Go to Post FIRST definately holds the key to my heart...and everything that goes with it (except maybe the evil chop saw in the basement) - karinka13 [more]
Unread 01-04-2014, 04:56 PM
heisenburger heisenburger is offline
FRC #4716
Rookie Year: 2014
heisenburger is an unknown quantity at this point
.net framework help!
I cant install the .net framework which is required to install the 2014 NI update, I get the error code HRESULT 0xc8000222.
Unread 01-04-2014, 05:09 PM
daneelshof's Avatar
daneelshof daneelshof is offline
Programming Mentor
FRC #1619 (Up-A-Creek Robotics)
daneelshof has a spectacular aura aboutdaneelshof has a spectacular aura about
Re: .net framework help!
First, make sure you have installed any available Windows Updates.
If that doesn't work, you can then try the instructions in this post:
http://answers.microsoft.com/en-us/w...c-68b599b31bf5
Sometimes the Windows Update cache gets corrupted.
Unread 01-05-2014, 06:16 PM
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
HRESULT 0xc8000222 seems to be a common result of not having administrator privileges when trying to install the .net framework. Try again after logging on as an admin user, and/or running the installer with elevated privileges (right-click and choose Run as administrator).
