Go to Post Some said the aluminum foil gave the robot a NASA-like quality, but others pointed out that blanketing components with a highly-conductive material that blocked air flow was probably not going to help get us to Einstein. - beerobber [more]
Unread 09-01-2014, 21:54
whileloop whileloop is offline
None #2638
whileloop is an unknown quantity at this point
Wink About how fast in m/s is VEX 2 CIM BALL SHIFTER with 36:12 gear ratio?
I need an idea of how fast this transmission will allow the robot to go. Thank you .
http://www.vexrobotics.com/ball-shifter.html
Unread 10-01-2014, 12:21
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: About how fast in m/s is VEX 2 CIM BALL SHIFTER with 36:12 gear ratio?
Unfortunately, it's not that simple. What wheel size?
Here's JVN's calculator for quick-n-dirty estimations:
http://www.chiefdelphi.com/media/papers/2755
GitHub
Unread 10-01-2014, 13:31
Popmaster288's Avatar
Popmaster288 Popmaster288 is offline
AKA: Tim Pop
FRC #0687 (Nerd Herd)
Team Role: Mechanical
Rookie Year: 2012
Popmaster288 is an unknown quantity at this point
Ok. First of all, this is a VEX Pro Ball shifter we're talking about. It's got two speeds. I'm assuming you're looking for the the speed when you're in the higher gear. Also, I've checked their website, and I don't see a 36:12 reduction (which is really just 3:1). But I'll give you the speeds of different wheel sizes of that anyway and show you how to find out yourself. The CIM motor at max power runs at about 2600 RPM. When you give a 3:1 reduction on that, the output RPM becomes about 870. By getting the Circumference of your chosen wheel, you can figure out the distance traveled in one rotation. Multiply that distance by the number of rotations in a minute (870). Then divide by 60, because there's 60 seconds in a minute, and your desired unit of measure is m/s.
I'll give you the speeds of a robot that has 4", 6", or 8" diameter wheels.
9.2 m/s for a 4" wheel
13.8 m/s for a 6" wheel
18.5 m/s for an 8" wheel
Now these speeds are pretty darn high. Realistically, the CIM motor won't be running at 2600 RPM to begin with. You have to account for weight of the system and loss of efficiency due to gears and sprockets. Also, the larger the wheel, the tougher it is on the motor to spin it. After all this is taken account of, you might be looking at something closer to half the speeds of what I gave you.
I hope this helped you. Maybe someone else can elaborate more on this or correct me if I'm wrong anywhere.
Unread 10-01-2014, 13:52
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Originally Posted by Popmaster288;
1325065The CIM motor at max power runs at about 2600 RPM...Realistically, the CIM motor won't be running at 2600 RPM to begin with....After all this is taken account of, you might be looking at something closer to half the speeds of what I gave you.
CIM free speed is either 5310 or 5500 rpm depending on what spec sheet you look at (the vex spec on the website is 5310) and your robot could go as fast as 90% of that speed. Peak power is at half of free speed (and half of stall torque, as torque is inversely proportional to speed).
The gear ratios for the vex pro shifter you listed are 12:40 on the input (motor to first stage) then 40:44 high and 24:60 in low gear. I'm not sure where the previous poster got 12:36 from.
With a 4" wheel I get 7.77 m/s with no speed loss (5310 motor rpm). That's 25 ft/s and very very very fast.
Kettering Motorsports
