Go to Post Why subject your robot to a potential sensor failure when you can train a monkey (or a student, if monkeys are lacking) to put the tube at the right height every time? - JVN [more]
Unread 04-01-2014, 16:28
Dexterium's Avatar
Dexterium Dexterium is offline
AKA: Adam Poindexter
FRC #1208 (Metool Brigade)
Rookie Year: 2011
Dexterium is an unknown quantity at this point
LabVIEW Update Failure
I just got the new LabVIEW at kickoff and am having issues getting it working. After installing all of the NI updates, the getting started page is not "'for FRC" and WPI Robotics Library is not available. Does anyone have any idea what the problem might be?
Unread 04-01-2014, 16:41
kgzak's Avatar
kgzak kgzak is offline
AKA: Kris
FRC #4392 (Decievers) FRC #2075 (Enigma)
kgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to behold
Re: LabVIEW Update Failure
Did you install the FRC update? Download it from ni.com/frc, unzip (might need password) and install then restart.
Unread 04-01-2014, 16:48
Dexterium's Avatar
Rookie Year: 2011
PROBLEM SOLVED
I did install the FRC updates. I just installed the wrong ones. In the past I have always found the updates by googling "FRC labview updates", the page that comes up is last years updates not this ones.
Unread 07-01-2014, 16:11
candreasen candreasen is offline
FRC #2574
candreasen is an unknown quantity at this point
Hey I'm having the same problem but I installed the patches (from the NI update service) after having started LabVIEW once, could that be the reason I'm not seeing the FRC custom interface?
Unread 07-01-2014, 16:30
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Originally Posted by candreasen View Post
Hey I'm having the same problem but I installed the patches (from the NI update service)...
What you can get from the built-in NI update procedure is not the FRC updates. Start at http://www.usfirst.org/roboticsprogr...ical-resources and follow the links to the FRC 2014 Update Suite.
Unread 08-01-2014, 18:19
FRC #2574
Yeah, I found that out after looking more closely yesterday, got it all up and running now, thanks!
Unread 08-01-2014, 19:04
TogaMaster TogaMaster is offline
FRC #4011
TogaMaster is an unknown quantity at this point
What password is required? I'm trying to install the update, but it's asking for a password and I have no idea what it might be.
Unread 08-01-2014, 20:23
Kevin Phan's Avatar
Kevin Phan Kevin Phan is offline
College Student
FRC #0357 (Royal Assault)
Rookie Year: 2010
Kevin Phan will become famous soon enoughKevin Phan will become famous soon enough
The password is 3Zones2Goals1Alliance
It can be located on the national instruments first website.
Unread 09-01-2014, 07:15
RufflesRidge RufflesRidge is offline
RufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant future
3Zones2Goals1Alliance!
Unread 09-01-2014, 09:27
bvisness's Avatar
bvisness bvisness is offline
Programming Mentor, Former Driver
FRC #2175 (The Fighting Calculators)
Rookie Year: 2010
bvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of light
Yep, don't forget the exclamation mark on the end.
