Team 314 Launcher
This is our final design review launcher, there is still evaluations being done but this video does a good job of showing our half court-in sweet spot. Hope you enjoy!!
https://www.youtube.com/watch?v=lWRYRpHFIaE Here is the link for Intake and Shooter video, roughly 19 feet away. https://www.youtube.com/watch?v=I1coTKRfynA Last edited by RonnieS : 14-01-2014 at 00:06. Reason: New Video |
Re: Team 314 Launcher
We have a gen 1 shifter that I took the high gear out of and milled the teeth (3 of them)down to a flat face so that when the high gear transfers from low (winching the catapult back) to high (releasing into a free spin) where the dog has nothing to grab and the shaft releases to the direction of tension making the ball fly. On the output shaft there is an external ratcheting mechanism so that the tensions is released from the motors as it is drawn back. Also, we adjust our hard stop so we can get different angle shots such as a blop shot for a good truss toss.
is it a ball shifter(i was told that they wouldn't work) |
It is a Gen 1 AM shifter, modified for our needs. It uses a dog gear, not balls.
love the idea, think its genius! |
What are you using as a spring? Do you find the initial angle of the spring makes a difference?
#11
Great prototype, how far were you guys from the goal in those first couple of shots? Looked like half field.
#12
Impressive!
Are you guys changing any of your parameters between the different shot ranges? It looks like it really is a "sweet spot" where everything stays the same: retract length, hardstop length, tension, etc. |
#13
What was your effective range on that launcher? It seemed like you could still score really close to the goal.
#14
This is a really impressive catapult. Basically what we are looking for as well. Good job!
#15
We can be as close as 3 feet away with the same sweet spot as half court
