Go to Post The only thing happy about ship day is the promise of sleep coming soon... - StephLee [more]
Unread 06-01-2014, 10:33
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
Lack of CV limit and what to do about it
How should one go about selecting a solenoid valve that has a higher cv limit?
What things should you look for when buying one?
I imagine, most teams have a similar knowledge base on this as I do. Which is, this is the solenoid we use because we have to. Now that we can select our own, what do we do?
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 06-01-2014, 11:47
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Lack of CV limit and what to do about it
First, what function does it need? Single, double, whatever.
Second, does it comply with the rules (e.g., 1/8" NPT input)?
Third, can you afford it?
Note that the 'regular valves we always used' are pretty good for the 0.160" ID tubing we get to use, having a significantly larger Cv isn't going to do much.
Unread 08-01-2014, 11:32
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Dad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud of
True, but there was an inexpensive valve (less than $40) that I recall finding a few years ago that we could not use because of Cv either being slightly higher or the spec was unavailable..... now if I could only remember where it was.....
This opens up a larger selection, and simplifies the documentation for teams and inspectors, with minimal change in performance.
