Go to Post From what I've seen in FIRST, teams that copy generally always learn something from it, and if they don't, the copy they produce is of much lower quality than the original. - TheOtherGuy [more]
Unread 01-13-2014, 09:07 AM
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
License expiring in 2 weeks
I have a couple of students who did not uninstall last year's WindRiver installation before installing the new one. The result is that WindRiver came up saying the license is expiring in two weeks. Is there a way to "update" the license instead of uninstalling and reinstalling? This process takes hours and we are trying to avoid it.
Unread 01-13-2014, 01:25 PM
Sparkyshires Sparkyshires is offline
AKA: Michael Shires
FRC #0384 (Sparky)
Sparkyshires is an unknown quantity at this point
Re: License expiring in 2 weeks
No. Another horrible side effect of WindRiver, they make this impossible. The only benefit is that they also include software for quick uninstallation (windows menu, all programs, WindRiver, Product Maintenance - remove all products.) If I could make a recommendation, at your next meeting copy the contents of the disks onto multiple USB devices so that all your students can take either a usb stick or the Disc home and you could get all the uninstalls and installs done in one night.
Unread 01-13-2014, 04:15 PM
RufflesRidge RufflesRidge is offline
RufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant future
http://wpilib.screenstepslive.com/s/...elopment-tools
Under "Existing Installations"
Unread 01-13-2014, 04:56 PM
Animal Control's Avatar
Animal Control Animal Control is offline
FRC #2345
Rookie Year: 2007
Animal Control is infamous around these partsAnimal Control is infamous around these partsAnimal Control is infamous around these partsAnimal Control is infamous around these parts
none that I can find.
Unread 01-13-2014, 09:02 PM
AKA: Michael Shires
FRC #0384 (Sparky)
Originally Posted by RufflesRidge View Post
I actually tried the use existing installation process, but it just skips to the end. it doesn't actually install anything. Not sure if that was a personal issue though.
"Measure with a micrometer, mark with chalk, cut with an axe."
Unread 01-22-2014, 11:13 AM
mmavipc mmavipc is offline
FRC #1622
mmavipc is an unknown quantity at this point
It IS possible. On disk 1 there will be a file named similarly to "FRC_2013_WB30_WB33_install.txt"
Go to your installation directory, usually C:\WindRiver there will be a file called "install.txt"
Replace install.txt with the file on disk 1 of this season's KoP, and WR should recognize the new license. Make sure you also rename the new license to install.txt
Unread 01-22-2014, 06:41 PM
Did it update your license though?
