Go to Post BEING a chairmans team is alot more important then WINNING the chairmans award. - fuzzwaz [more]
Unread 05-01-2014, 20:30
Falcon Falcon is offline
Ron Faulkner
AKA: Ron Faulkner
FRC #2451 (PWNAGE)
Rookie Year: 2010
Falcon is an unknown quantity at this point
E09_DRV_161213.7z Not Loading
We have the E09 classmate and I tried to re-image the classmate. Unfortunately, the tool stated that it could not find an image on the USB stick. If you open the RestoreDS.cmd file it has the following:
REM IMAGE MANIFEST
REM Edit file names HERE where applicable to match deployment files
REM
REM
REM ********************************
SET E09_Master=E09_2013_MASTER_09112012.wim
SET E11_Master=E11_2013_MASTER_09112012.wim
SET E12_Master=E12_2013_MASTER_09112012.wim
SET E09_CPP=E09_CPP_2013_251112.wim
SET E09_DRV=E09_DRV_2014_111113.wim
SET E09_JAV=E09_JAV_2013_261112.wim
SET E09_LAB=E09_LAB_2013_131212.wim
SET E11_DEV=E11_DEV_2013_271212.wim
SET E11_DRV=E11_DRV_2013_261212.wim
SET E12_DEV=E12_DEV_2013_091212.wim
SET E12_DRV=E12_DRV_2014_120913.wim
All I did was correct the E09_DRV value using WordPad and restart the USB load. Everything worked OK.
Unread 05-01-2014, 23:40
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: E09_DRV_161213.7z Not Loading
This was mentioned on the KOP website: http://www.usfirst.org/roboticsprogr...control-system
UPDATE 1/3/14: We discovered an error with the E09 Classmate Image. While we fix the image, here's a document on how you can correct the issue.
