Go to Post Begging, yelling, kicking, and screaming for members of my team to send me updates while I'm at college not doing homework. - Ginger Power [more]
Unread 08-01-2014, 02:13
JimWright949's Avatar
JimWright949 JimWright949 is online now
The Owen Day of Seattle
AKA: Jim Wright
FRC #4542 (Titanium Talons)
JimWright949 is a splendid one to beholdJimWright949 is a splendid one to beholdJimWright949 is a splendid one to beholdJimWright949 is a splendid one to beholdJimWright949 is a splendid one to beholdJimWright949 is a splendid one to beholdJimWright949 is a splendid one to behold
Error: Unable to load C:/WindRiver/WPILib/cRIO_Images/FRC_2014_v52.zip
Hello all,
I'm having a really odd problem. I've installed the 2014 Imager and Windriver 3.3 packages. I've then re-image my cRio with FRC_2014_v52.zip. Everything looks good on the cRio side.
I then open up the IDE and try to create a Remote System. I'm using these settings:
Processor: MPC5200
Backend:wdbrpc
Address:10.45.42.2
Port:<blank>
File:C:\WindRiver\WPILib\cRIO_Images\FRC_2014_v52. zip
Options:-R C:/WindRiver/workspace -RW -Bt 3
When I try to connect to the server I get:
Tue Jan 07 23:10:50 2014
Target name is 10.45.42.2
tgtsvr (VxWorks6x_10.45.42.2@Jim-PC): Tue Jan 07 23:10:50 2014
Wind River Target Server for Workbench 3.3.1
WTX Library version: 4.2.0.46
Tgtsvr core version: 4.2.0.40
Wind River Target Server: Win32 version
Connecting to the target agent ...
... switching to WDB4 mode ... ... succeeded !
Loading plug-in for VxWorks... succeeded.
Checking License... OK
VxWorks plugin version: 4.2.0.32
Attaching elf OMF reader for PPC CPU family... succeeded.
Error: loading core symbol table: status = 0x610001
Error: Unable to load the kernel image into the target server.
Error during target server core initialization
Target Server will exit
I'm not sure what I'm doing wrong. I've set up C++ for several years but for some reason I can't set this one up.
Has anyone seen this before?
-Jim
Unread 08-01-2014, 03:05
RufflesRidge RufflesRidge is offline
RufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant future
Re: Error: Unable to load C:/WindRiver/WPILib/cRIO_Images/FRC_2014_v52.zip
That's not the right file. See Step #2 below "Specifying the target server options" here: http://wpilib.screenstepslive.com/s/...-robot-program
Unread 09-01-2014, 01:29
AKA: Jim Wright
Ahh yes, thanks that did it.
Unread 25-01-2014, 13:49
jnettleton jnettleton is offline
FRC #2501
jnettleton is an unknown quantity at this point
I reimaged the cRIO and cRIOII with FRC_2014_v52.zip. Now I'm getting a "wrong core file" error message. Where can I find updated "cRIOFRC_vxWorks" and "cRIOFRCII_vxWorks" image files?
Unread 26-01-2014, 10:22
In the updated C++ Workbench update: http://wpilib.screenstepslive.com/s/...c-c-components
