Go to Post we've got three years to perfect it. And then... who knows? - Amanda Morrison [more]
Unread 09-01-2014, 14:48
domingocool domingocool is offline
Programmer
FRC #4645 (X-Machina)
Rookie Year: 2012
domingocool is an unknown quantity at this point
Exclamation Problem Imaging cRIO to v52
So we have been trying to image the cRIO with the 2014 imaging tool but it keeps giving the error shown:
We reset the cRIO and removed and re installed the software. I'm not sure what else there could be or what the error means.
Last edited by domingocool : 09-01-2014 at 14:49. Reason: Added top of the error dialog
Unread 09-01-2014, 14:53
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: Problem Imaging cRIO to v52
Have you tried the troubleshooting steps listed here: http://wpilib.screenstepslive.com/s/...ging-your-crio
Unread 09-01-2014, 15:13
Programmer
Rookie Year: 2012
I've tried the steps and it still throws the same error. The only thing that happens is that once in a while I see this happen:
The only thing is that the new image(v52) is not applied. If I give it another go after that, it shows the error message again.
Unread 09-01-2014, 16:39
Kevin Phan's Avatar
Kevin Phan Kevin Phan is offline
College Student
FRC #0357 (Royal Assault)
Rookie Year: 2010
Kevin Phan will become famous soon enoughKevin Phan will become famous soon enough
Do you still have the console out soft-switch on when you tried to reformat the cRIO?
Unread 09-01-2014, 16:42
Programmer
Rookie Year: 2012
Yea the Console Out is on.
Unread 09-01-2014, 16:53
Kevin Phan's Avatar
College Student
Rookie Year: 2010
Can you try reformatting the cRIO with that switch off, when I was beta testing rebound rumble's LabVIEW version, it interfered with us reformatting the cRIO.
Unread 09-01-2014, 17:15
Programmer
Rookie Year: 2012
Ok so now what it's doing is going through everything but gets stuck at Rebooting.
Unread 09-01-2014, 17:19
Kevin Phan's Avatar
College Student
Rookie Year: 2010
Can I see a screenshot of said rebooting. The rebooting takes a relatively small time, but it depends on what you are seeing.
Unread 09-01-2014, 20:31
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
You say you've done everything in the troubleshooting list, but let's focus on a couple of common problems directly.
Do you have your network adapter's IP address set properly? It should be 10.46.45.x, where x is either 5 (if you're using the Driver Station computer), 6 (the typical programming computer address), or something 10 or higher.
You should also make completely certain that no other network adapters are enabled on your computer. Don't just turn off the wireless network radio; actually go into the networking configuration and disable the adapter.
