Go to Post Basically: engineering is fun. - Mike [more]
Unread 08-01-2014, 23:29
alectronic alectronic is offline
no team (Volunteer)
Rookie Year: 2007
alectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant future
Re: 2008 vs 2014 Ball
Originally Posted by Animal Control View Post
the size if different and the height is a different requirement but for exact details read manual.
That isn't very helpful...
Going back to 2008:
Originally Posted by 2008 Manual 6.3
The game pieces, known as “TRACKBALLS,” are large balls made of an inflatable plastic bladder and an outer fabric covering. When inflated, each TRACKBALL is approximately 40 inches in diameter, and weighs approximately 7.3 pounds.
Additionally:
Originally Posted by 2008 Manual 10.2.8.1
The 2008 Trackballs require some care in assembly and inflation. Each Trackball consists of two parts: a Bladder and a Cover. The bladder has a 120cm diameter and is made of 2500g PVC.
Originally Posted by 2014 Manual 2.2.9
The BALLS are approximately 2 ft. diameter exercise BALLs with 6-panel 400D nylon red or blue covers. They are manufactured by Sportogo. BALLS are inflated per guidelines provided in the 2014 BALL Inflation Guide.
Looks like they are about 16" (diameter) smaller, as well as being about half the weight.
You can check out additional posts from the past by using the search option to look for "trackball", "overdrive", etc.
Good luck.
