Go to Post You and I have never met, but I am certain that if we went to the same school, we would have been good friends. - Molten [more]
Unread 09-01-2014, 12:55
TBolas TBolas is offline
FRC #4201
TBolas is an unknown quantity at this point
LabVIEW voltage measurement?
Hello.
I have just started working with LabVIEW and had a question on voltage measurement, namely is it possible? When looking online at tutorials there were a surprisingly few, and all required the NI MyDaq which my team currently doesn't have. Is there any way to measure the output voltage of a circuit in LabVIEW?
Thank you,
Theodore Bolas
Unread 09-01-2014, 13:28
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: LabVIEW voltage measurement?
Within +/- 10 V input range you can measure voltage through an analog input.
If your circuit has a higher voltage, then you'll have to add additional circuitry to bring the voltage into the rated range.
The battery voltage is also measured this way, but is knocked down to the more limited voltage range first.
Unread 09-01-2014, 13:41
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
This document shows a quick run-through of the WPI Library for LabVIEW, which shows the FRC libraries. https://decibel.ni.com/content/docs/DOC-14708 To expand on what Mark said, you would use the Analog Channel Vis.
There are many more examples built into the LabVIEW example finder. Look under the category FRC, and also at http://www.ni.com/frc.
