Go to Post I don't even care if it doesn't work as well as they would like. YOU MADE IT. You may never use it, but you made it. AWESOME. Every year there has been 1 team (sometimes 2) that has done something that really stood out. This year 1 team has done 2 things that stand out. Thanks guys. - rees2001 [more]
Unread 07-01-2014, 19:37
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: Mecanum wheels
Originally Posted by lcoreyl View Post
While as quoted these statements can both be true...
Please don't mis-quote me and then poorly attempt to make a counter-point which actually says something completely tangential to what the entire quote said.
GitHub
Unread 07-01-2014, 08:39
thefro526's Avatar
thefro526 thefro526 is offline
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
thefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond repute
Send a message via AIM to thefro526 Send a message via MSN to thefro526
Re: Mecanum wheels
There's a bit of mis-information in this thread, and while I don't want to join in the debate, I'd like to set the record straight for any of the newer teams that might be using this thread for information.
Mecanum Wheels can be purchased from two different FRC Suppliers.
- AndyMark http://www.andymark.com/Mecanum-s/53.htm
AndyMark's Mecanums were first released for the 2007 Season and have been evolving since then. They're offered in FRC relevant sizes of 6" and 8" with a Standard Duty and Heavy Duty version of each. The Pricing Varies from ~$250 for a set of 6" Standard Duty to in excess of $400 for a set of 8" Standard Duty.
- VexPro http://www.vexrobotics.com/vexpro/wh...um-wheels.html
VexPro's Mecanum Wheels are relatively new compared to AM's Mecanum Wheels, but have proven themselves to hold up reasonably well in the FRC Environment. They're a bit Cheaper than AM's Mecanum Wheels and rely on a primarily plastic construction in place of Metal.
As far as Mecanum's implementation in FRC, they're a decent way to make your drivetrain more maneuverable, as well as adding omni directional functionality within a traditional frame. The increased agility awarded by Mecanum wheels should allow you to move around traditional defense to the point where 'pushing' isn't necessarily required.
All of that being said, when comparing two similar drives, with the only difference being that one Uses Mecanum wheels in place of a traditional wheel, the Mecanum Drive will almost always have less traction than the traditional drive train. This is due in part to a couple of factors, the wheels always being in a constant state of slip (in that they're applying force in a non-fore/aft direction) being one of them, and the other being that each wheel's motor is independent. This means that if one of your wheels leaves the floor, or starts spinning, you're not only putting down the power of (3) motors.
-Dustin Benedict
2005-2012 - Student & Mentor FRC 816
2012-2014 - Technical Mentor, 2014 Drive Coach FRC 341
Current - Mentor FRC 2729, FRC 708
Unread 07-01-2014, 08:56
TedG's Avatar
TedG TedG is offline
CAD, Design & Graphics Support
AKA: Team supporter and enthusiast
FRC #0133 (BERT 133)
TedG will become famous soon enough
Thumbs up Re: Mecanum wheels
We have used Mecanum wheels the last 3 years with great success.
Great for manouvering in all directions without haveing to turn.
Last year we used the 6" dia heavy ones from AM and could push our way around as well as resist being pushed around. It helps if you have a heavy robot though.
And it's a good idea to buy a spare wheel or two, but they are expensive.
Bonny Eagle Robotics Team - BERT 133
2009-2010: Mentor, 2010-2013 Advisor/Mentor, 2013-Present: Mentor/Cad & Graphics Support
2010 - GSR: Excellence in Website Design
2011 - GSR: Motorola Quality Award
2012 - Mainely Spirit: Spirit Award, Human Player Award- GSR: Gracious Professionalism Award, Quarterfinalist- Beantown Blitz: Finalist
2013 - Mainely Spirit: Sportsmanship Award- GSR: Semifinalist, Woodie Flowers Award- PTR: Semifinalist- Beantown Blitz: Semifinalist
2014 - GSD: Spirit Award, 5th seed, Semi Finalists- PTD: 2nd seed, Finalists
2015 - Safety Animation 1st Place Award, PTD: Excellence in Engineering Award, 8th seed, Finalists, UNHD: Spirit Award, 9th seed, 6th seed Finalist Alliance Captain; Event Winner
2016 - NSD: Industrial Design Award, 3rd seed, Semifinalist- PTD: Excellence in Engineering Award, 2nd seed, Event Winner
Opinions expressed here are mine alone, and not necessarily of the team.
Unread 07-01-2014, 16:21
lcoreyl's Avatar
lcoreyl lcoreyl is offline
WittyTitleGen can't link to library
AKA: Milner
lcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud of
Re: Mecanum wheels
yes... yes there is...
I've linked a paper in my signature. In the paper is a link to a video showing the worms eye view of the contact patch of a mecanum wheel while being moved as it would in normal forward motion. The contact point doesn't slip. The rollers don't spin.
Unread 07-01-2014, 20:52
thefro526's Avatar
Mentor for Hire.
Re: Mecanum wheels
I don't want to debate this too much since it's going to derail the thread, but I'm still not convinced based on the two videos (Glass table, green backlighting) that the rollers do not spin under FRC conditions. Maybe I'm nit picking, but there seemed to be some sort of displacement of the roller (Looks like a few degrees at most) even on the table top test. At FRC speeds, something tells me that this has to add up into the rollers spinning while the robot is moving in standard fore and aft directions. It's been a few years since I've played with Mecanum wheels first hand, but if I remember correctly, rollered seemed to slip while under load.... But I might be wrong.
-Dustin Benedict
Unread 07-01-2014, 21:17
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: Mecanum wheels
They do spin somewhat under FRC conditions. The roller axial free play in the affordable COTS mec wheels typically used for FRC contributes to spinning. A compliant surface (like carpet) contributes to spinning. This is mentioned on page5 of his paper.
Unread 06-01-2014, 21:37
Keegbot's Avatar
Keegbot Keegbot is offline
AKA: Keegan McCrary
FRC #2438 (Beta Blues)
Rookie Year: 2012
Keegbot is an unknown quantity at this point
Re: Mecanum wheels
Originally Posted by jbsmithtx View Post
Try VEXpro. They have very affordable yet durable mecanum wheels. The other posters are correct in assuming that unless you are trying to catch, mecanums might not work well this year... However don't believe they are easy to push. We had to play defense with our mecanums last year in matches when our shooter failed and were fine. We could block lots of teams. I know this is contrary to popular belief, but a properly done mecanum drive base can in fact be very strong.
For anyone that wants to question our pushing abilites, we have video...
Our team used the VEXpro wheels last year, and I was very pleased with them. They lasted 2 competitions and multiple fundraisers until they started to fall apart. They are also quiet and light compared to the Andy Mark versions we have used in the past. We also had to be purely defensive in one competition and managed to place high because our mecanum drive allowed us to out-maneuver our opponents and get in front of them to block their shots.
Unread 06-01-2014, 22:03
Caleb Sykes's Avatar
Caleb Sykes Caleb Sykes is offline
FRC #4536 (MinuteBots)
Caleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond repute
Re: Mecanum wheels
I encourage anyone and everyone who thinks that they understand mecanum physics to read the whitepaper given here: http://www.chiefdelphi.com/media/papers/2759?
Unread 06-01-2014, 23:01
BEN35678's Avatar
BEN35678 BEN35678 is offline
Mentor
FRC #1523 (MARS)
Team Role: Mechanical
Rookie Year: 2012
BEN35678 is an unknown quantity at this point
Re: Mecanum wheels
Last year we used Andymark mecanum and this year we were looking at the vex pro mecanums, and a couple of our main mentors were worried about them cracking because they are plastic. Did you have anything that looked like it was about to crack or anything like that?
Unread 06-01-2014, 23:34
TheJoe's Avatar
TheJoe TheJoe is offline
AKA: Joe Neyhart
FRC #0279 (Tech Fusion)
Rookie Year: 2011
TheJoe has a spectacular aura aboutTheJoe has a spectacular aura about
Re: Mecanum wheels
Our team has used a mecanum drive train for the last three years and we've had a lot of fun with them.
As the robot driver for the past two years, I can assure you they're wonderful to control, and driving becomes a lot easier with mecanum.
Controlling the a mecanum-powered robot is a lot like moving a character in a first person shooter video game, which I'd assume many students are familiar with already.
Couple a mecanum drive train with gyroscope technology and now your robot can always move relevant to the driver (No matter the orientation), which in my personal opinion makes controlling the robot even easier.
While a downfall may be that you lose a lot of pushing power, the versatility gained to out-maneuver the defense matches said downfall quite well.
Unread 07-01-2014, 00:41
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Donut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond repute
Re: Mecanum wheels
Our VexPro mecanums have held up well. They survived one regional and some off season demos with no problems, and in our shop we typically run them on concrete. We are planning to use them again this year.
FRC Team 498 (Peoria, AZ), Student: 2004 - 2007
FRC Team 498 (Peoria, AZ), Mentor: 2008 - 2011
FRC Team 167 (Iowa City, IA), Mentor: 2012 - 2014
FRC Team 2662 (Tolleson, AZ), Mentor: 2014 - Present
Unread 07-01-2014, 09:56
purduephotog purduephotog is offline
Active Defense Design Engineer
AKA: Jason
FRC #3015
Team Role: Leadership
purduephotog is a jewel in the roughpurduephotog is a jewel in the roughpurduephotog is a jewel in the roughpurduephotog is a jewel in the rough
Send a message via AIM to purduephotog
Re: Mecanum wheels
Could anyone point me to resources about the maximum speed you can run Mecanum wheels at ?
I'm wondering (and trying) to find out if all the gear boxing is really necessary. Once they're slipping they're slipping, and the friction factor for all four wheels would be ~equal.
http://purduephotog.deviantart.com
Portrait Photography: "I used to say Immortalized in Silver, but now I say Captured and Squeezed by Electrons".
Unread 07-01-2014, 10:11
Ether's Avatar
Rookie Year: 1969
Re: Mecanum wheels
What do you mean by "slipping" in this context?
Unread 07-01-2014, 10:16
JesseK's Avatar
FRC #1885 (ILITE)
Re: Mecanum wheels
Can anyone speak to the wear of VEXPro 4" Mecanum rollers compared to the 6" wheel rollers over the course of multiple competitions?
In an average year we compete in 2-3 official and 2 off-season competitions, perform in several demos & run a lot of driver practice for the next year's team. So the wheels really need to last. Yet it'd be nice to know what spare parts to get ahead of time (i.e. 1 set of spare rollers per 1 event or 2 events?) when comparing wheels. If we have to replace the 4" wheel's rollers every 1 event, we may go the 6" route so we don't have rollers that are wearing thin at the end of an event.
My team's poking at the idea of Mecanum for a few reasons, and it's easy to implement on our current drive frame.
About Mecanum in general:
The only thing I can say without reading a metaphorical earful from Ether (ha, hi Ether) is that the default field-centric (or robot-centric with no deadband) control algorithm robs the drive train of power just by the nature of the code. When translating on the 45-degree relational diagonal (i.e. 0 degrees = full forward, 90 degrees = full right, so at 45 degrees the bot goes forward & right), 2 motors are completely turned off by the algorithm.
If we implemented Mecanum, we'd most likely do a dual-mode driver control. In the first mode, it'd be field-centric holonomic drive. In the 2nd mode, the driver would be limited to robot-centric tank drive with 90-degree strafing. The driver would be in the 2nd mode most of the time.
GitHub
  #15   Spotlight this post!
Unread 07-01-2014, 12:17
Ether's Avatar
Rookie Year: 1969
Re: Mecanum wheels
Hi Jesse :-)
Yup. And so the available driving torque at the wheels to keep the bot moving against the rolling resistance is half. And so the top speed in that direction will be substantially less than that predicted on the basis of kinematics assuming no load.
What driver interface do you have in mind for this? Perhaps divide this 2nd mode into 2 modes?
Mode 2a: Standard 2-joystick Y-axis-only tank drive (X-axes disabled)
Mode 2b: Right (or left) X-axis commands strafe (disable Y-axes)
