Go to Post In theory, this should work... Oops. - Eldarion [more]
Unread 08-01-2014, 15:15
apples000's Avatar
apples000 apples000 is offline
Rookie Year: 2012
apples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant future
Placing a Tank after a solenoid valve
So our team's planning on using pneumatics to launch the ball, but as others have noted, there's not enough flow rate. So, what we do is lock down the cylinder, open the solenoid valve which fills a small tank, then unlock the cylinder. However, the team is convinced it's illegal, but I can't really find any rules saying you can't. Has anybody else done this before?
Unread 08-01-2014, 15:22
Team 4057 Team 4057 is offline
FRC #4057 (Klamath Basion Robotics)
Team Role: Leadership
Team 4057 is an unknown quantity at this point
Re: Placing a Tank after a solenoid valve
so long as you don't use multiple solenoids you look ok to me. the rule your team mates are talking about refers back to previous years that prohibits long runs of tubing to gain extra air storage.
Unread 08-01-2014, 15:27
Wire Monkey Wire Monkey is offline
FRC #0384 (Sparky 384)
Team Role: Electrical
Rookie Year: 2011
Wire Monkey is an unknown quantity at this point
It looks like R78 says you can't.
If pneumatic COMPONENTS are used, the following items are required as part of the pneumatic circuit and must be used in accordance with this section, as illustrated in Figure 4-15.
The drawing has the tank before the solenoid. IF the rule says it must be done EXACTLY like this picture then I don't think it is legal.
Unread 08-01-2014, 15:38
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Rookie Year: 1999
Madison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond repute
The following is a schematic of the pneumatic system we used in 2012 for our catapult. It was, of course, completely legal and did have storage tanks on the low-pressure side of the system.
http://www.chiefdelphi.com/forums/at...9&d=1330055105
We did use a valve between the storage tanks and the cylinder, so the implementation you're suggesting is a little bit different. I can't speak to the legality of impeding the motion of a cylinder mechanically, though there doesn't appear to be any rule prohibiting that at a quick glance.
--Madison--
...down at the Ozdust!
Like a grand and miraculous spaceship, our planet has sailed through the universe of time. And for a brief moment, we have been among its many passengers.
Unread 08-01-2014, 15:50
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
FrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond repute
So the picture does not show cylinders or solenoid valves?
Figure 4-17 shows a low pressure accumulator.
A little heavier, but unquestionably legal: Use a cylinder with a longer stroke than is required & don't retract it fully.
Unread 08-01-2014, 15:55
BBray_T1296's Avatar
BBray_T1296 BBray_T1296 is offline
I am Dave! Yognaut
AKA: Brian Bray
FRC #1296 (Full Metal Jackets)
Rookie Year: 2010
BBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond repute
Lets take this by the rules:
R74: Pass, parts are legal
R75: Pass, tanks are rated for 125+PSI
R76: Pass, parts are unaltered
R77: Pass, parts are legal
R78: Pass, this rule lists the parts of a pneumatic circuit, but not in any specific order
R79: N/A not a compressor
R80: N/A not a compressor
R81: Pass, not operating above 120PSI
R82: Pass, beyond the primary regulator, and working at or below 60PSI
R83: Pass, though white-listed to be useable in 120PSI, not specifically required to be there
R84: N/A not a pressure gauge
R85: N/A always on-board
R86: Pass operating at 60PSI or less
R87: N/A not a relief valve
R88: N/A not a pressure switch
R89: N/A not a vent plug
R90: Pass, operating on a single solenoid
No blue boxes are applicable either.
So, since this passes all applicable rules related to pneumatic, I say it IS legal
If molecular reactions are deterministic, are all universes identical?
RIP David Shafer: you will be missed
Unread 08-01-2014, 22:17
DonRotolo's Avatar
Back to humble
FRC #0832
Consider alternative ways of 'assisting' your cylinder's extension with, say, latex tubing.
EDIT: If you place a storage tank after a solenoid valve, will THE one Pressure Vent Plug reliably vent all stored pneumatic pressure from the system when the release valve is opened? If not, R89 will be violated.
Unread 08-01-2014, 23:48
MechEng83's Avatar
MechEng83 MechEng83 is offline
Lead Mentor/Engineer
AKA: Mr. Cool
FRC #1741 (Red Alert)
Team Role: Coach
Rookie Year: 2011
MechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond repute
The pneumatic valves from FIRST Choice last year (and possibly this year, as I don't have access due to school STILL being closed... ) violate this rule. The valves have a neutral position, which means that unless the solenoid is active, the pressure from both sides is dead-headed. This is different behavior from the KoP valves from several years ago.
2016 INWLA GP| INWCH Entrepreneurship | INPMH DCA | INCMP Team Spirit | CAGE Match Winner (w/ 1747 &868), Finalist (1471 w/ 1529 & 1018), Best Fans
2015 ININD Judges Award, Proud "Phyxed Red Card" alliance partners of 1529 & 1720 | INWLA EI | INCMP GP
2014 Boilermaker Creativity | Chesapeake Finalist, Safety, GP, Entrepreneurship | IN State Championship Winner (w/ 868 & 1018) | CAGE Match Winner (w/ 1024, 5402 & 1646)
2013 Boilermaker RCA, Innovation in Controls, Finalist | Crossroads Entrepreneurship | Newton Semi-finalist
2012 Boilermaker Entrepreneurship | Queen City EI | Curie Semi-finalist
2011 Boilermaker RCA, Entrepreneurship
Red Alert Robotics
Unread 13-01-2014, 13:06
KevinG KevinG is offline
Chesapeake LRI/Friendly Giant
AKA: Kevin
FRC #3650 (RoboRaptors)
Rookie Year: 1998
KevinG is just really niceKevinG is just really niceKevinG is just really niceKevinG is just really nice
Why would the amount of air located on one side of the solenoid valve matter? There's 60 psi of air contained within the tubing, and that has to vent just as reliably as air contained in accumulators.
Unread 13-01-2014, 13:23
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
Rookie Year: 2011
ToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond repute
It's our opinion that as the rules are written, an accumulator downstream of the solenoid valve is legal. If a QA answer rules this out, it is legal to connect multiple cylinders to a single valve. Just pick one with the internal volume of the tank you want, and plug one of the ports. Viola, instant accumulator. Not as weight efficient as a tank, but performs the same function.
Or, as someone else mentioned, pick a cylinder with a large internal volume and only plan to use half (or less) of the stroke. (This is actually the most weight efficient solution of all.)
Todd F.
mentor, FIRST team 2363, Triple Helix
Photo gallery
video channel
Triple Helix mobile
Unread 13-01-2014, 13:25
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
R89
The pressure vent plug must be:
A. connected to the pneumatic circuit such that, when manually operated, it will vent to the atmosphere to relieve all stored pressure, and
B. placed on the ROBOT so that it is visible and easily accessible.
If the compressor is not used on the ROBOT, then an additional pressure vent plug must be connected to the
high-pressure portion of the pneumatic circuit off-board the ROBOT with the compressor (see R79).
Air pressure in a storage tank is "stored" in the rule above.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 13-01-2014, 13:47
FrankJ's Avatar
Robot Mentor
FRC #2974 (WALT)
So using the accumulator as described is OK as long as the vent valve will release its pressure?
Unread 13-01-2014, 15:25
Unsung FIRST Hero
Rookie Year: 1996
I have to ask the OP to be sure...
OP, You are using a valve to charge a tank and operate a cylinder in the same circuit? Is that what I am reading?
Madison,
In looking at your drawing, I do not see how the stored pressure can be vented immediately by opening the manually operated valve. Should there be a failure in either of the regulators, opening the valve leaves high pressure air still in the tanks. While that may have passed inspection at your events in 2012, I do not think it was legal in 2012 or now.
Please ask the question of the Q&A.
Al
WB9UVJ
www.wildstang.org
Unread 13-01-2014, 15:27
Madison's Avatar
FRC #0488 (Xbot)
Rookie Year: 1999
Madison,
Al -- Unfortunately, pneumatics isn't my area of expertise, so I can't provide a definitive answer for your concern. I do know, however, that we were able to vent all the pressure from the system with the single release valve. I'll ask the folks who were responsible for this to provide some clarification. It may be that the system was changed after this schematic was created.
-Madison
--Madison--
  #15   Spotlight this post!
Unread 13-01-2014, 15:47
gpetilli gpetilli is offline
FRC #1559
gpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to all
Madison,
I too am not an expert, but I believe the standard FRC solenoids use a supply "pilot" which means that if the input air pressure goes away (think manual dump) then the solenoid opens allowing the output air to back through the output to the input. This works only if there are no check values in the system and does not depend on any electrical signals. We have had issues in the past that if the working pressure is too low, there is not enough energy to "engage the pilot" and the solenoid does not activate. If I am correct, then this would allow the low pressure storage tank to vent when the manual release is opened.
