11-01-2014, 14:05
AKA: Pinecone
Re: Build Blitz Robot Reveal - Team Copioli
Originally Posted by Switzer96
Not sure if I'm missing something but I was going through Team Copioli's CAD files, and it appears as if they are using a 15mm timing pulley (P/N 217-3230) to drive two belts out of the gearbox. The belts are not in the design, so I am trying to figure out how two would fit with what I'm assuming is a 9mm timing belt from vex pro. Are they using a different pulley/belt or would this be able to fit somehow?
I hope that more information on assembly will be released soon for teams looking into using Vex Pro's versa chassis system.
The 15mm pulley is a bit wider than that, and the 9mm belts are a bit narrower than that, allowing for two "9mm" belts to fit on a "15mm" Vex pulley.
--2016 Waterbury SFs (with 3314, 3719), RIDE #2 Seed / Winners (with 1058, 6153), Carver QFs (with 503, 359, 4607)
-- 2015 TVR Motorola Quality, FLR GM Industrial Design -- 2014 FLR Motorola Quality / SFs (with 341, 4930)
-- 2013 BAE Motorola Quality, WPI Regional #1 Seed / Delphi Excellence in Engineering / Finalists (with 20, 3182)
-- 2012 BAE Imagery / Finalists (with 1519, 885), CT Xerox Creativity / SFs (with 2168, 118)
Student: 1714 (2009) - 2009 MN 10K Lakes Regional Winners (with 2826, 2470)
