Go to Post Dean looks rather debonaire in a tux. Like some sort of engineer super hero. The tuxedo is like his Clark Kent costume under which lies his amazing denim suit, to be whipped out at a moments notice in the face of uninspired youth and problems unconquered. - phrontist [more]
Unread 05-01-2014, 17:36
atucker4072's Avatar
atucker4072 atucker4072 is offline
Andrew Tucker
AKA: Andrew Tucker
FTC #4968 (Rapid Robotics)
Rookie Year: 2011
atucker4072 has a spectacular aura aboutatucker4072 has a spectacular aura aboutatucker4072 has a spectacular aura about
Ball eject
The issue has been raised that what happens if you have a ball in your robot but then have to e-stop or loose power.
What are teams thinking of doing incase this happens so you don't choke your alliance?
I was thinking have a system that any robot can hit your robot in a way so that it forces the ball to leave the system. So maybe a rod that is able to contact the ball regardless of where it is in or on the robot.
Unread 05-01-2014, 17:38
brandon.cottrell's Avatar
brandon.cottrell brandon.cottrell is offline
Vice President
FRC #1266 (The Devil Duckies)
Team Role: Leadership
Rookie Year: 2013
brandon.cottrell has much to be proud ofbrandon.cottrell has much to be proud ofbrandon.cottrell has much to be proud ofbrandon.cottrell has much to be proud ofbrandon.cottrell has much to be proud ofbrandon.cottrell has much to be proud ofbrandon.cottrell has much to be proud ofbrandon.cottrell has much to be proud ofbrandon.cottrell has much to be proud of
Re: Ball eject
While I do like Aerial Assist, this is something that kind of worries me about this game. Along with the autonomas shots missed, it's now easier to pinpoint exactly whose fault it was that a match was lost and why.
Unread 05-01-2014, 17:43
Andrew Tucker
AKA: Andrew Tucker
Rookie Year: 2011
Re: Ball eject
Thia will be a great test of gracious Professionalism! Although if teams meet before a match like they should lots of problems can be avoided. If I had to as a driver I wouldn't like a team to load a ball into their robot if they haven't tested it or been successful with it.
Unread 06-01-2014, 09:05
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Rookie Year: 1998
Mr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond repute
Re: Ball eject
A very BIG test of gracious professionalism
I'm not sure where to go with this aspect of the game.
I'm asking myself very seriously, if a robot can't automatically eject a ball when disabled, should it be allowed to intake it?
Autonomous is also very tricky - if your robot requires the ball to be inside your robot at the start of the match, and can't be easily freed by another robot, your alliance partners might ask you not to run it.
How would you feel if your alliance partners ask you never to pick up a ball? Or to not run your autonomous?
Would you ask your alliance partners not to do those things?
Because right now, this seems like the prudent thing to do.
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 06-01-2014, 09:57
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
FrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond repute
Re: Ball eject
The issue is the state "Estop" is really the same as disabled. So you load the ball in the disabled state (Robot is disabled until the match starts) Nothing will happen until the robot is enabled. The coders that can make the robot magically eject the ball on system failure aren't going to be the ones with these kinds of issues.
Scouting is going to be important this year (as if it was never unimportant) because a non functioning robot in the seeding matches can really skew the scores.
This might be the year that a good defense is a good offense.
Unread 06-01-2014, 10:30
JohnSchneider's Avatar
JohnSchneider JohnSchneider is offline
FRC #3310 (Black Hawk Robotics)
Rookie Year: 2010
JohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond repute
Re: Ball eject
It's a terrible enough feeling at a regional telling a team "Hey we need you to put this giant net on and sit there and not do what your robot was designed to do because of the nature of the game." I cannot imagine telling someone they cannot play the game in its proper form because "We don't trust your robot's design".
Heck, there are times when a team will just refuse and try it anyways and when the ball gets stuck then what do you do? The rules pertaining to this are not fair for any member of an alliance.
An E-Stopped robot with a ball most definitely should not have its ball counted. That way there's at least a way to keep playing the game for the other 2.
Unread 06-01-2014, 10:49
RSaunders RSaunders is offline
FRC #2537
RSaunders is an unknown quantity at this point
Re: Ball eject
Why wouldn't the referees consider a ball in an EStopped robot "out of play"? It's a good idea to raise this question in the Q&A, but software solutions aren't what you want when a simple human decision can solve your problem. That's what referees are for.
/Randy
Unread 06-01-2014, 11:40
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Ball eject
I would think a robot capable of taking action while disabled would be a safety hazard, violating R8.
Unread 06-01-2014, 11:47
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Rookie Year: 2011
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
Re: Ball eject
What about the robots in 2012 with the after-the-buzzer pneumatic bridge balancers?
2010: FRC 3043, Build Assistant
2011: FRC 3043, Head of Minibot subteam; FLL 12762, Team Captain
2012: FRC 3043, Electrical; FLL 12762, Team Captain; FTC 5670, Team Captain
2013: FRC 4301, Electrical, Team Co-Captain
2014: FRC 4301, Electrical/Programming, Team Co-Captain
2015: FRC 4301, Electrical/Programming, Team Captain
2016: FRC 4301, Chief Technical Officer; FTC 10860, 10861, and 11004: Mentor. Winner, Hub City Regional (3310 & 4063)
Unread 06-01-2014, 11:49
vhcook's Avatar
vhcook vhcook is offline
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
Re: Ball eject
You had to trigger the solenoid before the buzzer. Any after-buzzer activity was just the air pressure equalizing on a decision that had already been made.
Unread 06-01-2014, 13:51
Racer26 Racer26 is offline
Racer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond repute
Re: Ball eject
Not strictly true. You can have a single acting solenoid valve which spends the entire match energized, keeping your ball ejector retracted. As soon as the robot transitions to the disabled state (either commanded by the field at the end of a match, or because the robot lost communication) that solenoid will cease to be energized, and extend your ball ejector.
The trick is in figuring out a way to either A) make it so that during the pre-match disabled phase you can keep your ejector retracted (perhaps you use a dump valve connected to a servo to trap air strategically in the system that can later be released) OR B) pick the ball up at the start of auto instead of pre-loading it into your robot.
Unread 06-01-2014, 14:16
Dalrik Dalrik is offline
FRC #0639 (Code Red Robotics)
Rookie Year: 2010
Dalrik is an unknown quantity at this point
Re: Ball eject
This is probably what most teams are going to have to do. The corner case of a robot that crashes as soon as auton starts and thus never has time to arm an eject mechanism is one that I don't see a clear solution for. Then again, you have to waste part of your 5 second window for the hot goal picking up the ball...
Unread 06-01-2014, 16:30
tStano tStano is offline
AKA: Sparks
Team Role: Electrical
Rookie Year: 2012
tStano will become famous soon enough
Re: Ball eject
Single action solenoids are great but if you don't have pneumatics on your robot (and many teams don't), it shouldn't be necessary to add an entire pneumatic system for that.
Unread 06-01-2014, 19:49
GaryVoshol's Avatar
Cogito ergo arbitro
Rookie Year: 2000
Re: Ball eject
/Randy
A referee's job is to enforce the rules, not make up new ones. As much as we'd sometimes like to help out teams, we can't do so if the rules don't allow it. If the rules are amended to define a ball in an E-Stopped robot as field debris, we will so decide. If the rules remain as is, we can't do it.
(since 2004)
  #15   Spotlight this post!
Unread 05-01-2014, 17:49
Jhultink Jhultink is offline
AKA: Jaredt Hultink
FRC #2771 (Code Red Robotics)
Team Role: Mechanical
Rookie Year: 2012
Jhultink is a jewel in the roughJhultink is a jewel in the roughJhultink is a jewel in the roughJhultink is a jewel in the rough
Re: Ball eject
Then during alliance selection the best teams will be picked because it becomes more obvious who is good and who is not. I feel that rankings this year will not be as influential as they have been.
