Thread Rating: 5 votes, 5.00 average. Display Modes
Unread 04-01-2014, 14:48
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
FRC #2168 (The Aluminum Falcons)
otherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to behold
2014 Arial Assist Score Calculator
I put together a score calculator again this year.
Please let me know if you find any problems.
You will need to download it to make changes.
https://docs.google.com/spreadsheet/ccc?key=0AnIdRS5WoTuidEtuNmF3TVhmcVdnYXlTSUIyTml0e Xc&usp=sharing
It doesn't do any error checking yet (e.g. multiple scores from one robot in auto).
Also, the entry of assist points is a little weird, but it's the best way to enter the data quickly so far.
If you have suggestions/requests please contact me at james@team2168.org
http://team2168.org
Unread 04-01-2014, 17:43
yara92's Avatar
yara92 yara92 is offline
M.Fawdah Mechanical engineering
AKA: Mohamed
FRC #1946 (Mechka Monster)
Team Role: RoboCoach
yara92 will become famous soon enoughyara92 will become famous soon enough
Re: 2014 Arial Assist Score Calculator
nice work I send it to my time
TEAM 1946-Tamra
Unread 04-01-2014, 20:15
EvanVT EvanVT is offline
FRC #0095 (The Grasshoppers)
Team Role: Electrical
Rookie Year: 2012
EvanVT is an unknown quantity at this point
otherguy,
This calculator looks pretty sound. I do have a few suggestions about things that must be considered for match scoring. Under section 3.1.4 the manual states
"Points are awarded once per CYCLE for BALLS SCORED by ROBOTS in the GOALS, BALLS SCORED by ROBOTS over the TRUSS, and for each ROBOT CATCH. Additional points are credited to an ALLIANCE upon each GOAL based on the number of ASSISTS earned by the ALLIANCE for that CYCLE."
This means that assists, truss scores, and catches are not added to the alliance score until the cycle is completed. I believe that if the match were to end mid-cycle, none of the assist, truss, or catch points would count towards the final score.
A sheet taking this into account may consist of a section for scores from the auto period for each robot and then a separate section for points scored in each cycle.
Unread 04-01-2014, 20:24
cbudrecki's Avatar
cbudrecki cbudrecki is offline
AKA: Carl Budrecki (buh-dre'-key)
FRC #0222 (Tigertrons)
cbudrecki is a name known to allcbudrecki is a name known to allcbudrecki is a name known to allcbudrecki is a name known to allcbudrecki is a name known to allcbudrecki is a name known to all
Originally Posted by EvanVT View Post
otherguy,
I'm of the understanding that truss & catch points will count regardless of whether or not the ball is scored. Assist points, however, are only applied to scored balls.
Unread 11-01-2014, 15:17
Animal Control's Avatar
Animal Control Animal Control is offline
FRC #2345
Rookie Year: 2007
Animal Control is infamous around these partsAnimal Control is infamous around these partsAnimal Control is infamous around these partsAnimal Control is infamous around these parts
Smile Re: 2014 Arial Assist Score Calculator
thank you so much this calculator will make my job a whole lot easier
