Go to Post The size of your team has nothing to do with the size of your heart. - Amanda Morrison [more]
Unread 05-01-2014, 10:29
mitchklong mitchklong is offline
None #4859
mitchklong is an unknown quantity at this point
Is throwing worth it ?
Im trying to decide if adding a throw ability really buys that much.
Throwing can get you
Truss points (10)
Possibly catch points (10)
high goal points (9 more)
But throwing also:
causes the ball to bounce. That makes it more difficult to control than rolling.
risks ejecting the ball from the field.
can easily miss high goal and have to reshoot
relatively challenging technically
So..to throw or not to throw. That is my question.
Unread 05-01-2014, 10:34
who716's Avatar
who716 who716 is offline
AKA: Stephen Kalogiannis
FRC #0716 (Who'sCTEKS)
Rookie Year: 2011
who716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to behold
Re: Is throwing worth it ?
How about having a thrower that is also your shooter
-WPI number one seed
-Innovation in controls award
- NECMP#4 seed semifinalist
- 9th in NEW ENGLAND
2008- Connecticut regional winners
2004-UTC new England regional Winners
2001 highest rookie seed award winner
Unread 05-01-2014, 10:36
Zuelu562's Avatar
Zuelu562 Zuelu562 is offline
Ready for WPI District!
AKA: Jake Janssens
FRC #3623 (Terror Bots)
Zuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to behold
Throwing in a cycle can generate 20 points more than what just roll passes do just by the truss and catch bonuses. Add on the additional 9 from scoring high, and you have compelling enough reason for me. Also, a bouncing ball isn't really that hard to manage if you have some imagination. Get it to the wall or have a guide system to control it.
Team Resume
562 "S.P.A.R.K." - Student Programmer 2008-2011, Field Coach 2011
3623 "Terror Bots" - Technical Mentor, Field Coach 2012 - Present
Volunteer Resume:
BattleCry@WPI 12, 13, 15, 16 - Queuing
BattleCry@WPI 14 - Field Reset
Granite State District Event 2014 - Team Queueing
NEFIRST District Championships '14,'15,'16 - Team Queuing
Unread 05-01-2014, 11:21
engunneer's Avatar
engunneer engunneer is offline
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
Rookie Year: 1996
engunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond repute
I consider the truss pass (without catch) to be worth +20, since it comes with an assist (almost certainly). With the catch, it is worth 10 or 20 more than a normal assist.
Accurate throwing is going to be key for catching.
Student FRC23 (1996-1999), Mentor FRC246 (2000), Mentor FRC1318 (2007-2009), Mentor FRC93 (2011), Mentor FRC2151 (2012), Mentor FRC23 (2013), Mentor FRC4761 (2014-2017)
1998 - National Chairman's Award and Woodie Flowers Award (FRC23, Mike Bastoni ) | 2007 - PNW SF (488, 1595) | 2008 - Oregon RCA - Seattle #2 Seed, SF (488, 1696) | 2009 - Oregon #1 Seed, Winners (1983, 2635) - Seattle SF (945, 2865) - Galileo #2 Seed, SF (973, 25) | 2012 Midwest F (111, 71) | 2014 RIDE Winners (78, 125), Inspector - NEU #24, QF (3479, 3958) - NECMP #35 | 2015 Reading #11, SF (1058, 190), Inspector - RIDE #17, QF(4055, 5494), Inspector - NECMP #57 | 2016 Reading #4, SF (133, 4474), DCA, Inspector - Ride #22, SF (1735, 2067), Creativity, Inspector - NECMP #48, RCA - Archimedes
Unread 05-01-2014, 12:00
RRLedford RRLedford is offline
FTC 3507 Robo Theosis -- FRC 3135
AKA: Dick Ledford
FRC #3135 (Robotic Colonels)
RRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond repute
It all boils down to what the the level of impact is on increasing the cycle times when completing over truss shots & high goal scoring shots.
This then must be compared to the minimum cycle times that an efficient 31 point basic 3-assist with low goal score can give.
I can easily see the efficiently done 31 point cycles being completed almost twice as fast as an average 50 point cycle with both over truss done (no catch) and high goal scored.
Even assuming 100% success rate on over truss shooting, relinquishing ball possession with significant energy imparted to balls, and then perhaps having to contend with better positioned, more nimble than you defender blocking your effort to retrieve and reload the balls for the high goal shot seems like an especially risky time waster.
Then there is the issue of what percent of what goal shots can actually be successful on 1st try? Even at 90% accuracy this means you only gain ~8 points over the low goal (assuming 100% for them), and so in a five cycle match this would average out at only ~40 extra points, but if the the extra time investment needed, compared to low goal scoring, to reach that level of accuracy on the high goal, is only about 5 seconds per cycle, then the competition might nearly complete one more 31 point cycle and almost nullify the high goal scoring advantage.
So, if you seek to accomplish both the over truss shot and the high goal shot as your ideal strategy for each cycle, I conclude that that combination will ultimately prove more detrimental than advantageous for your final score.
This will be more the case with even an average amount of basic defense against you.
My advice would be to only attempt one or the other. and if high goal accuracy is good, that would be the one to do. The truss shot is just too big of a cycle time waster without having a consistent catch to add 10 more points and eliminate the ball chasing time waste. So, with the difficulty of executing the ball catch, the over truss shot seems like a bad idea.
Our team will only attempt high goal shots in both auto & tele of we can reach the 90+% accuracy level. We are also looking at how also to have an even more certain alternate option for low goal scoring, so we can go either way in matches where there is too much high goal shooting defense happening.
-Dick Ledford
FTC 3507 RoboTheosis
FRC 3135 Robotic Colonels
Unread 05-01-2014, 12:24
geomapguy's Avatar
geomapguy geomapguy is offline
Centenary '18
AKA: Graham Maxwell
FRC #1818
Rookie Year: 2011
geomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud of
Truss points (10)
Might want to read the rules. High goal scores are clearly 10 points.
Base point values are as follows:
LOW GOAL 1
HIGH GOAL 10
CATCH 10
TRUSS 10
The Cowboys - FIRST Robotics Team #1818 2015-
The Bolton Bear Bots - FIRST Robotics Team #3666 2011-204 (30-26-0)
2014 Oklahoma Regional - 20/62 (6-4-0), 5/62 in OPR
2014 Arkansas Regional - 14/39 (8-7-0, Quarterfinalists with 1706 and 1939), 24/39 in OPR
2013 Lone Star Regional Dean's List Finalist!
2013 Lone Star Regional - 22/57 (6-5-0), 17/57 in OPR
2012 Bayou Regional - 16/49 (6-5-0)
2011 Dallas Regional - 10/52 (4-2-5, #6 Alliance Captain, Quarterfinalists with 2948 and 3350)
Unread 05-01-2014, 12:39
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
He said 9 more. The implication is that if you can get the low goals (and if you can't get those, you need a new robot, and quick!), throwing only nets an additional 9 on top of the 1 for the low goal that anybody can get.
In other words, the box-on-wheels can get assist and low-goal points. A throwing robot can add in the truss points, the high-goal points, and possibly the catch points, as well as picking up assists and low goals.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 05-01-2014, 12:44
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
The high goals are a lot more difficult to defend than the low goals. Low goals could be fairly locked down by two defense bots. So a high, defense, defense alliance could probably take down a low, low, low alliance.
Unread 05-01-2014, 12:40
Racer26 Racer26 is offline
Racer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond repute
Yes... And scoring the BALL in the high goal instead of the low goal is a net gain of +9 points.
Unread 05-01-2014, 12:45
DonRotolo's Avatar
Back to humble
FRC #0832
First, consider if the winners on Einstein in 4 months will be able to throw or not.
Second, realistically, consider whether your team can build a mechanism to do that or not.
Your answers determine the answer to the OP
Unread 05-01-2014, 14:08
redsox11 redsox11 is offline
FRC #0348
redsox11 is an unknown quantity at this point
Another thing to take into consideration is that scoring in the low goals isn't as simple as just pushing it in, there are 7 inches between the bottom of the low goal opening and the field.
Unread 05-01-2014, 14:20
Team3266Spencer's Avatar
Team3266Spencer Team3266Spencer is offline
Team Captain and Lead Programmer
AKA: Spencer Lanman
FRC #3266 (Robots-R-US)
Rookie Year: 2012
Team3266Spencer is an unknown quantity at this point
But the ball has a 12 inch radius, so I imagine it wouldn't be that difficult to push in.
2012: Buckeye Regional, Queen City Regional, Human Player
2013: Queen City Regional, Buckeye Regional, Crossroads Regional
Shooter Operator
2014: Crossroads Regional, Queen City Regional
Catapult Operator
2015: Georgia Southern Classic Regional (Winner), Queen City Regional
Chainsaw Operator
Want to talk? TeamSpeak: team3266.noip.me
Unread 05-01-2014, 14:51
Zebra_Fact_Man's Avatar
Zebra_Fact_Man Zebra_Fact_Man is offline
]\/[ Go Blue!
AKA: Solomon
FRC #1076 (Pi Hi Samurai)
Team Role: Coach
Zebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant future
Something not explicitly stated in the rules, but I feel like it works against the spirit of the game (and expect a Q&A regarding it) is whether a robot can throw a ball over the Truss and catch it themselves.
Effectively kills a "Teamwork" element of this game, but if you get some space, I feel like it could be an easier 20pt bonus than trying to coordinate throwing and catching with 2 different robots.
If it ultimately IS legal, than throwing is definitely worth it. If not, unless you plan to shoot for 10's, I'd say NO.
Unread 05-01-2014, 14:54
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Rookie Year: 2011
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
Originally Posted by FRC Game manual
A CATCH occurs when a BALL SCORED over the TRUSS by a ROBOT’S ALLIANCE partner is POSSESSED by that ROBOT before contacting the carpet or HUMAN PLAYER.
(Emphasis mine.)
I.e. Not the same robot.
2010: FRC 3043, Build Assistant
2011: FRC 3043, Head of Minibot subteam; FLL 12762, Team Captain
2012: FRC 3043, Electrical; FLL 12762, Team Captain; FTC 5670, Team Captain
2013: FRC 4301, Electrical, Team Co-Captain
2014: FRC 4301, Electrical/Programming, Team Co-Captain
2015: FRC 4301, Electrical/Programming, Team Captain
2016: FRC 4301, Chief Technical Officer; FTC 10860, 10861, and 11004: Mentor. Winner, Hub City Regional (3310 & 4063)
  #15   Spotlight this post!
Unread 05-01-2014, 14:55
AKA: Dick Ledford
That approach is legal, but only gives 10 points, since by definition a "catch" requires that the thrower and catcher be DIFFERENT partners on an alliance.
So only 10 points, but possession maintained, which has its own value.
-Dick Ledford
