Go to Post FIRST is doing a great job, it's me who needs to do the hard work now. - Bomberofdoom [more]
Unread 05-01-2014, 12:15
yash101 yash101 is offline
Curiosity | I have too much of it!
AKA: null
Rookie Year: 2012
yash101 is an unknown quantity at this point
Re: "Dud" robots
If che control system fails, the team with the failure would lose for no reason, especially because in most cases the failures in the cRIO are natural and happens once-in-a-while.
So you may ask why I am bringing this up. This happened to us last year. As soon as the teleop period started, the cRIO randomly died. Thankfully, we had an extra cRIO sitting in out pit so recovery didn't take too long.
However, what if this happened and the robot was loaded upon the damage? That would be shear bad luck for the entire alliance!
I actually don't remember if we were even allowed to rematch after we fixed the problem so they really have to tweak that rule.
Overall, in my opinion, I think this is the most poorly written game in the FIRST history! There isn't even an endgame to give teams more of a challenge. Also, the ball is roughly the size of the robot. It also needs to be picked up. Because of the size and what needs to be done with the ball, it isn't as simple as 2008 where you could knock off the ball and then kick it. I think one of the only possibilities is to kick the ball!
Unread 05-01-2014, 12:35
Racer26 Racer26 is offline
Racer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond repute
Re: "Dud" robots
While I might be inclined to agree that Aerial Assist is one of the weakest games the GDC has come up with in my 11 years in FRC, there is definitely no problem picking up this ball. Go watch some videos from 2008, when trackballs were twice the diameter of this ball, and robots only marginally larger. Picking up a 2014 game ball is not that big a deal.
Unread 05-01-2014, 01:23
julianpowell julianpowell is offline
FRC #2928 (Viking Robotics)
Rookie Year: 2011
julianpowell will become famous soon enoughjulianpowell will become famous soon enough
Re: "Dud" robots
When you load a ball for autonomous you are taking a calculated risk. If you think it's likely that your autonomous will malfunction then you don't have to load a ball.
Unread 05-01-2014, 01:56
Anthony4004's Avatar
Anthony4004 Anthony4004 is offline
Anthony4004
FRC #4004 (MARS Rovers)
Anthony4004 is an unknown quantity at this point
Re: "Dud" robots
You do not have to load the ball into the robot, you can have it on the carpet touching.
Unread 05-01-2014, 02:22
SoftwareBug2.0's Avatar
SoftwareBug2.0 SoftwareBug2.0 is offline
AKA: Eric
FRC #1425 (Error Code Xero)
SoftwareBug2.0 has a brilliant futureSoftwareBug2.0 has a brilliant futureSoftwareBug2.0 has a brilliant futureSoftwareBug2.0 has a brilliant futureSoftwareBug2.0 has a brilliant futureSoftwareBug2.0 has a brilliant futureSoftwareBug2.0 has a brilliant futureSoftwareBug2.0 has a brilliant futureSoftwareBug2.0 has a brilliant futureSoftwareBug2.0 has a brilliant futureSoftwareBug2.0 has a brilliant future
Re: "Dud" robots
The problem is not that your robot could malfunction and lose you the round. The problem is that you get put in the position where you have to tell your alliance partners that you think their robot's autonomous mode is worse than useless. That's a good way to make people resent you.
Unread 05-01-2014, 04:35
Gray Adams's Avatar
Gray Adams Gray Adams is offline
Rookie Year: 2000
Gray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to behold
Re: "Dud" robots
Your alliance members have always been able to jeopardize your chance of winning by doing something negative for the team. This is nothing new.
Unread 05-01-2014, 07:51
magnets's Avatar
magnets magnets is offline
Rookie Year: 2012
magnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond repute
Re: "Dud" robots
In previous years, if my alliance partner wanted to stop me from scoring, I could still grab discs/basketballs/tubes and score them, or I could single balance, climb, or deploy a minibot. This year, if my partner gets stuck with the ball, I can no longer get points for the rest of the match. Think about if Einstein 2012 happened again, and a robot didn't work on the field. 0 points for that allinace . That's the first time they've made a game where your partners MUST continue working if they have a game piece.
I predict if there are field issues (let's face it, it's not unlikely), then teams will be really mad.
Unread 05-01-2014, 08:03
Yalib Yalib is offline
FRC #2630 (Thunderbolts)
Rookie Year: 2011
Yalib is on a distinguished road
Re: "Dud" robots
What about a robot losing communication? just e-stop him immediately? because usually a robot who lost com will "come back to life" after a number of seconds..
Thunderbolts 2630, Emek Hefer, Israel
2013 Israeli Regional Winner & Quality Award, Dean's List Finalist
2013 DC Regional Semi-Finalist & Industrial Design Award
Ranked 5th in 2013 Galileo
Unread 05-01-2014, 08:12
magnets's Avatar
Rookie Year: 2012
Re: "Dud" robots
Well, if its a three second communications drop (which we and all of our alliance experienced at CMP a few times last year), then wait. If the cRIO reboots, it'll be more like 20 sec, and if the radio goes down, more like a minute, which is too long. You can't e-stop an unconnected robot.
Unread 05-01-2014, 09:02
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
Rookie Year: 2011
ToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond repute
Re: "Dud" robots
Pointing out to me that my shooter might malfunction and lose the match for my alliance will not cause me to resent you. However, designing your robot in such a way that it loses me a match might. You better believe that our scouts this year will be noting which teams cost their alliances matches this way.
This aspect of the game is actually one of my favorites this year. It makes designing a shooter which must be pre-loaded a HUGE risk. If your robot fails, you cost your alliance the match. So you have a couple options:
A) Start with the ball on the floor and load it before shooting. That way, if your robot starts out dead, you don't cost your partners the match.
B) Don't shoot at all.
I see this rule as part of a deliberate effort on the part of the rules committee to make powerhouse teams less dominate. This year, the risk vs reward for building a shooter is very high. If you build a shooter which must be preloaded, you risk losing matches for your team. Even if your shooter works perfectly, it is easily defended against by a robot ramming you as you are shooting. This lowers the advantage that elite teams have had in the past, bringing them down towards the effectiveness level of a team which builds a simple pusher bot.
Remember the teams last year who asked, "Why did we spend all the time and effort to build a 3 tier climber, when we can be beaten by two robots who only feeder-station load, shoot, and hang for 10 points?"
Answer: The game designers are deliberately designing the games so three rookie teams who work together can beat an elite team who plays alone.
Todd F.
mentor, FIRST team 2363, Triple Helix
Photo gallery
video channel
Triple Helix mobile
Unread 05-01-2014, 10:06
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is offline
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Daniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond repute
Send a message via MSN to Daniel_LaFleur
Re: "Dud" robots
Any team that lets me know that their autonomous mode may be 'worse than useless' is marked high in my book because they are honest (we can help them with the autonomous mode).
It's the ones that tell me that they can do it all, when they are barely functional that bother me.
Also:
Is anyone concerned that if a bumper falls off your robot will be disabled? And this could happen with a ball inside your machine?
___________________
"We are not now that strength which in old days moved earth and heaven; that which we are, we are;
One equal temper of heroic hearts, Made weak by time and fate, but strong in will
To strive, to seek, to find, and not to yield. "
- Tennyson, Ulysses
Unread 05-01-2014, 11:43
dubiousSwain's Avatar
dubiousSwain dubiousSwain is offline
The ride never ends
AKA: Christian Steward
FRC #5420 (Velocity)
Rookie Year: 2011
dubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond repute
Re: "Dud" robots
I totally agree with this
2015 MAR District Champions
Unread 05-01-2014, 03:34
Damyen Damyen is offline
FRC #1574
Damyen is an unknown quantity at this point
Re: "Dud" robots
Can my robot pick that other ball and score it as well to earn more autonomous points?
Just a thought of a solution
