Go to Post Nothing says poor quality like a wrinkle in duct tape. - Matt C [more]
Thread Tools Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
  #16   Spotlight this post!
Unread 14-01-2014, 08:23
Kevin Leonard Kevin Leonard is offline
Professional Stat Padder
FRC #5254 (HYPE), FRC #20 (The Rocketeers)
Rookie Year: 2011
Kevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond repute
Re: Aerial Assist--Perspective from a low-resource team
First of all- color me impressed that you're done at such an early rate. Using the kitbot and being smart about your mechanisms like your team seems to be doing is a great way to finish early and get in driver practice.
I would recommend you try to find some practice space and really test what you can do. How fast can you complete a cycle on your own?
Build two more kitbots to practice doing assists with if you have the resources.
See the exact range of your mechanisms, see what they can do that might be unexpected.
Last year we built our robot to shoot 3's from in front of the pyramid, we discovered through some practicing and trying different things that when our shooter was in the "up" retracted position, we could shoot into the pyramid goal, which gave us another option when cycling under heavy defense.
Really knowing your robot's capabilities inside and out can give you a HUGE lead on the competition at your first regional, and even throughout the season.
Maybe improve your mechanisms further. Fine-tune the shooter to get a larger sweetspot, improve your catching abilities, etc.
I hope you guys have an awesome season, because you seem to be off to a great start.
All of my posts are my opinion only and do not reflect the views of my associated teams.
College Student Mentor on Team 5254, HYPE - Helping Youth Pursue Excellence
(2015-Present)
Alumni of Team 20, The Rocketeers (2011-2014)
I'm attempting a robotics blog. Check it out at RocketHypeRobotics.wordpress.com Updated 10/26/16
  #17   Spotlight this post!
Unread 14-01-2014, 08:38
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Bongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond repute
Send a message via MSN to Bongle
This should keep your mechanical team happy:
1) Drive it like you stole it until it breaks*
2) Do a failure analysis, redesign/remanufacture the broken component, or put into place a procedure that will detect the failure pre-match.
3) Goto 1.
You're probably correct that many other teams are at the same spot you are, and will now be iterating their designs to make them faster, more reliable, and more effective. Simply having a robot that can do the game task won't be enough. You've got a fantastic chance to build a 6th or 7th version of your bot by ship day. That should keep your mechanical guys busy.
*"Breaks" and the associated fixes can mean many things:
1) Did the driver screw up? Maybe your control software is too confusing and needs adjustment.
2) Did the robot munch its own part? Maybe you need sensors to prevent that from happening, or you should design the part to be less likely to wreck itself
3) Did a part simply break? Time for a redesign or beefing-up of that part.
4) And of course, you can simply redefine success. Can your robot pick the ball up 10 times in a minute? Change your requirement to 15, and see what needs to be done (driver training? pickup redesign? different ball-approach tactics?) to get your effectiveness up to that level.
5) Did a normal wear component break? How easy was it to replace? Could you design the robot to have greater access to that part?
6) Was something forgotten before a test session and delayed the start of the driving? Make some checklists or maybe even have the robot software self-check that everything is present and working.
7) Are there areas of the field that your robot won't be able to pick up the ball, like corners or in the open field? You could change the pickup to make it more effective in those areas. Also, see [4].
8) Can your catcher catch a ball thrown blindly (a human could throw it backwards over their head) 100% of the time?
  #18   Spotlight this post!
Unread 14-01-2014, 10:41
RonnieS's Avatar
RonnieS RonnieS is offline
Just a tad washed up
AKA: Ronnie Sherrer
FRC #0314
RonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond repute
Our team works our a classroom and have very similar situations regarding machining. What we have learned is that we need to build within our limits but still somewhat custom just takes careful practice. We manage to have a decent robot, at least from the past couple years. We love to bend 1x1 tubing for framing and mechanisms....its very hard but takes very little resources btw, a good 2 axis vise for a drill press makes a world of difference!
"Do not argue with an idiot. He will drag you down to his level and beat you with experience"
