Go to Post "What other program puts these role models on a first name basis with teenagers?" - Andy Baker [more]
Unread 13-01-2014, 15:11
TogetherSword8 TogetherSword8 is offline
FRC #0888 (Robotiators)
Rookie Year: 2012
TogetherSword8 is an unknown quantity at this point
Programming a Custom Dashboard
We are looking at creating a custom dashboard for our team this year. Is there any element of the dashboard that must communicate with the field, or are we able to edit the dashboard code freely for our purposes?
I program a robot. Which means I write code and everyone gets mad at me when something doesn't work, even if I am the only one that knows it doesn't work. The key part to know is that the robot never works.
Unread 13-01-2014, 15:24
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Programming a Custom Dashboard
There is no requirement for a Dashboard program to implement any specific communication with anything. There isn't even a requirement for a Dashboard program to be running. You can do pretty much whatever you want with it, subject to limitations on available network ports and bandwidth.
Unread 16-01-2014, 18:31
William Kunkel William Kunkel is offline
Programming Lead
AKA: Kunkel
FRC #0422 (Mech Tech Dragons)
Rookie Year: 2011
William Kunkel is an unknown quantity at this point
Just to clarify, the Driver Station (the bottom part of the standard display) is required by FIRST and cannot be modified or replaced. The Dashboard (the top part of the standard display) is not required and can be whatever you want.
Unread 16-01-2014, 19:23
yash101 yash101 is offline
Curiosity | I have too much of it!
AKA: null
Rookie Year: 2012
yash101 is an unknown quantity at this point
It'd be cool to be able to minimize the FMS DS, and create a web interface for the cRIO, to create a custom DriverStation! It would probably be legal because the robot is still master-controlled by the FMS, running with the normal DS!
Unread 16-01-2014, 19:59
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
While it might be cool, it would be illegal per R92.
Unread 16-01-2014, 21:07
When the window borders are removed, the DS is only 200 pixels tall. On most laptops that gives you lots of space for a dashboard. Do you really need to minimize?
When the window has borders, it can in fact be minimized. I'm not sure what an FTA or FTAA would say about that on the field. Please keep in mind that if they have trouble getting your robot and DS connected, you will potentially slow down match schedules.
Greg McKaskle
