Go to Post There is one unbreakable and unwritten law in FIRST, don't make it hard for your alliance partners to play. - Al Skierkiewicz [more]
Unread 05-01-2014, 15:01
Zebra_Fact_Man's Avatar
Zebra_Fact_Man Zebra_Fact_Man is offline
]\/[ Go Blue!
AKA: Solomon
FRC #1076 (Pi Hi Samurai)
Team Role: Coach
Zebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant future
Re: Is throwing worth it ?
Thanks for the quick answer. I read that rule at least twice and somehow never got that interpretation.
Unread 05-01-2014, 15:15
roush14r roush14r is offline
FRC #0900
roush14r is an unknown quantity at this point
I'm fairly new with FIRST but I feel like if it is worth for one robot to be throwing per alliance. Beyond that, I think that it become a little excessive and not necessarily worth it.
Unread 05-01-2014, 17:24
TheMadCADer TheMadCADer is offline
Rookie Year: 2010
TheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant future
If you want "full" 60 point cycles, you will need to throw over the truss and shoot into the high goal. To be the most time-efficient you can be, each robot should ideally only possess the ball in one zone. This would make an "ideal" match flow as follows:
Robot A receives ball from human player in Red Zone.
Robot A launches ball over truss to catching Robot B in White Zone.
Robot B somehow gets ball to Robot C.
Robot C launches ball through High Goal while in Blue Zone.
However, if you replace the High Goal with a Low Goal in that last step, you only lose out on 9 points per cycle.
Unread 05-01-2014, 17:32
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
FRC #2410 (BV CAPS Metal Mustang Robotics)
Rookie Year: 2010
CalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond repute
If you already have a method of launching over the truss, why would you not shoot for the high goal anyways? Just have Robot A launch, then go down to the other end of the field for a pass from C to launch into the goal?
Team 2410 thinks KISSing is amazing! Keep It Super Safe!
  • "You know you've been in robotics too long when you start talking to your tools." "Well, you've been in robotics CLEARLY too long when they start talking back"
  • Theory is when you know everything but nothing works. Practice is when everything works but you don't know why. On our team, theory and practice comes together - nothing works and nobody knows why.
MMR 2410 Student (2010 - 2013) | MMR 2410 Mentor (2013 - Present)
FTC Game Announcer / EmCee (2014 - Present) | FRC EmCee (2015 - Present) | FRC Referee (2016)
Academic Student (Forever)
Unread 05-01-2014, 17:45
Rookie Year: 2010
It simply takes too long.
Robot C then needs to possess the ball and deliver it back to Robot A. Robot A also has to wait around for the B --> C exchange and can't play defense in the Red Zone, which means they also aren't there to pick up the new ball as soon as it comes into play.
Instead, you could keep Robot A in the Red Zone playing defense while Robot C brings the ball to the Low Goal (instead of to Robot A). Robot A plays defense instead of driving back and forth, picking up the ball, and lining up for a shot.
The only time I'd say the high goal is better is if there is heavy defense on both Low Goals.
Unread 05-01-2014, 20:13
Alan2338's Avatar
Alan2338 Alan2338 is offline
Former Team Leader/Driver - Alumni
AKA: Alan Cabiness
FRC #2338 (Gear it Forward)
Rookie Year: 2011
Alan2338 will become famous soon enough
The way i see it, the fastest and highest scoring way is to do this:
Robot A passes ball to waiting Robot B in White Zone (before the truss).
Robot B throws/lobs the ball over the truss
Robot C reacquires thrown ball
Robot C shoots/throws ball into high goal.
I just think maybe a thrower should be in the white, and not the red. Just my thoughts...
P.S. I might think this just because I don't believe catching is going to be a big deal...
2013 Wisconsin Regional Winners (111, 1732)-Midwest Regional Semifinalists, 2nd Seed Captain, (111, 1675), Gracious Professionalism
Galileo Division Quarterfinalists, 7th Seed Captain (2512, 1323)
2014 Crossroads -Quarterfinalist, 8th Seed Captain (4085, 2358)Midwest -Finalist, 2nd Seed Captain (1732, 3936)
2015 Wisconsin -Quarterfinalist, 2nd Seed Captain (2077, 167) Judge's Award Midwest-Finalist, 1st Seed Captain (1756, 171) Chairman's
Archimedes Division Winner, 1st Seed Alliance (1023, 3996, 1089) Einstein Semifinalists
DePaul Class of 2018 - Computer Science
Unread 05-01-2014, 21:14
Rookie Year: 2010
Catch points aren't going to change many matches by themselves. However, it actually saves you time in the long run. Tossing the ball over the truss will send it bouncing the rest of the way across the field for the next robot to chase down if you don't catch it. If you do catch it then you can go right ahead and spit it out for that final assist or shoot quickly if you're the last robot in the line.
I see catching as a way to make what is essentially a really, really good pickup that also scores you bonus points.
Unread 05-01-2014, 21:39
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Donut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond repute
I have the same thoughts. I don't think catches will be common, but if a pair of robots can successfully pull off a truss throw/catch move, it gets a +30 point bonus in a single move (truss points, catch points, and at least a 2 assist) and is very hard to defend against. If the ball is high in the air traveling between the two robots there is no chance to block the ball during travel, and if you can't knock either robot out of position during the throw there's no way to defend it.
FRC Team 498 (Peoria, AZ), Student: 2004 - 2007
FRC Team 498 (Peoria, AZ), Mentor: 2008 - 2011
FRC Team 167 (Iowa City, IA), Mentor: 2012 - 2014
FRC Team 2662 (Tolleson, AZ), Mentor: 2014 - Present
Unread 05-01-2014, 23:22
G-Hence G-Hence is offline
FRC #1261
G-Hence is just really niceG-Hence is just really niceG-Hence is just really niceG-Hence is just really niceG-Hence is just really nice
Well time is an issue, but how much time is another thing. The rules don't really specify possession in time but rather control so theoretically, you could control the ball for lets say 2 seconds and you have the ball stopped and ready to assist given that you intake stops the ball quickly.
"Never let the fear of striking out get in your way."
-Babe Ruth
Unread 05-01-2014, 18:02
marissa1215's Avatar
marissa1215 marissa1215 is offline
FRC #2729 (STORM)
Team Role: Marketing
Rookie Year: 2013
marissa1215 is an unknown quantity at this point
I think that even though it may be harder the ball into the higher goal, it still is worth it considering the amount of points you can get, with a ratio of 1:10, when there is a good amount of time on the clock it is better to just risk the higher shot and make more points, but rolling the ball into the lower goal is ideal for when the score are neck and neck and you only need 2 or 3 points to win.
Unread 05-01-2014, 18:05
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
The best teams never ask "Is it worth doing?"
They ask "What's worth the most points and how can we do it?"
That's why they are always playing deep into Saturday @ Champs all the time.
Unread 05-01-2014, 19:21
loyal loyal is offline
Jack of all trades master of none
AKA: Loyal
FRC #0716
Rookie Year: 2012
loyal is a name known to allloyal is a name known to allloyal is a name known to allloyal is a name known to allloyal is a name known to allloyal is a name known to all
Throwing the ball is way faster. Forget the 3 assist. Take the 2 assist, over the truss, catch if you can, if not no worries. Gain control and sink the high goal. That when done correctly will be the quickest and most efficient scoring. Imo
Unread 05-01-2014, 20:28
Celia's Avatar
Celia Celia is offline
Now I go to college
FRC #0240 (TEMPEST alumna, MEZ mentor)
Rookie Year: 2012
Celia is an unknown quantity at this point
This ^^^
When we start brainstorming, we make a prioritized list of what we want our robot to do. High goal/truss shooting is worth ten points. Having a shooter means getting nine - or nineteen - more points per cycle rather than going for the low goal with no truss pass. Even if only one or two assists are managed, the shooting robot comes out on top. A well-designed robot should be able to efficiently harvest and shoot the game piece in nearly the same amount of time it takes another to herd the ball into the low goal. In autonomous, the point values speak for themselves.
Another positive to throwing: Let's say your alliance partners are unable to assist (broken down, goalie, etc.). Theoretically, couldn't one throwing robot cycle the field on its own, throwing over the truss and score in the high goal by itself? Earning twenty points per cycle with one robot doesn't seem half bad.
See one, do one, teach one
Unread 05-01-2014, 20:39
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
I think the important question here is, when will the High Rollers break a wall clock this year?
http://www.youtube.com/watch?v=raZdkGxq5Ig
  #15   Spotlight this post!
Unread 06-01-2014, 10:53
JB987 JB987 is offline
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
Team Role: Coach
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
What makes you think we haven't already, Jim? We almost did worse...launched ball so hard it knocked off control boards from shelf at driver station wall in our shop. Turns out the joysticks are pretty durable.
"A genius is just a talented person who does his homework" T. Edison
