Go to Post Are quadcopter rotors considered a pneumatic device? - bobbysq [more]
Thread Tools Rating: Thread Rating: 4 votes, 4.50 average. Display Modes
Unread 10-01-2014, 07:23
Gadeer Zbedat Gadeer Zbedat is offline
FRC #1946 (Mishka Monster)
Rookie Year: 2012
Gadeer Zbedat is an unknown quantity at this point
Is the CIM COOLER Good for use?
what is the pros and cons for using the cim cooler?\
please reply me !
Unread 10-01-2014, 08:13
yash101 yash101 is offline
Curiosity | I have too much of it!
AKA: null
Rookie Year: 2012
yash101 is an unknown quantity at this point
Re: Is the CIM COOLER Good for use?
Well, it is forced-air-cooling and the fan won't stall when the motor stalls, so it seems to be quite genius of a design. However, I haven't tested it.
The only problem I see is that since it enclosed the CIM, I think it may block off the radiation waves (don't be scared of that ), to cool down. I think that might make it less effective in cooling itself down.
CIM's don't necessarily run too hot. Our drive motors don't have heat sinks. I haven't seen a single one overheating. However, that could be because we are using mecanum so the motors keep moving even if the robot is stalled, another pro for mecanum!
Unread 10-01-2014, 09:19
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
Team Role: Coach
Rookie Year: 2010
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
I think you are thinking of the "Ice Box" for 775 style motors. That is a powered fan and full enclosure for the motor.
The CIM cooler is just an aluminum heat sink that attaches on to the outside of a CIM motor. It will definitely make it easier to remove some heat by adding surface area, but it also takes up some space and weight. We have never needed to cool our drive motors and have never noticed a loss of power from not doing so. However, there could be some advantage to it if you were dependent on consistency in drive (i.e. moving forward for a set time in autonomous rather than using encoders). That being said, our CIMs get hot to the touch and taking some heat off of them is on our list for this year, just not very high on that list.
Honestly we might just use a few of the fans out of our pile of collected fans if we have time.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
There were two coolers in the kit:
-The 'ice chiller' blue 550/775 cooler, which is a great looking design as the motor is open, allowing air to pass through the motor and cool the hot parts (esp. the armature).
-The CIM heat sink, which looks like a piece of extruded aluminum.
The CIM heat sink will do relatively little to cool the CIM as there is almost nothing in the CIM to transfer the heat from the armature (which spins) and the case (which does not spin). I like to look at This Data for an example of how different the internal temperature is. As you can see in the first PDF the brush guide temperature (green) is way hotter than the case temperature (orange) over the period of a match, and stays hotter for almost 20 minutes of heat soak.
That said, I have seen benefit to fan cooling CIM motors for longer periods of time on practice robots. Some teams that I know build a simple fan holder that sits somewhere on their robot (they hang it from the bumper with the robot tipped on it's side) to cool the CIMs when the robot is not on the field.
It's not that the CIM does not run hot, it's that you can't feel it on the outside.
Kettering Motorsports
Unread 10-01-2014, 09:52
MichaelBick MichaelBick is offline
FRC #1836 (MilkenKnights)
Rookie Year: 2010
MichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant future
Based on our experience, we've had CIMs run really hot during practice. Our conditions were a bit more extreme than most. We were geared for 18fps, and after about 15 - 20 minutes of practice the CIMs would get really toasty, noticeably affecting performance. Fans really helped us in this situation.
Team 1836 - The Milken Knights
2013 LA Regional Champions with 1717 and 973
2012 LA Regional Finalists with 294 and 973
To follow Team 1836 on Facebook, go to http://www.facebook.com/MilkenKnights
To go to our website, go to http://milkenknights.com/index.html
Unread 12-01-2014, 21:06
Doc Wu's Avatar
Doc Wu Doc Wu is offline
AKA: Al Gritzmacher
FRC #1507 (Warlocks)
Doc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant future
In a 2-3 minute match, the CIM motors don't have time to get very hot. What we've noticed is that the worst conditions for them are during practice and demos when they are driving for longer periods of time, especially as they get used under low battery conditions.
As another poster said, the source of the heat is deep in the windings inside the motor and it takes quite a while for it to migrate to the outside of the case.
That doesn't mean that it's not of some benefit to remove any heat you can from them, but it's probably too little, too late for typical match use.
If I were going to install them on a CIM motor, I would use a heat sink compound, much like the heat sink on a CPU or transistor. The paint on the case would be a consideration as well, but with the narrow views of what is considered a "modification" in the rules, I'd be afraid removing paint might be a problem. Even the silicone compound might get questioned.
I'd save them for the practice robot.
-= Mentor Lockport Warlocks -=- Team 1507 =-
Amateur Radio Callsign: AE2T
2016 Robot Inspector - Fingerlakes, Pittsburgh
2015 Robot Inspector - Pittsburgh, Champs. Judge Observer - Champs
2014 Robot Inspector - Tech Valley, Fingerlakes, Buckeye, Championship
2013 Robot Inspector - Fingerlakes, Buckeye, Championship
2012 Robot Inspector - Fingerlakes, Buckeye, Championship - Website Evaluator - Fingerlakes, Buckeye, Championship
2011 Robot Inspector - Fingerlakes 2011 Safety Advisor - Fingerlakes
Unread 12-01-2014, 21:44
nuggetsyl's Avatar
nuggetsyl nuggetsyl is offline
FRC #0025
Team Role: Coach
nuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond repute
Cims do get hot and we have made heat sinks for team 25 and use them on the cims. Imo 80% of the teams do not understand how this game will played. This is not 2012 there is no safe zone. Imo this is the second coming of 2003. If you are a defensive robot and have the weight get some heat sinks.
00,12Championship winner
03,06,08 Championship finalist
02A,03C,06N,08C,11N,12G Division winner
00,03,06,07,08,10,12 NJ / MAR winner
11 VCU winner
06,10 Las Vegas winner
12 MAR Mt Olive
red is for team 348
Unread 12-01-2014, 21:48
AKA: null
Rookie Year: 2012
They aren't too heavy either. I beclieve they are under a pound, so just use them on some high-strain parts, like the drivetrain.
Unread 14-01-2014, 12:28
Rookie Year: 2012
I'm really thankful for youre replies guys
Good luck in competition and have great building season \
Team 1946
Unread 15-01-2014, 23:41
Vaude's Avatar
Vaude Vaude is offline
AKA: Will
FRC #4283 (RoboAces)
Rookie Year: 2013
Vaude is an unknown quantity at this point
The coach of my team actually owns Next Gen Robots, the company that owns the CIM coolers, which came in the KOP.
To demonstrate, he did a 3 minute test of CIMs under no load, and you can see they make a huge difference. once you think about what kind of load your teams may be putting on these motors, you'll see they are well worth the additional weight.
www.youtube.com/watch?v=O-A6PXVUmW0
I can direct questions you may have to him, when my team meets tomorrow.
Unread 16-01-2014, 14:57
RobotDoktor's Avatar
RobotDoktor RobotDoktor is offline
Cat Herder
FRC #4265 (Secret City)
Team Role: CAD
Rookie Year: 2013
RobotDoktor is just really niceRobotDoktor is just really niceRobotDoktor is just really niceRobotDoktor is just really niceRobotDoktor is just really nice
It can depend on your usage. Drive motors may not necessarily need it except during extended use or very high load. Our team's 2013 bot used a CIM to power a flywheel based shooter, which did get so hot in a demonstration/practice period we had to stop using it to avoid damage (oh, by the way, burning CIM is a bad smell). Any CIM that is under near constant use, especially on a PID, can definitely benefit from this. As to the overall effectiveness, it may not be as good as active cooling, but is simpler. The shell of the CIM is aluminum, so when the motor is hot enough it will conduct heat. Without some sort of thermal paste to aid the conduction between the CIM and the heatsink may not be totally efficient.
Unread 16-01-2014, 15:10
roystur44's Avatar
roystur44 roystur44 is offline
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
roystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond repute
Send a message via Yahoo to roystur44
The Banebot motors in a start stop high load conditions can get smoking hot. I've seen the power wires get red hot and melt the covering off. Wonder if there will be any heat sinks made for them???
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
Unread 20-02-2014, 13:29
Mason987 Mason987 is offline
President
FRC #0987 (High Rollers)
Team Role: CAD
Rookie Year: 2012
Mason987 is an unknown quantity at this point
I'm not 100%, but i was looking at the bag those heat sinks come in and they suggest using a compound themselves. We aren't using them so we won't run into this problem but I would imagine some thermal paste on them would be acceptable. Without the paste, the aluminum isn't transferring the heat as well, obviously enough. I'd imagine driving around and letting the air do the cooling might even be more beneficial than a heat sink without the thermal paste.
I could be wrong though.
Unread 10-01-2014, 09:33
Tungrus Tungrus is offline
Tungrus is just really niceTungrus is just really niceTungrus is just really niceTungrus is just really nice
For effective heat transfer between CIM (or heat source) and the heat sink, both should have max contact area possible. The heat sink in the kit does not contour to CIM curvature (at least the one I saw), reducing effective heat transfer, which is in addition to paint on the CIM. To maximize the heat transfer there are compounds, a paste that goes between the heat source and sink. Not sure if using heat compound will be considered as tampering, in my opinion it should not, thats for Q&A.
Having said that using this heat sink with some contact will result in better cooling than no heat sink. The fins provide larger surface area of heat dissipation.
