Go to Post Lesson learned: don't hide cables where drills can find them! - Richard Wallace [more]
Unread 16-01-2014, 20:07
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: Mecanum forward rotation error
Originally Posted by mattachew12 View Post
Yes we have, the square white connector is plugged in to the DSC under the (-) and (+) symbols, and the red is with + and black with -. They are plugged into the PD board under a 30A slot with a 20A fuse.
If the fuse is good, unplug the white connector and use a voltmeter to check if there's voltage at the connector, with the correct polarity.
