Go to Post Trust me. I am a Clock after all. ;) - Elgin Clock [more]
Unread 05-01-2014, 21:08
yash101 yash101 is offline
Curiosity | I have too much of it!
AKA: null
Rookie Year: 2012
yash101 is an unknown quantity at this point
COTs part's question
There are some small computers like the Intel NUC. It would be classified as COTS unmodified. However, it is barebones and comes with no disk drives or RAM. That means you need to "modify" it by adding so-dimms and an mSATA ssd. Would this still be considered a COTS part?
Unread 05-01-2014, 22:12
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
Team Role: Teacher
Rookie Year: 2011
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
Re: COTs part's question
No. It is no longer COTS if someone cannot buy it, in that configuration, in a store, or online.
A COTS part that has been painted is considered "fabricated" because it is not available in that "configuration" to the general public. A COTS controller board, memory card, etc., are all COTS on their own. But once you slap them together they become a "fabricated" item.
Unread 05-01-2014, 23:29
Doc Wu's Avatar
Doc Wu Doc Wu is offline
AKA: Al Gritzmacher
FRC #1507 (Warlocks)
Doc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant future
Or do they become a collection of COTS parts? Can't anyone buy the HD and memory off the shelf?
-= Mentor Lockport Warlocks -=- Team 1507 =-
Amateur Radio Callsign: AE2T
2015 Robot Inspector - Pittsburgh, Champs. Judge Observer - Champs
2014 Robot Inspector - Tech Valley, Fingerlakes, Buckeye, Championship
2013 Robot Inspector - Fingerlakes, Buckeye, Championship
2012 Robot Inspector - Fingerlakes, Buckeye, Championship
2012 Website Evaluator - Fingerlakes, Buckeye, Championship
2011 Robot Inspector - Fingerlakes 2011 Safety Advisor - Fingerlakes
Unread 05-01-2014, 23:38
Redo91's Avatar
Redo91 Redo91 is offline
AKA: Justin
Redo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of light
These seems like it would be something that could be easily clarified by the Q&A when it opens on the 8th.
Team 1296-Full Metal Jackets
Alumni 2009
Mentor 2009-2014
Team 624-CRyptonite
Mentor 2014-2015
Unread 06-01-2014, 19:02
AKA: null
Rookie Year: 2012
It can be taken either way. The device was meant to be expanded. I doubt that you'd use a computer without RAM and a Boot drive! This is something kind of complicated and maybe Al could clarify this for us because he is part of the inspection team.
We aren't building the RAM modules ourselves, neither the disk drive, so we are technically not modifying the computer. Just pull out the ram, wifi, bt and disk and the computer will be exactly as out of the box.
By the way, how much could I get a CHEAP set of 4GB RAM that will work? This wouldn't require anything special. The same would go for the SSD. This isn't something we will be using daily, so a cheap ssd will most likely cut it. Otherwise, maybe I could boot from a flash disk!
Unread 06-01-2014, 19:45
FrankJ's Avatar
FrankJ FrankJ is online now
Robot Mentor
FRC #2974 (WALT)
FrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond repute
The components would all be considered COTs. The issue is how to power it. You either will need to power it from the robot battery or the battery will need to be self contained in the COTS computer.
Unread 06-01-2014, 21:10
AKA: null
Rookie Year: 2012
I was thinking of a 12v to 19v boost converter. I think it would be cots legal because it is external. It is just a vReg, so I am doubtful that any problems would be caused!
Unread 06-01-2014, 21:54
DonRotolo's Avatar
Back to humble
FRC #0832
Definitely a Q&A question.
Also, I think the CUSTOM CIRCUIT of a 12 - 19 V converter wouldn't be a problem.
Unread 06-01-2014, 22:04
techhelpbb's Avatar
techhelpbb techhelpbb is offline
FRC #0011 (MORT - Team 11)
Rookie Year: 1997
techhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond repute
In the past we fielded a Gateway netbook with added RAM.
The RAM modules are COTS. The Gateway netbook is COTS.
The COTS rules should also not prohibit repaired systems but I've not actually competition inspected a repaired laptop on a robot and I am very unclear on how anyone would know. I've repaired plenty of driver's station laptops that were used in competition.
We did remove the display and keyboard from that Gateway netbook we had on the robot and it was like that during inspection. You can't buy it COTS without the display and keyboard but through several inspections no one complained because it was properly enclosed and packed in foam blocks.
I have seen cRIOs that were repaired fielded.
Nothing stops FIRST from changing this around but we actually did this so it would be a change.
Unread 06-01-2014, 22:14
AKA: null
Rookie Year: 2012
Isn't that illegal? That involves opening the case of the cRIO!
Unread 06-01-2014, 22:18
techhelpbb's Avatar
Rookie Year: 1997
Think for a minute - how would you know?
What do think National Instruments does when they refurbish these things?
The issues of how do you detect tampering was part of the reason why when I helped to propose a 2015 control system I proposed a tool that would detect tampering and the altered operation. A proper repair does not alter the normal operation it restores it.
