Go to Post ...he's acting like a programmer whose code is compiling...:yikes: - EricH [more]
Unread 11-01-2014, 20:01
E Dawg E Dawg is offline
... is not done with FRC yet.
AKA: Ethan
FRC #0159 (Alpine Robotics)
Rookie Year: 2012
E Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud of
Custom Dashboard problems: Help us please!
So the other day I was creating a custom dashboard. I created the build and replaced the default .ini file with the one created in the build. Upon deploying code, the dashboard a) did not change and b) I was asked if I wanted to manually configure my adapter. I said no and continued to the driver station. But now I am unable to communicate with the cRIO even though I am connected to the radio. I tried resetting the dashboard but that didn't help at all.
This is my error message: 44001: error at no network change.
Thanks for any help you can give.
Unread 11-01-2014, 21:41
Rick Wagner's Avatar
Rick Wagner Rick Wagner is offline
FRC #3008 (Kalani Robotics)
Rick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to behold
Re: Help us please!
I don't know how to answer your question, but I suggest you repost it in the Programming Forum for a quicker technical response.
Unread 12-01-2014, 12:53
AKA: Ethan
Rookie Year: 2012
Re: Custom Dashboard problems: Help us please!
Reposted to programming subforum.
Unread 12-01-2014, 13:13
Woolly's Avatar
Woolly Woolly is offline
Programming Mentor
AKA: Dillon Woollums
FRC #1806 (S.W.A.T.)
Rookie Year: 2012
Woolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond repute
Well, first of all, you need to replace the .exe file as well as the .ini file.
Second of all, to change the Driver Station network settings, go to "setup" and hit "Choose NIC" which will bring up the menu you got the first time you started the DS. You'll probably need to set it to "Local Area Connection* X" or "I will configure my wireless adapter manually" to get it to work.
Team 1806 Student: 2012-2013 | Mentor: 2013-Present
Unread 12-01-2014, 13:33
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
By default the Driver Station starts the Dashboard located in
C:\\Program Files\FRC Dashboard
with the default name of "Dashboard.exe"
You can replace this default dashboard with your own by renaming yours and placing it in that location.
Alternatively, not practical unless your Driver Station is also your Programming laptop,
The LabVIEW button on the Driver Station Setup tab looks in:
My Documents\LabVIEW Data\builds\FRC Dashboard Project\FRC PC Dashboard\Dashboard.exe
