Using the AXIS camera (M1011) with OpenCV
So, I am using cv::CvCapture to get video. This code works with my internal webcam (cvCaptureFromCAM(0);. However, when I switch to reading from the net-cam (AXIS M1011), my app keeps crashing and OpenCV says that it can't find "../../modules/highgui/src/cap_ffmpeg_impl.hpp(545)"
What am I doing wring and why is it triggering?
the code is below.
PHP Code:
//----------------------------------------------------------------------------------------------------------- //face-tracking by Dev, 1.0 #include <opencv2/highgui/highgui.hpp> #include <opencv2/objdetect/objdetect.hpp> #include <opencv2/imgproc/imgproc.hpp> #include <iostream> #include <math.h> #include <string> #include <sstream> #include <vector> #include <WinSock.h>
using namespace std; //So I don't have to use std:: --don't worry. it's nothing big. using namespace cv; //so I don't have to use cv:: --same here :D. Just saves time
void processDisplay( Mat processed, Mat unprocessed ); //Subroutine declaration, processDisplay //String camIP = "xxx"; //Put your Camera MJPEG stream IP here int capMode = 1; //capture mode: 1 for internal; 2 for AXIS M1011; 3 for AXIS M1014; int FaceCount = 0; //variable for the nimber of faces detected int capFailures = 0; //Failure count in camera frame fetch. CURRENTLY UNUSED const int maxCapFailures = 10; //Max Failure count in cam frame fetch before exiting, with error code, -1. CURRENTLY UNUSED
CascadeClassifier face; //dscribes what a face looks like CascadeClassifier eyes; //describes what eyes look like
int main( int argc, const char** argv ) { //main function CvCapture* capture; //creates struct, "capture".************************************************* //capture.set( capture, CV_CAP_PROP_FRAME_WIDTH, 640 ); //Sets the capture size width to 640px. Currently deactivated //capture.set( capture, CV_CAP_PROP_FRAME_HEIGHT, 480 ); //Sets the capture size height to 480px. Currently deactivated //cvSetCaptureProperty(capture, CV_CAP_PROP_FRAME_WIDTH, 640); //Sets the capture size width to 640px. deactivated //cvSetCaptureProperty(capture, CV_CAP_PROP_FRAME_HEIGHT, 480); //Sets the capture size height to 480px. deactivated CvCapture* capture2; //Creates struct, "capture2" Mat unprocessed; //unprocessed image Mat processed; //processed image if( face.load( "D:\\SSDWIN7PRGFILES\\opencv\\opencv\\sources\\data\\haarcascades\\haarcascade_frontalface_alt.xml" ) ) { //loads one face cascade if( eyes.load( "D:\\SSDWIN7PRGFILES\\opencv\\opencv\\sources\\data\\haarcascade\\haarcascade_eye_tree_eyeglasses.xml" ) ) { //loads another face cascade cout << "I was able to load the cascades!" << endl; //message } else { //if not loaded second cascade cout << "Failed to load cascades!\n\n\tOptions:\n\t[ESC] to exit\n\tAny other key to try again"; //message|error analysis if( waitKey(0) == 27 ) { //waits and updates screen. Also detects keyboard commands return -1; //returns error code, -1; } else { //if no key was pressed cout << "Trying Again" << endl; //message|info } //close brace } //close brace } else { //message|error cout << "Failed to load cascades!\n\n\tOptions:\n\t[ESC] to exit\n\tAny other key to try again"; //message|error action if( waitKey(0) == 27 ) { //wait for [ESC] key return -1; //exit program with error code, -1 } else { //if no [ESC] key, try to configure cascade again cout << "Trying Again" << endl; //message|info } //closing brace } //closing brace if( capMode == 1 ) { //check capture mode, descibed above at variable creation capture = cvCaptureFromCAM(0); //set camera of "capture" to cam 0 capture2 = cvCaptureFromCAM(0); //set camera of "capture2" to cam 0 //capture2 = cvCaptureFromFile("root:paradise@http://10.11.65.10/jpg/image.jpg?size=3"); cout << "I'm going to use the internal camera." << endl; //message|info } else if( capMode == 2 || capMode == 3 ) { //if different cam mode //if( camIP.empty() ) { // cout << "IP not set" << endl; //} else { capture = cvCaptureFromFile("http://10.11.65.10/axis-cgi/mjpeg/video.cgi?camera=1&resolution=640x480"); //hook to network camera capture2 = cvCaptureFromFile("http://10.11.65.10/axis-cgi/mjpeg/video.cgi?camera=1&resolution=640x480"); //hook to network camera cout << "MJPEG stream opened" << endl; //message|info //} } //closing brace
if( capture ) { //check to see if capture was true bool msgq = 0; //to prevent message from repeating while( true ) { //infinite loop unprocessed = cvQueryFrame( capture ); //gather image from cam processed = cvQueryFrame( capture2 ); //gather image from cam //unprocessed = imread("http://10.11.65.10/jpg/image.jpg?size=3"); //processed = imread("http://10.11.65.10/jpg/image.jpg?size=3"); if( !unprocessed.empty() ) { //check to see if camera is outputing footage if( msgq = false ) { //make sure message doesn't repeat cout << "The Webcam Stream has been opened properly!" << endl; //message|info } //closing brace processDisplay( processed, unprocessed ); //run the processing algorithm msgq = true; //set flag to true } else { //if cam frame was not present cout << "Could not access the camera. Please maake sure nothing is already using the camera. Retrying" << endl; //message|error } //closing brace int c = waitKey(1); //+check to see if the [ESC] key was pressed if( (char)c == 'c' ) { //| break; //| } //+closing brace } //closing brace } //closing brace waitKey(0); return 0; //closes program with safe exit code, 0! } //closing brace
void processDisplay( Mat processed, Mat unprocessed ) { //processing algorithm Mat gray; //New matrix for the grayscale image vector<Rect> faces; //new vector to store the faces, where they are and how big they are vector<Rect> eye; //New vector to store info about the eyes
cvtColor( processed, gray, CV_BGR2GRAY ); //converts color image to grayscale equalizeHist( gray, gray ); //cleans the image
face.detectMultiScale( gray, faces, 1.1, 2, 0|CV_HAAR_SCALE_IMAGE, Size(30,30) ); //detects faces using a cascade eyes.detectMultiScale( gray, eye, 1.1, 2, 0|CV_HAAR_SCALE_IMAGE, Size(30,30) ); //dtects eyes using a cascade
Point2i p1(0,240); //point Point2i p2(640,240); //point Point2i p3(320, 0); //point Point2i p4(320, 480); //point Point2i p5(0, 0); //point Point2i p6(640, 480); //point Point2i p7(640, 0); //point Point2i p8(0, 480); //point line( processed, p1, p2, Scalar(113, 37, 105), 1, CV_AA); //line line( processed, p3, p4, Scalar(113, 37, 105), 1, CV_AA); //line line( processed, p5, p6, Scalar(1.0), 1, CV_AA); //line line( processed, p7, p8, Scalar(1.0), 1, CV_AA); //line cout << "I detected " << faces.size() << " face(s)! \n\t"; //message|output
int count = 0; //counter integer
for( count = 0; count < faces.size(); count++ ) { //Point center( faces[i].x + faces[i].width * 0.5, faces[i].y + faces[i].width * 0.5 ); Point center( faces[count].x + faces[count].width * 0.5, faces[count].y + faces[count].height * 0.5 ); ellipse( processed, center, Size( faces[count].width * 0.5, faces[count].height * 0.5 ), 0, 0, 360, Scalar(22, 127, 255 ), 2, 8, 0); cout << "Face Number:" << count+1 << ";\tPosition: X: " << faces[count].x << " Y: " << faces[count].y << endl; Point2i p9(320, 240); Point2i p10(faces[count].x + faces[count].width*0.5, faces[count].y + faces[count].height*0.5); line( processed, p9, p10, Scalar(33, 191, 152), 1, CV_AA ); }
count = 0;
for( count = 0; count < eye.size(); count++ ) { Point centerEye( eye[count].x + eye[count].width * 0.5, eye[count].y + eye[count].height * 0.5 ); ellipse( processed, centerEye, Size( eye[count].width * 0.5, eye[count].height * 0.5 ), 0, 0, 360, Scalar( 57, 64, 192 ), 2, 8, 0 ); }
imshow( "Processed Image", processed ); imshow( "GrayScale Image (Processing)", gray ); imshow( "Original Image", unprocessed ); FaceCount = FaceCount + faces.size(); cout << endl << "I have detected " << FaceCount << "Face(s) so far!" << endl; }
Thank goodness that CD shrinks the CODE box! Otherwise this post would be a couple pages long
Thanks!
