Go to Post FIRST: Making women's hair grow, and mens hair fall out. - Ashley Christine [more]
Unread 13-01-2014, 09:59
MrRoboSteve MrRoboSteve is offline
Mentor
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
Rookie Year: 2011
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
Q&A Q26: PDB (and router and digital sidecar) location
Q&A has this question and answer:
Q.Rule R39 - what does "easily" mean? Does it mean that the PDB must be visible if the robot is in it's
normal upright position, or is it OK to turn the robot on its side to look at the PDB? Is this during
inspection only, or does it have to be visible while the robot is on the field?
A.The Team must be able to put the ROBOT in a configuration where the PD Board and circuit breakers
are easily visible to the Robot Inspector. There is no requirement for the PD to be visible during a
MATCH. However, having the PD visible with the ROBOT in its "normal" position can aid in on-FIELD
troubleshooting.
Here's some scenarios you need to think about when laying out the electronics on your robot.
1. Your robot didn't move during a match, stopped moving during a match, or parts of your control system have stopped working. Can you see the PDB and the Digital Sidecar and the cRIO well enough to see the indicator lights for troubleshooting purposes?
2. Your robot is on the field, but the robot is not connecting to the FMS. Can you and the FTA/CSA easily see the indicator lights on the router?
Extra credit: explain why experienced teams generally mount the router higher up on the robot in a visible location, using sticky Velcro.
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
Unread 14-01-2014, 00:46
Matt Stemple's Avatar
Matt Stemple Matt Stemple is offline
Lead Robot Inspector - Sacramento
Rookie Year: 2012
Matt Stemple is a name known to allMatt Stemple is a name known to allMatt Stemple is a name known to allMatt Stemple is a name known to allMatt Stemple is a name known to allMatt Stemple is a name known to all
Inspector tip. Label your main breaker in addition to keeping it visible. Check to ensure still visible with bumpers on. During inspection with bumpers off it may look great, then bumpers on the breaker is hidden. Oppps.
End-goal is to prevent damage to your robot in the event of a 'smoking' failure. Having the main breaker labeled on the bot for the FTA or field support to quickly find may prevent further damage.
Again if failure with smoke, you may need to quickly replace wire or components. Easy access to PD will help a lot during post incident troubleshooting.
Matt Stemple
Sacramento Regional LRI, www.cafirst.org
