Go to Post It's not just well and good that students are being inspired, it's the whole dang point. - James1902 [more]
Go Back   Chief Delphi > FIRST > Rumor Mill
Thread Tools Rating: Thread Rating: 24 votes, 4.33 average. Display Modes
Unread 01-05-2014, 09:32 AM
wilsonmw04's Avatar
wilsonmw04 wilsonmw04 is offline
Coach
FRC #1086 (Blue Cheese)
Team Role: Teacher
Rookie Year: 2007
wilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond repute
Re: The Not So-Secret Secret End-Game
This thread is an awesome stress reliever. Thanks for the chuckle :-)
Currently: Coach FRC 1086/FTC 93
2006-2011 Coach FRC 2106/FTC 35
If you come to a FRC event to see a robot competition, you are missing the point.
Unread 01-05-2014, 09:43 AM
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
Also, Also, there are two options for the Team Element truss. Cheapest option is two strings strung between 2x4s. Which works fine for just making sure you clear it, but you couldn't hang a robot off it.
More expensive option is a truss-like construction of 1/2" plywood all around. Plywood for the sides of the truss and plywood strips for the "angles" of the truss. Which might, maybe, be stiff enough not to sag (much) across a field width span. But you sure aren't hanging any robots off it without turning it into splinters.
But if the GDC is willing to spring an entirely new game on us, they're probably more than willing to make teams waste $100 on wood for a useless game element.
Unread 01-05-2014, 09:49 AM
mrnoble's Avatar
mrnoble mrnoble is offline
teacher/coach
FRC #1339 (Angelbotics)
Team Role: Coach
mrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond repute
Agreed.
Honestly, the angriest I've felt towards the GDC was when, in 2012, we got to competition and discovered the mechanism we'd developed for pushing down the bridge we built to spec wouldn't even budge the actual bridges, which as you certainly recall, were so significantly heavier that they were entirely different.
Unread 01-05-2014, 10:02 AM
cbudrecki's Avatar
cbudrecki cbudrecki is offline
AKA: Carl Budrecki (buh-dre'-key)
FRC #0222 (Tigertrons)
cbudrecki is a name known to allcbudrecki is a name known to allcbudrecki is a name known to allcbudrecki is a name known to allcbudrecki is a name known to allcbudrecki is a name known to all
my 2¢ about the truss...
these are standard lighting/rigging trusses that I'm sure FIRST has plenty of easy access to (and they really aren't that expensive). The GDC is not only responsible for creating a game, but also making it look good, and ensure that it can stand up to the rigors of competition. Sure a rope or volleyball net would have done the job but 1)it'd look really cheesy, and 2) when one of these big balls hits it, it would give, lose slack, sag, and have to be re-tensioned between each match. The trusses simply look good, and won't ever change dimensions.::
Unread 01-05-2014, 10:42 AM
dubiousSwain's Avatar
dubiousSwain dubiousSwain is offline
The ride never ends
AKA: Christian Steward
FRC #5420 (Velocity)
Rookie Year: 2011
dubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond repute
Originally Posted by GearsOfFury View Post
My opinion on truss strength / durability and people feeling it's unnecessary: I think people are overlooking the fact that there will be 3 pound balls shot at the truss at high velocity, multiple times per game. The GDC is probably just trying to insure the thing doesn't break or fall over when all those shots fail to clear the truss. A rope or simple bar wouldn't do it. Plus as some have pointed out it looks like standard lighting rigging that they have plenty of experience with and access to.
A volleyball net would absorb the force of a ball perfectly fine...
2015 MAR District Champions
Unread 01-05-2014, 10:49 AM
bugynerd bugynerd is offline
FRC #2197 (Las Pumas)
Team Role: Coach
bugynerd is an unknown quantity at this point
Did I miss something, or was there actually no release of the Encryption Code in the Kickoff Broadcast?
Did I miss something, or was there actually no close to the Kickoff Broadcast, in the form of a few "good luck teams" words from Dean, Woodie, and Don?
Unread 01-05-2014, 10:51 AM
RufflesRidge RufflesRidge is offline
RufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant future
You and/or your kickoff missed something (the end of the broadcast). https://www.youtube.com/watch?v=YWb2...PZcMFF3#t=1722
Unread 01-05-2014, 10:59 AM
fb39ca4 fb39ca4 is offline
FRC #1899
fb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to all
But it would be worse if a robot got entangled in it, which would likely tear the net. A truss, on the other hand, while still allowing the robot to get entangled, would not break.
Unread 01-05-2014, 11:08 AM
ninjosh97's Avatar
ninjosh97 ninjosh97 is offline
ninjosh97
AKA: Josh
FRC #2655 (The Flying Platypi)
Team Role: Leadership
Rookie Year: 2012
ninjosh97 is an unknown quantity at this point
Lightbulb Re: The Not So-Secret Secret End-Game
Just something else I found.
According to R18, you can carry 30lbs of robot parts not in the bag.
Hasn't it been 20lbs in previous years?
Maybe they expect us to need to bring more.
Josh H.
Team 2655, 2013-14 Season President
4 FLL Seasons
3 FRC Seasons (So far)
Unread 01-05-2014, 11:17 AM
mrnoble's Avatar
teacher/coach
Team Role: Coach
No, that is not correct. It's been 30 lbs.
Unread 01-05-2014, 11:23 AM
ninjosh97's Avatar
ninjosh97
AKA: Josh
Rookie Year: 2012
Ah ok, wasn't sure.
Thanks for the clarification. :-)
Josh H.
4 FLL Seasons
Unread 01-05-2014, 11:34 AM
mrnoble's Avatar
teacher/coach
Team Role: Coach
I feel the need to point out that thinking the GDC might add another game element is not akin to "conspiracy theory", as in Area 51 aliens, vaccinations=autism, and any of the twisty ways of discovering a Water Game. It is much more like adding bonds to your stock portfolio when Ben Bernanke hints that interest rates might be allowed to rise. If anyone is actually building for a game that doesn't exist based on hints that don't say much (if anything) about what that game might be, they are foolish. I don't think there is actually anyone doing that. What I think SHOULD be done is, plan for the game as it is now, and leave room in your thinking and designs for changes that might occur. Hedge your bets.
I think I'll leave this one alone for a while now. If I'm correct, and there is more to be revealed, well, we'll all see it sooner or later. If I'm wrong, then that's fine too, and no one will have to adjust. Either way, it doesn't make much difference to keep looking for more and more obscure (or nonexistent) clues, and keep debating points of conjecture. The idea is clearly out there now. Let's just wait and see what happens.
Unread 01-05-2014, 12:27 PM
MooreteP's Avatar
MooreteP MooreteP is offline
Zen Archer
AKA: Senor Mas
FRC #0571 (Team Paragon)
Rookie Year: 1998
MooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond repute
While showing the animation last night to a casual observer of FIRST challenges, their initial reaction as the animation started was: "oh, is it volleyball this year?"
Volleyball also has assists. Imagine an endgame where extra points were awarded for each successive throw and catch over the truss during the last 15 seconds. Or even a bonus multiplier (1.1x, 1.2x, 1.3x) that increased for each successful volley as long as the ball never hit the floor.
It would not require any new ideas or designs that hadn't been considered or were already being created.
It would have a crowd pleasing excitement that would improve this game.
Unread 01-05-2014, 12:37 PM
Racer26 Racer26 is offline
Racer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond repute
Neat idea.
  #15   Spotlight this post!
Unread 01-05-2014, 01:26 PM
runneals's Avatar
runneals runneals is offline
FTC Mentor - The Robot Corps 7491
FRC #3928 (Team Neutrino)
runneals has a spectacular aura aboutrunneals has a spectacular aura about
Looking at how they designed the team on (the truss supports going horizontal, instead of vertical or even just a 12x12 box) support your thought about the 3 pound balls... but wouldn't not making them go vertical just sag the wood?
David Runneals
FRC 3928 Team Neutrino 4-H: Mentor (2015 Off-Season - ?)
FTC North Super Regional Championship: Game Announcer (2015)
FTC 7491 The Robot Corps 4-H: Mentor (2013 - ?)
FRC 2167 Mentor (2014)
FRC 3928 Team Neutrino 4-H: Member, Co-Captain, & Media Coordinator (2013)
