Go to Post theres nothing more macho than something made entirely out of diamond plate. - Dan9874123 [more]
Unread 04-01-2014, 15:16
thegem811 thegem811 is offline
FRC #0811 (The Cardinals)
Team Role: Tactician
Rookie Year: 2014
thegem811 is an unknown quantity at this point
Balls left over from Autonomous Mode
If one or more of the three balls used in autonomous mode are still in the field of play when the drivers can start driving, can those balls be used to gain points by tossing them over the truss? And can they be used for assists, or does that not count, since they are not technically from a cycle?
Unread 04-01-2014, 15:25
GaryVoshol's Avatar
GaryVoshol GaryVoshol is online now
Cogito ergo arbitro
Rookie Year: 2000
Re: Balls left over from Autonomous Mode
You're right, ASSISTS only count during CYCLES.
3.1.2 says when the first CYCLE starts:
Although an ALLIANCE may start a MATCH with up to three (3) BALLS, the PEDESTAL will only be illuminated when the last BALL that started the MATCH is SCORED, effectively reducing the number of BALLS in play per ALLIANCE to one (1).
(since 2004)
Unread 04-01-2014, 17:58
Chi Meson's Avatar
Chi Meson Chi Meson is offline
"Strange and Anti-charmed"
AKA: Brian Chidley
FRC #2168 (Aluminum Falcons)
Team Role: Teacher
Chi Meson has much to be proud ofChi Meson has much to be proud ofChi Meson has much to be proud ofChi Meson has much to be proud ofChi Meson has much to be proud ofChi Meson has much to be proud ofChi Meson has much to be proud ofChi Meson has much to be proud of
And so currently I'm reading that Truss/Catch points CAN be earned with balls left over from autonomous, but I expect a rule change/clarification on this points.
The problem is that truss/catch points are limited to 1 each (20 points total) per cycle. But the balls in play at the end of Autonomous are not part of a cycle, so by a lteral reading of rules, you could re-lauch/catch with a post-autonomous ball any number of times.
I expect a rule modifaction that either limits a post-auto ball to 1 set of truss points, or to set truss points as being part of a cycle (as assist points currently are). This clarification would significantly impact an alliance strategy.
Unread 04-01-2014, 18:02
Timeroot Timeroot is offline
FRC #1717
Timeroot is an unknown quantity at this point
If you read it literally, then there are no TRUSS or CATCH points scored, because they're not part of a cycle at all. Those points only exist during a cycle.
Unread 04-01-2014, 18:11
Chi Meson's Avatar
AKA: Brian Chidley
Team Role: Teacher
That's been the argument, but where is the rule that says truss/catch points are "only during a cycle"? I agree that this is probably the intent, but after reading every line twice, I can't find that rule. Please do tell me where it is.
Unread 04-01-2014, 19:27
Brandon_L Brandon_L is offline
The color orange triggers me
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
Rookie Year: 2007
Brandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond repute
Game 3.1.4
Points are awarded once per CYCLE for BALLS SCORED by ROBOTS in the GOALS, BALLS SCORED by ROBOTS over the TRUSS, and for each ROBOT CATCH. Additional points are credited to an ALLIANCE upon each GOAL based on the number of ASSISTS earned by the ALLIANCE for that CYCLE.
A CYCLE is the series of events that recur regularly, and each CYCLE begins with an ALLIANCE member retrieving their BALL from their lit PEDESTAL and ends when the BALL is SCORED in a GOAL. Major events in a CYCLE are depicted in Figure 3-1.
Points are awarded once per cycle, and according to the definition of a cycle the ~3 auton balls left in play are not a part of a cycle.
Although, by this definition, points are not awarded at all for clearing out the ~3 auton balls after auton has ended because balls scored by robots in goals are counted once per cycle, and these balls are not part of a cycle.
Seems like this could be intentional, as it makes sense. Or maybe I'm misreading something.
FRC 2495 - Hamilton West Robotics [2007-2014]
FRC 3929 - Atomic Dragons [2012-2013]
FRC 2180 - Zero Gravity [2017-]
Just trying to collect all the possible team colors
Unread 04-01-2014, 19:35
theCADguy's Avatar
theCADguy theCADguy is offline
Design Team Student Leader
AKA: Sean Gibbons
FRC #0020 (The Rocketeers)
Team Role: CAD
Rookie Year: 2013
theCADguy has a spectacular aura abouttheCADguy has a spectacular aura about
Probably not. If this were actually legal, then there would be no logical reason to even have an autonomous, as more points could be scored by keeping the balls until teleop and gaining assist points instantly. Even if this were legal, it defeats the point (pun intended) of one the most important aspects of the game. Anyway, I predict that FIRST will clarify this some time soon.
Unread 04-01-2014, 19:37
GaryVoshol's Avatar
Cogito ergo arbitro
Rookie Year: 2000
Not only that, if they went through the goal without being SCORED, they'd be returned to the HP to reenter into the field. (3.1.2 second paragraph) Lather, rinse, repeat.
(since 2004)
Unread 04-01-2014, 19:50
AKA: Brandon Liatys
Rookie Year: 2007
We've got to be missing something somewhere.
Unread 05-01-2014, 00:06
JohnSchneider's Avatar
JohnSchneider JohnSchneider is offline
FRC #3310 (Black Hawk Robotics)
Rookie Year: 2010
JohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond repute
So we have to score pieces for no points?
I don't understand why the field crew cant just pause the match to take all of the balls remaining out of play... a lot less headache...
Unread 05-01-2014, 00:22
Connerd's Avatar
Connerd Connerd is offline
09R - JBD Detachment, USU ROTC
AKA: Conner Doggett
FRC #3166 (First Year Ravens)
Rookie Year: 2013
Connerd will become famous soon enough
Me ( and my team) think that the three (3) maximum allowed balls at the start of the match in auto would stay on the robots that they started in, with balls being recycled into play only after the last ball from auto mode was put through a goal. Whether this means that they will be scored, or if assists are possible, remains to be seen. A possible Q/A maybe?
2012-2014 - Team 3245 Ravens, Student/Mascot
2014-20?? - Team 3245 Ravens, Alumni
2015-20?? - Team 3166 Ravens, Mentor
Unread 05-01-2014, 00:37
cbudrecki's Avatar
cbudrecki cbudrecki is offline
AKA: Carl Budrecki (buh-dre'-key)
FRC #0222 (Tigertrons)
cbudrecki is a name known to allcbudrecki is a name known to allcbudrecki is a name known to allcbudrecki is a name known to allcbudrecki is a name known to allcbudrecki is a name known to all
Originally Posted by FRC Game Manual, 3.1.2, Paragraph 2
This includes BALLS that go in GOALS but don’t meet the criteria to be considered SCORED.
This makes me think that balls left over from autonomous are not part of a cycle, and therefore "don't meet the criteria to be considered SCORED." However all autonomous balls must pass through a GOAL before any balls may re-enter the field.
Unread 05-01-2014, 09:03
Ido_Wolf's Avatar
Ido_Wolf Ido_Wolf is offline
LabVIEW Addict
AKA: Ido
FRC #2230 (General Angels)
Rookie Year: 2011
Ido_Wolf is an unknown quantity at this point
Exactly, so what happens if a robot holding a ball loses communication or something during the game? The alliance would be doomed because of it, unable to score any points.
Unread 05-01-2014, 09:32
cbudrecki's Avatar
From what I can tell, with the rules as currently written, Yes. The exception would be if an alliance robot could possibly dislodge the POSSESSED ball.
  #15   Spotlight this post!
Unread 05-01-2014, 10:38
Tuba4 Tuba4 is offline
AKA: Tom Albert
FRC #0063 (The Red Barons)
Tuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant future
Under 3.1.2 MATCH Logistics it says: "Although an ALLIANCE may start a MATCH with up to three (3) BALLS, the PEDESTAL will only be illuminated when the last BALL that started the MATCH is SCORED, effectively reducing the number of BALLS in play per ALLIANCE to one (1)." Since the Pedestal only lights when the last ball is scored, I must believe that autonomous balls can only and must be be score into goals.
