Go to Post Engineers talk with math first, and grammar second. It is a fact of life. - Molten [more]
Thread Tools Rating: Thread Rating: 10 votes, 5.00 average. Display Modes
Unread 08-01-2014, 00:13
jee7s jee7s is offline
Texan FIRSTer, ex-frc2789, ex-frc41
AKA: Jeffrey Erickson
FRC #6357
Rookie Year: 1997
jee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond repute
Re: Legal compressors?
Originally Posted by DonRotolo View Post
FWIW, it isn't the motor that gets so hot, it is the compressor cylinder (head & piston).
Yeah, I know its not the motor. I was typing too fast on that one.
2013 Alamo Regional Woodie Flowers Finalist Award Winner
2012 Texas Robot Roundup Volunteer of the Year
Texas Robot Roundup Planning Committee, 2012-present
FRC 6357 Mentor, 2016-
FRC 2789 Mentor, 2009-2016 -- 2 Golds, 2 Silvers, 8 Regional Elimination Appearances
FRC 41 Mentor 2007-2009
FLL Mentor 2006
FRC 619 Mentor 2002
FRC 41 Student 1998-2000
Unread 07-01-2014, 16:05
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
I'm curious which one 254 uses. It's similar in appearance and size to the standard small Viar, but distinctly different.
Unread 07-01-2014, 16:07
FRC #6357
Rookie Year: 1997
Viair has a few options that comply with the rules:
http://www.viaircorp.com/c-models.html
We get the 90C as part of FIRST Choice, my team uses the 92C, and that 95C seems to have a different motor. Perhaps that's the 254 compressor?
FLL Mentor 2006
FRC 619 Mentor 2002
Chexposito's Avatar
Chexposito Chexposito is offline
AKA: Expo
FRC #1730
Rookie Year: 2007
Chexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of light
R79
Compressed air on the ROBOT must be provided by one and only one compressor. Compressor specifications may not exceed nominal 12VDC, 1.05 cfm flow rate.
Pretty much any compressor that fits that criteria.
Edit: NVM posted while I was posting.
Unread 07-01-2014, 16:09
Nirvash's Avatar
Nirvash Nirvash is offline
AKA: Bryan
FRC #4676
Rookie Year: 2011
Nirvash has a spectacular aura aboutNirvash has a spectacular aura about
From what I see,
4.10.4 R77
The only pneumatic system items permitted on 2014 FRC ROBOTS include the items listed below.
A. Items available in the 2014 KOP,
J. Compressors compliant with R79.
Which is
4.10.6 R79
So yes, you can use a different compressor, assuming it meets those specs.
However, I am more curious HOW you have gone through three compressors now, while the VIAIR may not be a workhorse of a compressor, it should last a lot longer then that. Are you running your compressors for extended periods of time without active cooling on them (A fan cooling the compressor head)?
(And took too long to post, didn't I?)
Team 3488 - Electrical Lead/Programming Lead 2011-2013
Team 4676 - Electrical/Programming Mentor 2013-Present
