FIRST Button on WindRiver not appearing
Let me start from the beginning, back in 2013 I accidentally forgot to uninstall WindRiver from the previous year before installing the 2013 version of WindRiver. I was able to fix it somehow(I don't remember how though) but whenever I tried to uninstall it through the Windows control panel, I would get error:NULL. What I did next this year was delete the WindRiver directory and the WindRiver folder found in C:\Program Files\Common Files\InstallShield\Universal because that was a solution that another FIRST member found in this thread.
I then proceded to install WindRiver using both discs since the laptop I am using is running Windows 7. I did not open WindRiver between installing each disc. After I installed each disc, I then installed the mandatory C++ update or the workbench update. After doing this multiple times I have not been able to get the FIRST button to appear on the toolbar on the laptop even though I was able to get it on my desktop. Last edited by mega900997 : 07-01-2014 at 23:02. |
Re: FIRST Button on WindRiver not appearing
Password: 3Zones2Goals1Alliance! |
Last year we had more problems with this. There are half a dozen threads on chief delphi about the missing FIRST menu but I can't recall what fixed it for us.
I want to say it may have been a 32bit/64bit mismatch. Are you running 64 bit or 32 bit? When I setup a new computer today I only did the first disk. No LabView and then installed the update and all was well. You might try deleting everything again. Run a registry cleaner like CCleaner and then do the install. Or go through the registry searching for Windriver and deleting entires associated with it and do the install again. I'm sorry I couldn't be more help. |
