Go to Post You guys can send [Wisconsin] some warm Florida weather, its getting cold up here again. - Ricky Q. [more]
Thread Tools Rating: Thread Rating: 17 votes, 5.00 average. Display Modes
Unread 02-02-2014, 11:08
Kellen Hill's Avatar
Kellen Hill Kellen Hill is offline
Strategist
AKA: The user formerly known as 'hill'
FRC #1746 (OTTO)
Kellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond repute
Re: Build Blitz Robot Reveal - Team JVN
Aren had told me the other week that they milled a couple of grooves into the face of the gear (after milling the face of the gear flat to avoid contact with the choo-choo linkage). They then drilled a hole through the hex shaft and used a roll pin to retain the gear by using the grooves milled into the face of the gear.
1625 Winnovation Member: 2005-07
1625 College Mentor: 2007-11
525 Swartdogs Mentor: 2011-12
1746 OTTO Lead Mentor: 2013-Present
Unread 02-02-2014, 14:23
Aren_Hill's Avatar
Aren_Hill Aren_Hill is offline
Build Nifty Things
Aren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond repute
Yup, milled the boss flat, then put a roll pin through the end of the HEX shaft ~1/16th from the end. Then just milled a flat pocket just wide enough and deep enough to completely hide the roll pin.
With access to more screw sizes I likely would've just drilled and tapped the end for a large countersunk screw that was over 1/2" diameter to retain it.
A snap ring and counterbore would also work.
A guy who likes robots.
1625->3928->148->1296->971 oh dear
