Go to Post Use sensors to collect data about the surrounding environment, then discard it and drive into walls. - Jared Russell [more]
Unread 13-01-2014, 17:55
rwkling1's Avatar
rwkling1 rwkling1 is offline
FRC #2977 (Sir Lancer Bots)
Team Role: Leadership
Rookie Year: 2011
rwkling1 has a spectacular aura aboutrwkling1 has a spectacular aura about
Ri3d Gearbox
I see that the gearbox in the robot in three days video is from ir3 creative, but I can't seem to figure out where the "dog gear" is. Is this something that they made custom? or is it somewhere on the website that I don't see?
Thanks!
Unread 13-01-2014, 19:20
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
Rookie Year: 1996
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
Re: Ri3d Gearbox
The dog gear was from an Andymark shifter.
I believe it had been modified slightly so it was shorter overall.
Dan or Andrew will have to weigh in with specifics.
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Unread 13-01-2014, 22:46
Dan Richardson's Avatar
Dan Richardson Dan Richardson is offline
iR3 Creative
AKA: Dan Richardson
Dan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond repute
Re: Ri3d Gearbox
Thanks!
We did modify some of our shifter parts but we have since redesigned it slightly to package standard COTS parts.
The cad model with BOM for that gearbox is here: http://www.robotin3days.com/ri3d-1-0...eting-gearbox/
A video walk-through is here: http://youtu.be/xx3I2_CYeGs
BOM:
Modulox Lunchbox QTY 1
Modulox Bearing Block QTY 1
12 Tooth CIM Pinion Gear QTY 1
AM Shifter Block Assembly QTY 1
AM Dog Gear QTY 1
AM 48T Shifter Gear QTY 1
3/8″ Ratcheting GearWrench
Compression Spring: McMaster Part # 9657K273
Modulox Shifter Shaft (Link TBD)
CO-Founder of Robot in 3 Days and the Robot in 3 Day Challenge.
Unread 14-01-2014, 09:15
discobrisco's Avatar
discobrisco discobrisco is offline
FTC #2410
Rookie Year: 2012
discobrisco is an unknown quantity at this point
Ri3d Gearbox
What we did for our prototype is cut a hole in the spacer and put a ratcheting wrench around the shaft, then remove the smaller gear from the shifting mechanism. It was a quick and easy modification and I believe they did the same.
Edit-we did this in the super shifter.
Unread 14-01-2014, 09:32
Jacob Paikoff's Avatar
Jacob Paikoff Jacob Paikoff is offline
FRC reunion tour
FRC #0079 (Krunch)
Rookie Year: 2007
Jacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant future
Re: Ri3d Gearbox
Dan,
What's the difference between the Modulox Shifter Shaft and the Long SS Hex Shaft that AndyMark currently sells?
Just from looking at the CAD of the gearbox the two looked more or less interchangeable.
Team 79, Krunch 2007-2010 Student
Team 2059, The Hitchhikers 2011-2014 College Mentor
Team 5402, The Iron Kings 2015 Mentor
Team 79, Krunch 2016 - Mentor
Unread 14-01-2014, 21:31
iR3 Creative
AKA: Dan Richardson
Re: Ri3d Gearbox
Originally Posted by Jacob Paikoff View Post
Dan,
I may need to do a deeper dive but I believe the major difference is that the the Long SS Hex Shaft is missing the bore and slot to shift the dog. I believe in the AM shifters these features are incorporated in a cluster shaft.
Unread 16-01-2014, 23:43
TheKeeg's Avatar
TheKeeg TheKeeg is offline
Michigan Tech Engineering
AKA: Keegan Harrington
FRC #0068 (Truck Town Thunder)
Rookie Year: 2013
TheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud of
Re: Ri3d Gearbox
We are currently designing a winch system to draw back and release our catapult and I am intrigued by the lunchbox. A few questions about your Ri3D robot...how many pounds of force did it take to draw the catapult back? We need about 50-75 lbs or force at about 22 inches from the catapult's pivot point and I am curious as to how well this transmission will perform. We started designing for a WCP 2 speed transmission but later determined that it was not the best one to use.
Thanks, Keegan
Unread 18-01-2014, 09:54
iR3 Creative
AKA: Dan Richardson
Re: Ri3d Gearbox
I apologize, I was incorrect. The only difference that I can tell is that the hex portion, and the 3/8" round version of ours are slightly longer. If it were just the hex it would be interchangeable but the 3/8" in the Long SS Hex Shaft round would fall short of the bearing.
Unread 18-01-2014, 16:51
FRC reunion tour
FRC #0079 (Krunch)
Rookie Year: 2007
Re: Ri3d Gearbox
Thanks Dan, I'm glad you cleared that up.
Unread 22-01-2014, 23:40
Cash4587's Avatar
Cash4587 Cash4587 is offline
Mentor
AKA: Cooper Cash
FRC #4587 (Jersey Voltage)
Team Role: Coach
Rookie Year: 2013
Cash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud of
Re: Ri3d Gearbox
Is there an updated BOM for with the other link that was "tbd"?
Unread 23-01-2014, 08:21
iR3 Creative
AKA: Dan Richardson
Re: Ri3d Gearbox
Looks like its the site has the shaft as part number AM-2777 and they have a kit listed under AM-2774.
It doesn't look like there is an order page for the shaft. If you're trying to place an order maybe you can call and have them add the shaft to it.
Unread 16-02-2014, 22:39
arun4444 arun4444 is offline
FRC #3760
arun4444 has a little shameless behaviour in the past
Re: Ri3d Gearbox
Here is the shaft
http://www.andymark.com/product-p/am-2770.htm
Unread 16-02-2014, 23:57
rwkling1's Avatar
Rookie Year: 2011
Re: Ri3d Gearbox
Thank you, but it's a little late now
