Iterative Robot - Need Help!!!
Hi,
This code is iterative robot template based. If you can spot something that is wrong in the code below, please let me know so I can fix the error. Suggestions would also be nice. Will this code work for the following functions: 1. Mobility 2. Moving wheels through motors 3. Pneumatics -> Piston Also, for function #3, I know I have two instances of the code. One is the relay version and the other is the solenoid version. Which one do I use? Also, I'd appreciate it if anyone can look over the parameters to see if they are correct in the constructors. Here is the code: Code:
package edu.wpi.first.wpilibj.templates;
import edu.wpi.first.wpilibj.Compressor;
import edu.wpi.first.wpilibj.Jaguar;
import edu.wpi.first.wpilibj.Relay;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.Solenoid;
import edu.wpi.first.wpilibj.Victor;
public class RobotTemplate extends IterativeRobot {
int joystickPort = 1;
int leftMotorChannel = 2;
int rightMotorChannel = 1;
int pressureSwitchChannel = 1;
//The GPIO channel that the pressure switch is attached to.
int compressorRelayChannel = 1;
//The relay channel that the compressor relay is attached to.
int relayModuleNumber = 1;
int relayChannelNumber = 2;
int victorOneChannel = 3;
int victorTwoChannel = 4;
RobotDrive theRobot = new RobotDrive(leftMotorChannel, rightMotorChannel);
Joystick driveStick = new Joystick(joystickPort);
Compressor mainCompressor = new Compressor(pressureSwitchChannel, compressorRelayChannel);
Relay spike = new Relay(relayModuleNumber, relayChannelNumber);
Victor wheelOne = new Victor(victorOneChannel);
Victor wheelTwo = new Victor(victorTwoChannel);
//if relay doesn't work - use this:
Solenoid pistonExtract = new Solenoid (1);
Solenoid pistonRetract = new Solenoid (2);
public void robotInit() {
mainCompressor.start();
// will fill later
//variables expected to update periodically
double moveValue = driveStick.getAxis(Joystick.AxisType.kY);
double rotateValue = driveStick.getAxis(Joystick.AxisType.kX);
theRobot.arcadeDrive(moveValue, -rotateValue); //robot driving
double speed = 1.0; //adjustment back of joystick
if (driveStick.getTrigger()) { //shooter wheels
wheelOne.set(speed);
wheelTwo.set(speed);
}else{
wheelOne.set(0.0);
wheelTwo.set(0.0);
//one variation to work with piston
if (driveStick.getRawButton(3)) { //top-middle button
spike.setDirection(Relay.Direction.kForward);
} else if (driveStick.getRawButton(4)) {
spike.setDirection(Relay.Direction.kReverse);
}else{
spike.set(Relay.Value.kOff);
//which one to choose?
//second variation to work with piston
if (driveStick.getRawButton(5)) {
pistonExtract.set(true);
pistonRetract.set(false);
}else if (driveStick.getRawButton(6)) {
}else{
pistonExtract.set(false);
public void testPeriodic() {
